I am running Vista Home Premium x64 and I would really like to run a logoff and/or shutdown script. Do you have a way to do it? I know it's in gpedit and I have seen a lot of posts where people have added scripts with gpedit and then tried to do a before & after analysis of the registry to see how to manually add a script - but it is really complicated and I can't get it to work.
Good grief, you would think that running a logoff/logon/startup/shutdown script would be as easy as adding one registry entry but I can't find any information. And it sure doesn't help that you have to logoff/logon/restart to test it.
I'm hoping that you have the magic answer!!!
