steelfallen
Ok I recently encountered a problem where whatever application im using seems to randonaly exit its use. I dont mean the program crashes more like someone is constantly hitting Alt Tab. It took me 15 minutes just to write this because I had to keep clicking on the text box.
I didn't notice the problem this morning but then my mother had someone work on my pc installing a USB wireless adapter (pissed she didn't just ask me to do it) and when i went to use it later in the day i started having the problem.
Now it cant be that Alt Tab are stuck since when I run a full screen application i have no problems like a game or something. It seems to be localized to the desktop. Any ap be it a simple notepad to firefox encounters the problem. I have checked the wires and nothing seems to be loose and I also tried preforming a system restore to a date before I had the problem and that didn't do it either.
It could be a virus but if it is Comodo Antivirus didnt pick up anything through a startup scan so any advice would be appriecated.
I have tried MSconfig checking for any new startup programs but no luck in that department.
I uninstalled comodo antivirus and super anti spyware and shifted to norton and spybot s&d and problem went away but neither progran actually found anything in addition to running a malwarebytes anti mailware but that didn't find anything. but now its back and worse then ever. Please someone out there tell me what the hell is going on. I have exhausted my solutions outside wiping the harddrive and starting over.
I know its not a keyboard issue because i have swapped keyboards and the problem still persisted. Mouse on the other hand could be a possibility
System Specs
Model X1200
Proccessor Althon 64 Duel Core 5000 2.6 ghz
4 gigs ram
Windows Vista Home Premium Sp2 64bit
Mouse Razor Diamond BackK
Keyboard: Logitech cant remenber model
System Specs
Model X1200
4 gigs ram
