PixelOz
Hi I'm David and I'm new to the forum so I say hi to all the other PC lovers like me out there. I have been having this odd issue with File Exlorer since I bought my PC about 1 year, 9 months ago.
Very often when I open the File Explorer and I double click on the C:\ drive icon the folder location jumps to either the Picture folder (C:\Users\David Guzman\Pictures) or to the Music folder (C:\Users\David Guzman\Music) instead of displaying the root folder files and the other folders contained in it so in order to do that I have to click once the blue back arrow (the left one) and then it gets to the root folder in the C:\ drive the way I think it should have done when I first double clicked the C:\ drive icon.
It does this all the time (very frequently) but it mostly jumps to the Pictures folder and it also does this sometimes when I'm inside another folder (any) and I double click in it to see its contents in which case I have to do the same (click the back blue arrow) in order to see the correct content.
Does anybody have a clue of why it does this? Is this some sort of Vista bug?
Other than that the OS has performed very, very well from the get go. It seldom crashes, say what some people say about Vista vs XP (and I have 3 XP PCs at home) I think that my Vista OS hasn't crashed more than 4 times since I bought it, programs crash here and there (but rarely, you know, the normal thing) but the OS has been rock solid and that is way better than the track record that my XP machines have even tough they are relatively stable too so you won't catch me among those that criticize Vista that much, nope.
I know that is not the fastest but I don't mind that that much, my PC is fast enough for me.
Now going back to the main subject at hand. The PC is regularly checked for viruses with different security software (with on demand scanners, I only have one real time antivirus engine running as it is supposed to be - Avast). It has had about 3 different antivirus programs with 3 different firewalls (it currently has Comodo firewall) so far so I don't think that the problem is there.
I have checked the disk many times and defragmented it too as part of regular maintenance and also system files are checked at intervals to keep things in check.
My mouse is a Logitech EX-100, it was part of the Logitech cordless desktop EX-100 but I only use the mouse nowadays cause the keyboard sometimes didn't work so well so I replaced it with a wired Microsoft Basic Keyboard 1.0A. I removed the batteries from the wireless keyboard just in case.
The drivers of the mouse are current (I downloaded the latest version today) but it still does this anyway so I don't think that the problem is there either. The mouse works perfectly otherwise and the PC works like a charm overall.
Any ideas? Has anybody found this weird bug too? :huh:
- Generic self assembled PC
- Intel Core i7 920 2.66 Ghz
- MSI motherboard X58 Platinum SLI
- 6 GB Patriot memory 1333 Mhz triple channel
- 2 x Evga GeForce 260 GTX in hardware SLI mode
- Motherboard Realtek sound
- Acer H213H 21.5 inches
- 1920 x 1080 HD
- Hitachi 1 terabyte Sata hard disk Deskstar 7K1000.B + Western Digital 1 terabyte My Book USB external drive for backup
- PSU
- Ultra 750 watts PSU - 750Pro LSP750 Part No. ULT31502
- Case
- Ultra 923 full tower ATX Part No. ULT40125
- Cooling
- Stock Intel CPU cooler with 3 chasis fans
- Logitech EX-100 mouse part of wireless desktop w/o keyboard
- Microsoft Basic Keyboard 1.0A
- 3 Mbps
- Other Info
- Ultra UPS 1000 VA Model No.Ultra - 1000AP
