I did it a while ago, but I have completely forgotten how to do it? Perhaps somebody could enlighten me?
To be more precise, I recently installed the K-Lite codec pack, and it has added an option on my right click menu, which is displayed when right clicking on any file, called "Media Info". This is quite annoying because I don't use the program often enough for it to be on my right click menu. So I would like that to be deleted.
I would also like to add an option to my right click menu that is displayed with any file called, "Scan with Spybot - Search & Destroy". And this should obviously scan with spybot. The directory for Spybot is the default:
C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
Preferably, it should have the spybot logo next to the scan option, but I don't know whether this is asking alot.
Thanks in advance for any comments
- Build #1
- Intel Core i7 3770K @4.4GHz
- ASUS P8Z77-V PRO
- Corsair Vengeance 2x4GB DDR3 1600MHz Low Profile (White)
- Gigabyte Radeon HD 7850 (2GB GDDR5)
- Integrated on motherboard
- 23" LG LCD/LED IPS
- 1920*1080
- Samsung EVO 128GB SSD Seagate Barracuda 2TB 7200rpm 2x500GB Seagate FreeAgent 5400rpm
- PSU
- Corsair TX650W V2 (80+ Bronze)
- Case
- NZXT Phantom 410
- Cooling
- Corsair H100 Water Cooler, 1x140mm and 1x120mm stock fans
- Microsoft Desktop 2000 Wireless Mouse
- Microsoft Desktop 2000 Wireless Keyboard
- 95 Mb/s Download 70 Mb/s Upload
