Vista Operating System Control Issue -- HELP!
I'm having a horrible time with Vista 32-bit Home Version.
No matter what I do, I can't seem to gain access to system folders I need access to. I've used my authority as administrator to try to check off the right boxes, but Vista is constantly struggling with me over which one of us has control over the folders.
For example, I need to copy .pst files to my Microsoft Office 2003 Outlook folders. My file explorer finds the right folder, but then I can't access it, even though I've checked off all the boxes making invisible folders visible. The folders still aren't accessible.
One reason I use Microsoft system software over Mac is that Mac was always struggling with me over who got to make the decisions. Now I'm having the same problem with Vista.
Can anyone help?
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
gosh i hate vista. YEP even if you are an administrator account you cant hardly do nothing. BUT microsoft has a hidden account which will let you delete anything... BUT i forgot how to do it. BTW when i say anything i mean all the ****ty system crap which keeps getting denied. RESAULTS MAY VARY.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
In the Tutorials there's an article how to set up the hidden Administrator account. I did it on my system, although luckily I never really have to use it. I think it still has that picture of a farm or something for wallpaper. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
I saw the one on taking ownership and it did nothing for my problems. If I can find the hidden administrator answer, that's the one I'd like to try. On a hunch, I did a Google search and found:
Hidden Administrator Account
Now to see if it works.
Bill Gates, if you're out there, why did you give us a system like the Mac? If I wanted my Operating System to be in total control, I would'a bought a Mac.
Nah, it didn't work. I have only one account and it's my user account, and I have full administrator rights. I just don't seem to be able to delete some folders and files, regardless of how I change them and establish controls. Can anyone help?
You should see the tutorial for setting up the administrator account that's on this site. Look in Tutorials forum.
If you still can't delete files I'd scan for malware. I had a registry hack stuck on my system that would not let me delete anything even using Unlocker and "delete on next boot" type utilities. Malware bytes antimalware cleaned it right off.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Agreed. Something isn't right. I've always been the only user on my pc, and even after formatting 2 times over the last year and a half, I can still do anything I want. Never had a problem with accessing anything at all.
Although, mine is a Retail full version, on a self built pc......not sure if that would make a big difference or not. I don't use branded pc's at all.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless LX310
    Logitech Wireless
    18/2 cable
