W WhoYouWith Member Oct 7, 2010 #1 Hey guys I accidental deleted these and now im stuck any ideas? My Computer System One
pacinitaly HappyGuru Lovin2Help Vista Guru Oct 7, 2010 #2 will this help? Attachments SystemPropertiesAdvanced.exe SystemPropertiesAdvanced.exe 80 KB · Views: 272 My Computer System One Manufacturer/Model gateway/m6881 CPU centrino core 2 duo 2.2ghz T7500 Memory 3GB Hard Drives 500GB WD Mouse logitech Internet Speed fios 35MB not!!!!
W WhoYouWith Member Oct 7, 2010 #3 hey,thanks for getting back i just downloaded the link and it was a file not a installation were should i place the file . thank you My Computer System One
pacinitaly HappyGuru Lovin2Help Vista Guru Oct 7, 2010 #4 place the file back in the folder C:\Windows\System32 My Computer System One Manufacturer/Model gateway/m6881 CPU centrino core 2 duo 2.2ghz T7500 Memory 3GB Hard Drives 500GB WD Mouse logitech Internet Speed fios 35MB not!!!!
pacinitaly HappyGuru Lovin2Help Vista Guru Oct 7, 2010 #6 did you reboot? otherwise, very sorry. maybe the real well versed gurus can give better advice good luck PS don't forget to check a previous restore point!!!! My Computer System One Manufacturer/Model gateway/m6881 CPU centrino core 2 duo 2.2ghz T7500 Memory 3GB Hard Drives 500GB WD Mouse logitech Internet Speed fios 35MB not!!!!
W WhoYouWith Member Oct 7, 2010 #7 yes many times rebooted ... thanks for ur help My Computer System One
pacinitaly HappyGuru Lovin2Help Vista Guru Oct 7, 2010 #8 try this too, maybe other files have been deleted or missing and can be reclaimed. Recuva - Undelete, Unerase, File and Disk Recovery - Free Download My Computer System One Manufacturer/Model gateway/m6881 CPU centrino core 2 duo 2.2ghz T7500 Memory 3GB Hard Drives 500GB WD Mouse logitech Internet Speed fios 35MB not!!!!
W WhoYouWith Member Oct 7, 2010 #9 will do , just scanning now ill let you no what happens My Computer System One
pacinitaly HappyGuru Lovin2Help Vista Guru Oct 7, 2010 #11 damn My Computer System One Manufacturer/Model gateway/m6881 CPU centrino core 2 duo 2.2ghz T7500 Memory 3GB Hard Drives 500GB WD Mouse logitech Internet Speed fios 35MB not!!!!
W WhoYouWith Member Oct 7, 2010 #12 i might just system restore .... but i got so much stuff i don want to lose ... My Computer System One
pacinitaly HappyGuru Lovin2Help Vista Guru Oct 7, 2010 #13 if the stuff is moveable, put on a flash drive or external HDD or CD/DVD first. My Computer System One Manufacturer/Model gateway/m6881 CPU centrino core 2 duo 2.2ghz T7500 Memory 3GB Hard Drives 500GB WD Mouse logitech Internet Speed fios 35MB not!!!!
