Solved Vista won't reboot - ATI 4379 Serial ATA Controller problem
02befree
Happened after a Windows Update.....Acer Aspire 5100 Notebook w/ Vista Home Premium 32-bit
After the update I restarted and then a windows says Found New Hardware window with the option of installing, doing it later or don't ask me again. If I try to install I get the message:
Windows encountered a problem installing eh driver software for your device
Windows encountered an error while attempting to install it
The name is already in use as either a service name or a service display name.
When I restart it won't boot, if I go into Startup Repair it won't repair.
I can hit F8 and select Last Good Configuration.. and that will boot me into Vista and the same thing happens again. Found New Hardware...
When the Found New Hardware window appears another window appears that says:
Microsoft Windows window appears with "You must restart your computer to apply these changes"
I've done the loop several times, read numerous posts on using a Vista CD to boot to , etc. and have tried everything I've read but have had no luck.
I would like to delete something here, but not sure what. Found a post talking about deleting a pending .xml file or something like that, but I only found some very old ones from a year ago, so not sure they are the culprit. Maybe I should delete them anyway...
Re: Vista ATI
Do a system restore back to before the update.
You might have had a bad update.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Re: Vista ATI
I tried that, for some reason I only have a system restore point for yesterday :(
I show an unknown device, which I assume is the ATI SATA Controller. I'm sure there's something I can delete to tame this beast.
Re: Vista ATI
Go get the drivers from the manufactuer.
SOLVED: Vista won't reboot - ATI 4379 Serial ATA Controller problem
Downloading some ATI drivers from the Acer site didn't help.
Got this from another post.
Go to the Silicon image support website: http://www.siliconimage.com/support/...x?pid=0&cid=0&
download the appropriate DRIVER (not bios) for whatever your computer has - SiI3112 for Non-Raid 2 port SATA 150 controllers worked for me.
Unzip the driver file into a directory.
Go to device manager and "update drivers" for the problem component - on mine it showed Unknown Device. Go to "have disk" and point the browser to the folder with the .inf file for the component. Update the drivers and reboot.
My computer works fine now.
Thanks for the update
Glad you got it fixed.
