Help Gremlins in restore point...
coldengrey
I recently tried to run restore point, after all my start up programs/services got shut off (more on that in moment...) and restore point FAILED due to some error (basically what info notice said after restart)
I'd recently installed ccleaner, revo uninstall pro, acronis (preparing for move to 64bit windows 7). Not sure if one of the are responsible for shutting down almost all of my start up programs, ect?
*I did also recently install windows updates - are there any known bugs or problems with the most recent?
Is there any way to restore the restore points?
Thanks
    Dell Inspiron 1520
    Intel Core 2 Duo T7300 2-GHz
    2x1GB DDR2 PC2-5300
    Nvidia GeForce Go 8600GT 256MB
    Dell U2311H
Hello coldengrey and welcome to the forums :party:
Is there an error code? This is usually some random characters and numbers. For example: (I know this is windows update, it's the same principle though)
As for the bugs, not as far as I know, it's almost definitely a problem at your end
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Make a full anti virus scan download and make a full scan with Malwarebytes
For Rich's advice:
Malwarebytes Anti-Malware
Download and install MBAM from here
Run a full scan and attach the log with your next post
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
