I am trying to open a document that I downloaded from my e-mail (I clicked save but did not click save as) so it was saved as a temporary file only!
I located that temporary file but it will not open saying it was incorrectly decoded
I also located the file shortcut itself in my roaming folder but it gives me this message:
The Item xxxxx that
this shortcut refers to has been changed or moved, so this shortcut will no
longer work properly. Do you want to delete this shortcut?
I need to locate the modified file because it is of utmost importance, what can I do?
The Item xxxxx that
- Sony Vaio
