Sorry not very technical but need help
akkittiekat
so i just got my computer working again and i can't remember the password i made as the admin and i never made a backup...i know there is a way to go back to a date through the F12 key or tab key but i don't remember what its under there. i am using windows vista. if anyone knows anything that will help please let me know.
Hello akkittiekat, and welcome to Vista Forums.
It sounds like you are thinking of "System Restore". It can be accessed with a Vista Install DVD, a repair CD, or the reserved system partition at boot up. It is possible to restore to a point before you created the Admin password, or to a password you remember.
Here are some tutorials to show you how to use "System Restore" in different ways:
http://www.vistax64.com/tutorials/194765-system-recovery-options.html
http://www.vistax64.com/tutorials/67567-administrator-account.html
http://www.vistax64.com/tutorials/102005-reset-user-account-password.html
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
You referred to the Admin password, is this the Admin account created during installation, or the "Hidden Default Administrator" account? This tutorial shows how to enable the Default Hidden Administrator account when there is no other account with Admin privileges available. Once you have enabled this account, you can use it to change the password to your Admin account.
http://www.vistax64.com/tutorials/200888-user-account-password-change-win-re.html
Cheers!
Robert
F8 on my computer restart and start tapping it before windows loads.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
