I have been experiencing this issue on a regular basis ever since I got my Vista desktop. Recently I upgraded to Windows 7 and the problem persists.
Every once in a while the hard drive starts working intensively and the computer becomes almost unresponsive. It stays like this for anywhere between 30 minutes and a couple hours. If I reboot the issue does not go away; the "process" continues until it completes at which moment the computer becomes normally responsive again.
I have tried to track down the culprit using both the Task Manager (Resource Monitor) and Process Explorer. It's not obvious what the process causing the slowdown is but it seems to run in a svchost.exe. I am quite sure that changes to very large files on the hard drive (hundreds on megabytes, gigabytes) trigger it. CPU usage is relatively low.
For diagnostic purposes I have disabled several tasks: antivirus/antimalware; defragmentation; system restore; prefetch; windows search; file indexing -- to no avail, the problem persists.
My theory so far is this: when files on the hard drive undergo changes, particularly large files, Windows runs some scheduled process at normal priority to reorganize the hard drive and/or compress or defragment files, irrespective of my settings. The larger the files, the more time it takes to complete and the longer system responsiveness is limited.
The annoyance is that during this time I cannot use the computer; I have to wait it out. As I mentioned, rebooting does not help. As a matter of fact, if I reboot then the shutdown and restart are extremely slow (can take 15-30 minutes each).
It drives me crazy. I was hoping that the upgrade to Windows 7 would fix the problem but it didn't. Any advice?
- HP Pavilion
- AMD Athlon 64 X2 5200+ 2.7 GHz
- 4 GB
- NVIDIA
- 500 GB
