autoplay does not give the right options
oznola
hi,
i want to import .MTS files from an sd card using autoplay but there seems to be no option for that on my vista machine with sp 2 in the autoplay popup dialog.
the options chosen in the control panel menu for autoplay do not seem to help.
i have a friend who can do this using their similar vista machine.
we have scratched our heads quite allot to figure this out but no luck.
i have tried to run autoplay repair but it keeps crashing with no result.
can anyone advise please?
thank you.
    Dell M1530
    Intel Core 2 Duo
    2gb
Hello and welcome to the forum.
When you say it crash's what are we talking about, does it hang, does it freeze, not responding, or is it a blue screen, it is very important on what kind of crash.
Please tell us when this problem started and what were you doing at the time, did it crash the first time or after a few times of trying.
Plus I want you to do the following right away.
1. Run a full updated virus scan using you internet security...
2. If you don't have malwarebytes then download and run a full scan, here is the free version. Malwarebytes while running your AV or malwarebytes let it run and don't use your computer until it's done, let me know when you do the scans and the results. I want to know that you do not have a virus or malware on your system. This will not take to long...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
hi,
i have run a full scan using the malware software you suggested. no malicious items were detected.
the crashes before were announced by pop-up dialogs which said that the "program had crashed"(sic)
autoplay repiar did not crash this time but there are only three options in the tab related to how to handle video files.
the options in the autoplay video tab are "Play using windows media player", there is a windows logo with no explnation, and there is a third item in this tab for adobe photoshop elements with the subtitle "Organize and edit".
but when i insert an sd card with .MTS files into the reader i am not presented with these options in the autoplay dialog. and changing the options in Control Panel>Autoplay does not help. (there is no effect from settings there)
my goal it to have the .MTS files transfered to the hard disk automatically and then erase them from the sd card.
how can i set this up please?
thank you.
    Dell M1530
    Intel Core 2 Duo
    2gb
hi,
thank you.
I'm guessing your friend has a program installed that allows them to be imported.
MTS File Extension - Open .MTS files
Here's a couple links that might help,
HD camcorder files saved as .MTS How do I save them in a format that - Microsoft Answers
How to Import Mts Files to Windows Movie Maker | eHow.com
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
