Solved Help! right click menu issues
chaosrealm93
Power User
Hello forum, i recently installed a program called Encspot, used for analyzing mp3 files. however when i uninstalled it, it left behind an entry in the right click menus. i cant find a way to delete it from the menus. and when i try to click on "view with encspot", it gives me this message. please help =|
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
Press F5 (Refresh screen) & see if the item is actually there?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
thx for the quick replies =) i tried richc46's link and tried the registry restore. that helped fix the problem.
PS, i also F5-ing before i did the registry restore.
thx again guys =P
    ASUS M3A79-T Deluxe
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Corsair AX850
    Logitech G500
    iunno.
Very welcome :)
Thanks for the kind words, too.
oh, 1 more question, how do you close this thread and mark it as "solved" or the equivalent?
    ASUS M3A79-T Deluxe
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Corsair AX850
    Logitech G500
    iunno.
Very good, forum spirit.
Upper right, the triangle.
Click on it
Type solved.
The Moderators will close it for you.
so type report "solved" in the "report post" dialogue box? okies =)
    ASUS M3A79-T Deluxe
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Corsair AX850
    Logitech G500
    iunno.
Notice the green check next to the title of the thread - it has been marked as solved by the moderators.
    1920 x 1200 pixels
Lorien is correct.
But we hope that you visit often and it is good that you know how it is done
Just type solved, in the future
i see. thx Lorien and richc46. =)
    ASUS M3A79-T Deluxe
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Corsair AX850
    Logitech G500
    iunno.
