Ok need help in understanding why
ohsocute69
this is bugging me bad , the only things on desktop running is , yahoo pool and msn
should this graph be reading this high on task manager (gb) im refering too
number 2 problem , i have noticed all the numbers on this second graph are lower than say 100,000 , but there are like 5 java applications on here and 4 of these are very high is this normal and what do they run ??
should there only be like 1 java ??
virus? have you run a scan recently?
    AMD/GIGABYTE
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
    Gigabyte GA-M57SLI-S4 (rev. 2.0)
    2048MB RAM
    NVIDIA GeForce 8600 GT
    SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
    1680 by 1050 pixels
    Seagate ST310003 40AS SCSI Disk Device Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Optiarc DVD RW AD-7191S SCSI CdRom Device
yes virus has been run by malware, im more looking at , the scale of java why would they be so high ?? is this normal ,
and trying to work out why in the very first picture , the (gb) is high or is it ?? i think it is i cant work out what is going on
well what i meant was that doesnt look normal so it may be a virus, did u do i virus scan or malwarebytes scan.
heres what i got playing yahoo pool
or you can try, uninstalling JAVA and then do a reboot and reinstall it, maybe u downloaded a wrong version.
http://www.java.com/en/download/help/uninstall_java.xml
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
How do I uninstall Java on my Windows computer ?
yes i did a full scan with malwarebites, but hasnt picked up anything,
the only java i have in controll panell now is, (as there was another one there back from 2008 , which i just now deleted .
this is the one in there now java (tm) 6 update 20 sun microsystems inc...
is there any other way of finding out if i have a virus at all ?? so you do think that the first graph up the top is rather high ?? in the first picture ??
does not look normal, but i know nothing about java, so i just figured it was a virus
try uninstalling and reinstall
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
You have two games running and IE open to this forum. Close all those programs and look at Taskmanager again with nothing running. Eldinv ran Yahoo pool and also had a Java process running. Close ALL the running programs and copy paste the results back here like you did before.
ok here is 3 photos with no windows open ,
from the graph to the processors , i still dnt understand why the gb is high ??
OK, first off, there's a lot of processes running. You have plenty of memory, and the 1.33 - 1.8 GB of memory that your PC is using doesn't seem too bad, based on all of the processes. The more memory you have, the more it will try to use.
I have 2GB total and mine uses upwards of 650MB to 1GB depending on what I'm doing.
The columns where you have the taskmgr.exe circled is just how much of the processor power that the particular thing is using at the moment, so I don't see an issue with that. Nothing in that column really has anything to do with the GB of memory used.
But just keep in mind, the more running processes that you have, the more memory it will try to use. The Java thing, I don't know much about, but running a few of them at once will raise that number substantially. The games on webpages ( like the Pool games) use Java.
Like, right now, my browser is using roughly 90,000. I opened 5 more webpages in new tabs, and it raised it to over 130,000, which in turn raises my memory usage (like your 1.33GB).
EDIT: Opening my fantasy baseball page, which uses Java also, is using around the same amount as yours....around 100,000.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless LX310
    Logitech Wireless
    18/2 cable
