Solved Help: Cmos resetting problem
zuriat
Can someone help me with this problem please.
On January 1st, 2011 my PC clock reset itself to default factory date which is 2009.
Duse to this event most of my software registration and activation has been screwed up.
Every tine I start my PC, I am told that my CMOS setting is wrong. Eventhough I entered Setup to change the CMOS date to 2011, the same thing will happen all over again when I restart my PC!
Below are the details of my problem and PC:
Problem
1.
CMOS Setting Wrong
CMOS Date and Time Not Set
Halt On: [All, but Keyboard]
2. Computer reverted to 01/01/2009
CMOS Setup Utility
System Date: 01/01/2009
System Time: 12:10:57
Manufacturer: American Megatrends Inc.
Computer OS: Vista-X68
Processor Type: Intel [R] Core [TM]2 Quad CPU Q8400 @2.66 GHz
System Memory: 4096 MB
System Manufacturer: Acer Aspire M5800/M3800
System BIOS Version PU1-AO
BIOS Release Date: 12.10.57
Antivirus and Internet Security: Trend Micro Titanium
Any help from this forum will be appreciated bbefore I decide to reformat and re-install my Vista.
Thank you in advance,
Zuriat.
    Acer Aspire M5800
    Intel(R) Core (TM)2 Quad CPU Q8400 @ 2.66 GHz
    Intel (R) 4 Series Chipset
    4.00 GB
    ATI Radeon HD 4650
    Realtex High Defination Audio
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
    IE 8 Windows Media Player
Change the battery in your computer. Reset your bios to clear any errors that may have been caused. Change the data in the Bios to how it is needed. The battery is quite cheap and will save you alot of time.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Thank you Roy69,
I will try and change my PC battery and see if the problem is resolved.
Zuriat.
    Acer Aspire M5800
    4.00 GB
    ATI Radeon HD 4650
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
Hi Roy69,
I changed my PC's battery and it solved my problem.
You are spot on, thank you.
    Acer Aspire M5800
    4.00 GB
    ATI Radeon HD 4650
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
Help. It is happening again. My PC system date is reverting back to 2009.
I have changed my motherboard battery 5 times and the problem is recurring.
What can I do short of changing my battery?
Thank you.
    Acer Aspire M5800
    4.00 GB
    ATI Radeon HD 4650
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
Go into the BIOS menu and reset to factory defaults and then change what you need. Also I suggest that you scan for malware.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
when my PC does that My PC current time settings also changes to the same date in 2009.
This in turn causes a lot of other problems like my Windows auto update, website signature expiry date and validity, my internet security anti virus time stamp is also giving me problem??????????????????????
I reset my Bios every time I start up my computer because the date revert to factory default!
I am using Trend Micro Platinum Internet Security which is a top of the line anti-virus.
    Acer Aspire M5800
    4.00 GB
    ATI Radeon HD 4650
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
In addition to what I sent you in the email, have you got any RTC sync software?
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
:huh:
Forgive my ignorance; What is an RTC Sync. software?
    Acer Aspire M5800
    4.00 GB
    ATI Radeon HD 4650
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
    Acer Aspire M5800
    4.00 GB
    ATI Radeon HD 4650
    Dell E207WFP
    1680 by1050 pixels
    ST3320418AS
    Acer wireless
    Microsoft
    1000 mbps
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
