I had a hard drive crash 2 weeks after the warranty on my HP Elite Pavilion Desktop ran out in September last year. I replaced the hard drive with a WD 1 TB (was a Seagate I think 500GB). Now, 9 months later the new hard drive is acting up. I do not have extensive technical computer experience, but I did run the diagnostics on it (the one that came with HP - PC Doctor or similar) and got "Passed" on the hard drive on one occasion and "Failed" on another. I decided to just use the CDs to do a complete restore to factory settings. I am running Windows Home Premiums Vista 64 bit, I believe.
Anyway, I have gotten through the process twice now but the computer seems to get hung up after it says the reset is complete using the discs I ordered from HP. When it reboots, it goes through the normal blue screen, then Windows green bar thingy, and then it gets to and stays on a white screen with two folder icons with a little sheet of paper "flying over" from one to the next. It seems to stay here forever. The first time, I turned off the PC after several hours and when I turned it back on, it said BOOTMGR was missing. I have just done it the second time and am wondering how long I should let it stay on while on this white screen with the two folders before I give up again.
Hope this makes sense and that I am providing enough information to receive some assistance!
Thanks,
Kelli
Thanks,
Kelli
- HP Pavilion Elite m9300t PC with TV/PVR
- - Intel(R) Core(TM) 2 Quad processor Q6700 (2.66GHz)
- 4GB DDR2-800MHz dual channel SDRAM (4x1024)
- 256MB NVIDIA GeForce 9300, DVI-I, VGA adapter,HDMI
- Integrated 7.1 channel sound w/ front audio ports
- WD Caviar Green 1 TB (upgraded from OEM of 500GB 7200 rpm SATA 3Gb/s hard drive that crashed 2 weeks after 1 yr warranty expired)
