casandra27
My desktop its an hp, having major issues and now won't boot to windows. i forgot model but i know its got wind v 32bit, intel processor, 2 512mb ram. I had did a factory image restore on 6-18-11. bout 5 days ago, it started going stupid on me. so i tried to due factory restore again. upon reboot i keep getting thrown to recovery. i try the repair my computer, and it says windows startup repair unable to repair. did chkdsk/r, looked at drive through diskpart has two patitions, both are healthy. tried again with image same results. went back to command prompt an did bootrec/fixboot, states action was completed successful. attempted image again now does a crash dump, booted back up and went to recovery and attempted safe mode, goes through drivers loading and crash dumped again. what follows is the repair detail
problem event name StartupRepairV2
prob sig 1 unknown
2 6.0.6000.16386.0.0.0.0
3 0
4 65537
5 unknown
6 NoOsinstalled
7 0
8 1
9 Fix Partition Table
10 1168
OSVersion 6.0.6000.2.0.0.256.1
Local ID: 1033
so i go through the motions and repeat repair attempt and alt prob event shows below
Problem Event Name StartupRepairV2
prob sig 1 AutoFailover
" " 2 6.0.6000.16386.6.0.6000.16386
3 6
4 196611
5 Nobootfailire
6 Failure During Setup
7 0
8 0
9 unknown
10 1168
OSVersion : 6.0.6000.2.0.0.256.1
Locale ID: 1033
these two alternate over and over, I am needing more repair info or steps I hope I still have options, thanks in advance.
prob sig 1 unknown
3 0
4 65537
5 unknown
6 NoOsinstalled
7 0
8 1
10 1168
Local ID: 1033
3 6
4 196611
5 Nobootfailire
7 0
8 0
9 unknown
10 1168
Locale ID: 1033
- Toshiba Satellite L350D Laptop
- 3 gb
- NVIDA
