Save to Flash Drive? Help!!!!!
neb
I have Vista Home Basic. I want to back up the contents of my D (Data) Drive. I have never done this b4 but feel comfortable with the process. I have been looking for the option of WHERE want to save the file to (which would be Flash Drive), but cannot find one- a screen comes up saying (by default?) that it will be saved to another drive. A couple of years ago I experimented trying to save files--maybe this is why D drive is coming up as to where to Save to. Help!!! Thank you in advance.
Is there a "browse" button/tab in the window?
    Advent
    AMD Phenom X4 9550 2.8Ghz
    FOXCONN A6VMX (Socket 940)
    4.0GB RAM
    256MB On-board ATI Radeon X1200 Series
    UnKnown
    19" TFT Mointor
    1400 by 900
    500GB Western Digital WDC
    HP Keyboard
    Mobile Broadband via Vodafone
    250GB External Hard-drive
Well when you insert your flash drive you normally get the message what do you want to do with this drive, View files, play with WMP, View pictures etc, you could forget that if you want to.
You goto your D: drive and select the files/folders you want to copy to your flash drive then right-click on the files and select Send To then flash drives drive letter should be shown on there.
    Windows 10 Home 64-bit
    DELL Inspiron 3793 17"
    Intel Core i5 1035G7
    Dell Inc. 0C9WH2
    8.00GB
    Intel UHD Graphics (Dell) 2047MB NVIDIA GeForce MX230 (Dell)
    Realtek Audio
    Generic PnP Monitor
    1920x1080 (Highest 32bit Colour)
    119GB NVMe SSSTC 128GB (RAID (SSD)) SHIT 931GB Seagate SATA
    DELL SHIT INBUILD BATTERY
    Touchpad, USB remote Mouse
    DVD: HL-DT-ST DVD+-RW GU90N
