O/S will not fully install... please help.
rizonn
I just did a fresh pc build all new parts and is put together correct, and I put in my O/S boot disk and it goes through the loading files but when it gets to the "starting windows" and the next screen should be "license agreement" the screen just goes black. I tried the same disk in another pc and acted like i was booting from it and it went to the install perfectly. Not sure what the issue could be. If anyone has experienced this please let me know.
-Build-
CPU: i7 930 bloomfield
Mobo: EVGA e758-a1 3way sli
GPU: EVGA gtx 470
CD-ROM: Lite on Blueray/Dvd-rw/dvd-rom/cd-rw/cd-w
Ram: CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)Hard drive: SAMSUNG Spinpoint F3 HD103SJ 1TB
Powersupply: COOLER MASTER GX Series RS750-ACAAE3-US 750W ATX12V v2.31
Case: COOLER MASTER HAF 932
Monitor: SAMSUNG EX2220X Glossy Black 21.5" 5ms LED Backlight LCD Monitor
maybe broken DVD drive?
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
1) Try with 2gm of Ram.
2) If you have onboard video, remove video card.
Research I have done for you points to this being the best answer.
Your bios may have the option to automatically detect the video card and should be set to auto.
If the option is not there remove the card.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
