32 bit programs with problems with Open/Save As
lcastilloe
I have Windows Vista 64 and after installing a printer driver and a Twitter client (which later I uninstalled), ALL programs 32 bit-based could not do Open/Save As, clicking on then will not do any action and will not show any error message. Also, the hotmail attachement command Save Target As (using IE) shows an error message "Internet Explorer can not download. Interface not compatible".
If I open IE 64 and Office 2003 it will work correctly in the File Open/Save As commands...
Looks like a comdlg32.dll or the registry is corrupted / damaged...
Any experience like this? Please help...
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    NVIDIA GeForce 9600M GT
    16"
    1920x1080
    300 GB
Hello,
Can you please press the Windows Key + R to open the Run dialogue. Type cmd and press enter. Go past the UAC prompt if necessary. Type sfc /scannow noting the space and let the scan run. It will take about 15 minutes. If integrity violations are found, parse and upload the log files. See the top yellow box here on how to parse the logs files: http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html and then upload/paste inline if you really cannot upload sfcdetails.txt from your Desktop.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello Richard, I have got two CBS logs from two runs, one normal and one from safe mode but they are too long, you want me to send you this by email?
I really can not understand very well what the contents means...
Thanks in advance...
Luis
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
Hello Luis,
Do not worry about the contents. I will work out what they mean and give you fixing instructions if anything is out of place. Now that you have got those logs, either attach them to your next post if you know how, or follow these instructions:
Press the Windows Key + R to open the Run dialogue. Type cmd and press enter. Then copy and paste in
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >%userprofile%\Desktop\sfcdetails.txt
and press enter. When it has run (less than 1 second) a new file sfcdetails.txt will have been created on your Desktop. Open this using double click, and then copy and paste the entire contents into your next post (this one will not be too long) or attach it if you know how.
Good luck!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Richard,
See below text from SCF...
Thanks.
Code:
2010-05-27 16:12:05, Info CSI 00000006 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:05, Info CSI 00000007 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:08, Info CSI 00000009 [SR] Verify complete
2010-05-27 16:12:09, Info CSI 0000000a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:09, Info CSI 0000000b [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:11, Info CSI 0000000d [SR] Verify complete
2010-05-27 16:12:12, Info CSI 0000000e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:12, Info CSI 0000000f [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:14, Info CSI 00000011 [SR] Verify complete
2010-05-27 16:12:15, Info CSI 00000012 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:15, Info CSI 00000013 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:18, Info CSI 00000015 [SR] Verify complete
2010-05-27 16:12:19, Info CSI 00000016 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:19, Info CSI 00000017 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:21, Info CSI 00000019 [SR] Verify complete
2010-05-27 16:12:22, Info CSI 0000001a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:22, Info CSI 0000001b [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:25, Info CSI 0000001d [SR] Verify complete
2010-05-27 16:12:25, Info CSI 0000001e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:25, Info CSI 0000001f [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:28, Info CSI 00000021 [SR] Verify complete
2010-05-27 16:12:28, Info CSI 00000022 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:28, Info CSI 00000023 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:30, Info CSI 00000025 [SR] Verify complete
2010-05-27 16:12:31, Info CSI 00000026 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:31, Info CSI 00000027 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:33, Info CSI 00000029 [SR] Verify complete
2010-05-27 16:12:34, Info CSI 0000002a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:34, Info CSI 0000002b [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:36, Info CSI 0000002d [SR] Verify complete
2010-05-27 16:12:36, Info CSI 0000002e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:36, Info CSI 0000002f [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:39, Info CSI 00000031 [SR] Verify complete
2010-05-27 16:12:39, Info CSI 00000032 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:39, Info CSI 00000033 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:42, Info CSI 00000035 [SR] Verify complete
2010-05-27 16:12:42, Info CSI 00000036 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:42, Info CSI 00000037 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:45, Info CSI 00000039 [SR] Verify complete
2010-05-27 16:12:45, Info CSI 0000003a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:45, Info CSI 0000003b [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:47, Info CSI 0000003d [SR] Verify complete
2010-05-27 16:12:48, Info CSI 0000003e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:48, Info CSI 0000003f [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:50, Info CSI 00000041 [SR] Verify complete
2010-05-27 16:12:50, Info CSI 00000042 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:50, Info CSI 00000043 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:53, Info CSI 00000045 [SR] Verify complete
2010-05-27 16:12:54, Info CSI 00000046 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:54, Info CSI 00000047 [SR] Beginning Verify and Repair transaction
2010-05-27 16:12:57, Info CSI 00000049 [SR] Verify complete
2010-05-27 16:12:58, Info CSI 0000004a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:12:58, Info CSI 0000004b [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:00, Info CSI 0000004d [SR] Verify complete
2010-05-27 16:13:00, Info CSI 0000004e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:00, Info CSI 0000004f [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:03, Info CSI 00000051 [SR] Verify complete
2010-05-27 16:13:04, Info CSI 00000052 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:04, Info CSI 00000053 [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:07, Info CSI 00000055 [SR] Verify complete
2010-05-27 16:13:07, Info CSI 00000056 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:07, Info CSI 00000057 [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:09, Info CSI 00000059 [SR] Verify complete
2010-05-27 16:13:09, Info CSI 0000005a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:09, Info CSI 0000005b [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:14, Info CSI 0000005d [SR] Verify complete
2010-05-27 16:13:14, Info CSI 0000005e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:14, Info CSI 0000005f [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:16, Info CSI 00000061 [SR] Verify complete
2010-05-27 16:13:16, Info CSI 00000062 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:16, Info CSI 00000063 [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:19, Info CSI 00000065 [SR] Verify complete
2010-05-27 16:13:19, Info CSI 00000066 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:19, Info CSI 00000067 [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:22, Info CSI 00000069 [SR] Verify complete
2010-05-27 16:13:22, Info CSI 0000006a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:22, Info CSI 0000006b [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:31, Info CSI 0000006d [SR] Verify complete
2010-05-27 16:13:31, Info CSI 0000006e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:31, Info CSI 0000006f [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:37, Info CSI 00000072 [SR] Verify complete
2010-05-27 16:13:37, Info CSI 00000073 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:37, Info CSI 00000074 [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:45, Info CSI 00000078 [SR] Verify complete
2010-05-27 16:13:45, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:45, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2010-05-27 16:13:52, Info CSI 0000007e [SR] Verify complete
2010-05-27 16:13:52, Info CSI 0000007f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:13:52, Info CSI 00000080 [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:01, Info CSI 00000082 [SR] Verify complete
2010-05-27 16:14:01, Info CSI 00000083 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:01, Info CSI 00000084 [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:09, Info CSI 00000092 [SR] Verify complete
2010-05-27 16:14:10, Info CSI 00000093 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:10, Info CSI 00000094 [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:20, Info CSI 000000ad [SR] Verify complete
2010-05-27 16:14:20, Info CSI 000000ae [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:20, Info CSI 000000af [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:28, Info CSI 000000b1 [SR] Verify complete
2010-05-27 16:14:29, Info CSI 000000b2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:29, Info CSI 000000b3 [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:34, Info CSI 000000b5 [SR] Verify complete
2010-05-27 16:14:35, Info CSI 000000b6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:35, Info CSI 000000b7 [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:44, Info CSI 000000b9 [SR] Verify complete
2010-05-27 16:14:45, Info CSI 000000ba [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:45, Info CSI 000000bb [SR] Beginning Verify and Repair transaction
2010-05-27 16:14:54, Info CSI 000000bd [SR] Verify complete
2010-05-27 16:14:54, Info CSI 000000be [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:14:54, Info CSI 000000bf [SR] Beginning Verify and Repair transaction
2010-05-27 16:15:07, Info CSI 000000d7 [SR] Verify complete
2010-05-27 16:15:07, Info CSI 000000d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:15:07, Info CSI 000000d9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:15:24, Info CSI 000000db [SR] Verify complete
2010-05-27 16:15:24, Info CSI 000000dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:15:24, Info CSI 000000dd [SR] Beginning Verify and Repair transaction
2010-05-27 16:15:40, Info CSI 000000df [SR] Verify complete
2010-05-27 16:15:40, Info CSI 000000e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:15:40, Info CSI 000000e1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:15:44, Info CSI 000000e3 [SR] Verify complete
2010-05-27 16:15:45, Info CSI 000000e4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:15:45, Info CSI 000000e5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:15:48, Info CSI 000000e7 [SR] Verify complete
2010-05-27 16:15:48, Info CSI 000000e8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:15:48, Info CSI 000000e9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:15:52, Info CSI 000000eb [SR] Verify complete
2010-05-27 16:15:53, Info CSI 000000ec [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:15:53, Info CSI 000000ed [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:08, Info CSI 00000100 [SR] Verify complete
2010-05-27 16:16:08, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:08, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:10, Info CSI 00000104 [SR] Verify complete
2010-05-27 16:16:10, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:10, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:15, Info CSI 00000108 [SR] Verify complete
2010-05-27 16:16:16, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:16, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:21, Info CSI 0000010c [SR] Verify complete
2010-05-27 16:16:21, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:21, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:32, Info CSI 00000110 [SR] Verify complete
2010-05-27 16:16:33, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:33, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:41, Info CSI 00000114 [SR] Verify complete
2010-05-27 16:16:41, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:41, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2010-05-27 16:16:45, Info CSI 00000118 [SR] Verify complete
2010-05-27 16:16:45, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:16:45, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2010-05-27 16:17:03, Info CSI 0000011c [SR] Verify complete
2010-05-27 16:17:03, Info CSI 0000011d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:17:03, Info CSI 0000011e [SR] Beginning Verify and Repair transaction
2010-05-27 16:17:10, Info CSI 00000120 [SR] Verify complete
2010-05-27 16:17:11, Info CSI 00000121 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:17:11, Info CSI 00000122 [SR] Beginning Verify and Repair transaction
2010-05-27 16:17:24, Info CSI 00000135 [SR] Verify complete
2010-05-27 16:17:24, Info CSI 00000136 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:17:24, Info CSI 00000137 [SR] Beginning Verify and Repair transaction
2010-05-27 16:17:37, Info CSI 0000013e [SR] Verify complete
2010-05-27 16:17:37, Info CSI 0000013f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:17:37, Info CSI 00000140 [SR] Beginning Verify and Repair transaction
2010-05-27 16:18:05, Info CSI 00000142 [SR] Verify complete
2010-05-27 16:18:05, Info CSI 00000143 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:18:05, Info CSI 00000144 [SR] Beginning Verify and Repair transaction
2010-05-27 16:18:21, Info CSI 00000146 [SR] Verify complete
2010-05-27 16:18:22, Info CSI 00000147 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:18:22, Info CSI 00000148 [SR] Beginning Verify and Repair transaction
2010-05-27 16:18:33, Info CSI 0000014a [SR] Verify complete
2010-05-27 16:18:33, Info CSI 0000014b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:18:33, Info CSI 0000014c [SR] Beginning Verify and Repair transaction
2010-05-27 16:18:44, Info CSI 0000014e [SR] Verify complete
2010-05-27 16:18:45, Info CSI 0000014f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:18:45, Info CSI 00000150 [SR] Beginning Verify and Repair transaction
2010-05-27 16:18:53, Info CSI 00000152 [SR] Verify complete
2010-05-27 16:18:53, Info CSI 00000153 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:18:53, Info CSI 00000154 [SR] Beginning Verify and Repair transaction
2010-05-27 16:19:03, Info CSI 00000158 [SR] Verify complete
2010-05-27 16:19:03, Info CSI 00000159 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:19:03, Info CSI 0000015a [SR] Beginning Verify and Repair transaction
2010-05-27 16:19:15, Info CSI 0000015c [SR] Verify complete
2010-05-27 16:19:16, Info CSI 0000015d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:19:16, Info CSI 0000015e [SR] Beginning Verify and Repair transaction
2010-05-27 16:19:26, Info CSI 00000160 [SR] Verify complete
2010-05-27 16:19:26, Info CSI 00000161 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:19:26, Info CSI 00000162 [SR] Beginning Verify and Repair transaction
2010-05-27 16:19:36, Info CSI 00000164 [SR] Verify complete
2010-05-27 16:19:36, Info CSI 00000165 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:19:36, Info CSI 00000166 [SR] Beginning Verify and Repair transaction
2010-05-27 16:19:47, Info CSI 00000168 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:19:49, Info CSI 0000016a [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:19:49, Info CSI 0000016b [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:19:50, Info CSI 0000016d [SR] Verify complete
2010-05-27 16:19:50, Info CSI 0000016e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:19:50, Info CSI 0000016f [SR] Beginning Verify and Repair transaction
2010-05-27 16:20:00, Info CSI 00000171 [SR] Verify complete
2010-05-27 16:20:00, Info CSI 00000172 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:20:00, Info CSI 00000173 [SR] Beginning Verify and Repair transaction
2010-05-27 16:20:11, Info CSI 00000175 [SR] Verify complete
2010-05-27 16:20:13, Info CSI 00000176 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:20:13, Info CSI 00000177 [SR] Beginning Verify and Repair transaction
2010-05-27 16:20:27, Info CSI 0000017a [SR] Verify complete
2010-05-27 16:20:27, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:20:27, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2010-05-27 16:20:46, Info CSI 0000017e [SR] Verify complete
2010-05-27 16:20:47, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:20:47, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2010-05-27 16:20:56, Info CSI 00000183 [SR] Verify complete
2010-05-27 16:20:56, Info CSI 00000184 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:20:56, Info CSI 00000185 [SR] Beginning Verify and Repair transaction
2010-05-27 16:21:17, Info CSI 00000189 [SR] Verify complete
2010-05-27 16:21:17, Info CSI 0000018a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:21:17, Info CSI 0000018b [SR] Beginning Verify and Repair transaction
2010-05-27 16:21:26, Info CSI 0000018f [SR] Verify complete
2010-05-27 16:21:26, Info CSI 00000190 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:21:26, Info CSI 00000191 [SR] Beginning Verify and Repair transaction
2010-05-27 16:21:39, Info CSI 00000193 [SR] Verify complete
2010-05-27 16:21:39, Info CSI 00000194 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:21:39, Info CSI 00000195 [SR] Beginning Verify and Repair transaction
2010-05-27 16:21:54, Info CSI 00000197 [SR] Verify complete
2010-05-27 16:21:54, Info CSI 00000198 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:21:54, Info CSI 00000199 [SR] Beginning Verify and Repair transaction
2010-05-27 16:21:58, Info CSI 0000019b [SR] Verify complete
2010-05-27 16:21:58, Info CSI 0000019c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:21:58, Info CSI 0000019d [SR] Beginning Verify and Repair transaction
2010-05-27 16:22:07, Info CSI 0000019f [SR] Verify complete
2010-05-27 16:22:07, Info CSI 000001a0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:22:07, Info CSI 000001a1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:22:21, Info CSI 000001a3 [SR] Verify complete
2010-05-27 16:22:22, Info CSI 000001a4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:22:22, Info CSI 000001a5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:22:37, Info CSI 000001a7 [SR] Verify complete
2010-05-27 16:22:38, Info CSI 000001a8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:22:38, Info CSI 000001a9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:22:49, Info CSI 000001ab [SR] Verify complete
2010-05-27 16:22:49, Info CSI 000001ac [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:22:49, Info CSI 000001ad [SR] Beginning Verify and Repair transaction
2010-05-27 16:23:11, Info CSI 000001af [SR] Verify complete
2010-05-27 16:23:11, Info CSI 000001b0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:23:11, Info CSI 000001b1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:23:20, Info CSI 000001b3 [SR] Verify complete
2010-05-27 16:23:20, Info CSI 000001b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:23:20, Info CSI 000001b5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:23:34, Info CSI 000001c0 [SR] Verify complete
2010-05-27 16:23:34, Info CSI 000001c1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:23:34, Info CSI 000001c2 [SR] Beginning Verify and Repair transaction
2010-05-27 16:23:44, Info CSI 000001c4 [SR] Verify complete
2010-05-27 16:23:44, Info CSI 000001c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:23:44, Info CSI 000001c6 [SR] Beginning Verify and Repair transaction
2010-05-27 16:23:57, Info CSI 000001c8 [SR] Verify complete
2010-05-27 16:23:59, Info CSI 000001c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:23:59, Info CSI 000001ca [SR] Beginning Verify and Repair transaction
2010-05-27 16:24:16, Info CSI 000001cc [SR] Verify complete
2010-05-27 16:24:16, Info CSI 000001cd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:24:16, Info CSI 000001ce [SR] Beginning Verify and Repair transaction
2010-05-27 16:24:38, Info CSI 000001d0 [SR] Verify complete
2010-05-27 16:24:39, Info CSI 000001d1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:24:39, Info CSI 000001d2 [SR] Beginning Verify and Repair transaction
2010-05-27 16:24:42, Info CSI 000001d4 [SR] Verify complete
2010-05-27 16:24:42, Info CSI 000001d5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:24:42, Info CSI 000001d6 [SR] Beginning Verify and Repair transaction
2010-05-27 16:24:47, Info CSI 000001d9 [SR] Verify complete
2010-05-27 16:24:48, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:24:48, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2010-05-27 16:25:03, Info CSI 000001e1 [SR] Verify complete
2010-05-27 16:25:04, Info CSI 000001e2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:25:04, Info CSI 000001e3 [SR] Beginning Verify and Repair transaction
2010-05-27 16:25:10, Info CSI 000001e5 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:25:20, Info CSI 000001e9 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:25:20, Info CSI 000001ea [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:25:23, Info CSI 000001f0 [SR] Verify complete
2010-05-27 16:25:24, Info CSI 000001f1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:25:24, Info CSI 000001f2 [SR] Beginning Verify and Repair transaction
2010-05-27 16:25:39, Info CSI 000001fe [SR] Verify complete
2010-05-27 16:25:39, Info CSI 000001ff [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:25:39, Info CSI 00000200 [SR] Beginning Verify and Repair transaction
2010-05-27 16:25:46, Info CSI 00000202 [SR] Verify complete
2010-05-27 16:25:47, Info CSI 00000203 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:25:47, Info CSI 00000204 [SR] Beginning Verify and Repair transaction
2010-05-27 16:25:54, Info CSI 00000206 [SR] Verify complete
2010-05-27 16:25:54, Info CSI 00000207 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:25:54, Info CSI 00000208 [SR] Beginning Verify and Repair transaction
2010-05-27 16:26:02, Info CSI 0000020d [SR] Verify complete
2010-05-27 16:26:03, Info CSI 0000020e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:26:03, Info CSI 0000020f [SR] Beginning Verify and Repair transaction
2010-05-27 16:26:11, Info CSI 00000225 [SR] Verify complete
2010-05-27 16:26:11, Info CSI 00000226 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:26:11, Info CSI 00000227 [SR] Beginning Verify and Repair transaction
2010-05-27 16:26:20, Info CSI 00000238 [SR] Verify complete
2010-05-27 16:26:20, Info CSI 00000239 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:26:20, Info CSI 0000023a [SR] Beginning Verify and Repair transaction
2010-05-27 16:26:28, Info CSI 0000023c [SR] Verify complete
2010-05-27 16:26:28, Info CSI 0000023d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:26:28, Info CSI 0000023e [SR] Beginning Verify and Repair transaction
2010-05-27 16:26:36, Info CSI 00000240 [SR] Verify complete
2010-05-27 16:26:37, Info CSI 00000241 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:26:37, Info CSI 00000242 [SR] Beginning Verify and Repair transaction
2010-05-27 16:26:47, Info CSI 00000253 [SR] Verify complete
2010-05-27 16:26:47, Info CSI 00000254 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:26:47, Info CSI 00000255 [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:03, Info CSI 00000257 [SR] Verify complete
2010-05-27 16:27:03, Info CSI 00000258 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:03, Info CSI 00000259 [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:13, Info CSI 00000267 [SR] Verify complete
2010-05-27 16:27:13, Info CSI 00000268 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:13, Info CSI 00000269 [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:16, Info CSI 0000026b [SR] Verify complete
2010-05-27 16:27:17, Info CSI 0000026c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:17, Info CSI 0000026d [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:29, Info CSI 00000270 [SR] Verify complete
2010-05-27 16:27:29, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:29, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:37, Info CSI 00000274 [SR] Verify complete
2010-05-27 16:27:37, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:37, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:47, Info CSI 00000278 [SR] Verify complete
2010-05-27 16:27:47, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:47, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2010-05-27 16:27:54, Info CSI 0000027c [SR] Verify complete
2010-05-27 16:27:55, Info CSI 0000027d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:27:55, Info CSI 0000027e [SR] Beginning Verify and Repair transaction
2010-05-27 16:28:05, Info CSI 00000282 [SR] Verify complete
2010-05-27 16:28:06, Info CSI 00000283 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:28:06, Info CSI 00000284 [SR] Beginning Verify and Repair transaction
2010-05-27 16:28:16, Info CSI 0000029e [SR] Verify complete
2010-05-27 16:28:17, Info CSI 0000029f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:28:17, Info CSI 000002a0 [SR] Beginning Verify and Repair transaction
2010-05-27 16:28:49, Info CSI 000002a2 [SR] Verify complete
2010-05-27 16:28:50, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:28:50, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
2010-05-27 16:28:58, Info CSI 000002a6 [SR] Verify complete
2010-05-27 16:28:59, Info CSI 000002a7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:28:59, Info CSI 000002a8 [SR] Beginning Verify and Repair transaction
2010-05-27 16:29:09, Info CSI 000002aa [SR] Verify complete
2010-05-27 16:29:09, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:29:09, Info CSI 000002ac [SR] Beginning Verify and Repair transaction
2010-05-27 16:29:18, Info CSI 000002ae [SR] Verify complete
2010-05-27 16:29:19, Info CSI 000002af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:29:19, Info CSI 000002b0 [SR] Beginning Verify and Repair transaction
2010-05-27 16:29:30, Info CSI 000002b3 [SR] Verify complete
2010-05-27 16:29:30, Info CSI 000002b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:29:30, Info CSI 000002b5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:29:42, Info CSI 000002b7 [SR] Verify complete
2010-05-27 16:29:42, Info CSI 000002b8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:29:42, Info CSI 000002b9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:29:50, Info CSI 000002bb [SR] Verify complete
2010-05-27 16:29:50, Info CSI 000002bc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:29:50, Info CSI 000002bd [SR] Beginning Verify and Repair transaction
2010-05-27 16:29:57, Info CSI 000002bf [SR] Verify complete
2010-05-27 16:29:57, Info CSI 000002c0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:29:57, Info CSI 000002c1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:30:07, Info CSI 000002c4 [SR] Verify complete
2010-05-27 16:30:07, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:30:07, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction
2010-05-27 16:30:15, Info CSI 000002c8 [SR] Verify complete
2010-05-27 16:30:15, Info CSI 000002c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:30:15, Info CSI 000002ca [SR] Beginning Verify and Repair transaction
2010-05-27 16:30:24, Info CSI 000002ce [SR] Verify complete
2010-05-27 16:30:25, Info CSI 000002cf [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:30:25, Info CSI 000002d0 [SR] Beginning Verify and Repair transaction
2010-05-27 16:30:35, Info CSI 000002d2 [SR] Verify complete
2010-05-27 16:30:35, Info CSI 000002d3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:30:35, Info CSI 000002d4 [SR] Beginning Verify and Repair transaction
2010-05-27 16:30:44, Info CSI 000002d7 [SR] Verify complete
2010-05-27 16:30:45, Info CSI 000002d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:30:45, Info CSI 000002d9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:30:54, Info CSI 000002db [SR] Verify complete
2010-05-27 16:30:55, Info CSI 000002dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:30:55, Info CSI 000002dd [SR] Beginning Verify and Repair transaction
2010-05-27 16:31:05, Info CSI 000002df [SR] Verify complete
2010-05-27 16:31:06, Info CSI 000002e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:31:06, Info CSI 000002e1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:31:16, Info CSI 000002e3 [SR] Verify complete
2010-05-27 16:31:16, Info CSI 000002e4 [SR] Verifying 25 (0x0000000000000019) components
2010-05-27 16:31:16, Info CSI 000002e5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:31:18, Info CSI 000002e7 [SR] Verify complete
2010-05-27 16:31:18, Info CSI 000002e8 [SR] Repairing 2 components
2010-05-27 16:31:18, Info CSI 000002e9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:31:18, Info CSI 000002eb [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:31:19, Info CSI 000002ed [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:31:19, Info CSI 000002ef [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:31:19, Info CSI 000002f0 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:31:19, Info CSI 000002f2 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:31:19, Info CSI 000002f3 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:31:19, Info CSI 000002f5 [SR] Repair complete
2010-05-27 16:31:19, Info CSI 000002f6 [SR] Committing transaction
2010-05-27 16:31:19, Info CSI 000002fa [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2010-05-27 16:43:00, Info CSI 00000006 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:00, Info CSI 00000007 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:02, Info CSI 00000009 [SR] Verify complete
2010-05-27 16:43:02, Info CSI 0000000a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:02, Info CSI 0000000b [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:06, Info CSI 0000000d [SR] Verify complete
2010-05-27 16:43:06, Info CSI 0000000e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:06, Info CSI 0000000f [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:08, Info CSI 00000011 [SR] Verify complete
2010-05-27 16:43:08, Info CSI 00000012 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:08, Info CSI 00000013 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:12, Info CSI 00000015 [SR] Verify complete
2010-05-27 16:43:12, Info CSI 00000016 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:12, Info CSI 00000017 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:15, Info CSI 00000019 [SR] Verify complete
2010-05-27 16:43:15, Info CSI 0000001a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:15, Info CSI 0000001b [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:17, Info CSI 0000001d [SR] Verify complete
2010-05-27 16:43:18, Info CSI 0000001e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:18, Info CSI 0000001f [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:20, Info CSI 00000021 [SR] Verify complete
2010-05-27 16:43:20, Info CSI 00000022 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:20, Info CSI 00000023 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:22, Info CSI 00000025 [SR] Verify complete
2010-05-27 16:43:23, Info CSI 00000026 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:23, Info CSI 00000027 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:25, Info CSI 00000029 [SR] Verify complete
2010-05-27 16:43:26, Info CSI 0000002a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:26, Info CSI 0000002b [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:28, Info CSI 0000002d [SR] Verify complete
2010-05-27 16:43:28, Info CSI 0000002e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:28, Info CSI 0000002f [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:31, Info CSI 00000031 [SR] Verify complete
2010-05-27 16:43:31, Info CSI 00000032 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:31, Info CSI 00000033 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:34, Info CSI 00000035 [SR] Verify complete
2010-05-27 16:43:34, Info CSI 00000036 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:34, Info CSI 00000037 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:36, Info CSI 00000039 [SR] Verify complete
2010-05-27 16:43:37, Info CSI 0000003a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:37, Info CSI 0000003b [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:39, Info CSI 0000003d [SR] Verify complete
2010-05-27 16:43:39, Info CSI 0000003e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:39, Info CSI 0000003f [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:42, Info CSI 00000041 [SR] Verify complete
2010-05-27 16:43:42, Info CSI 00000042 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:42, Info CSI 00000043 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:45, Info CSI 00000045 [SR] Verify complete
2010-05-27 16:43:45, Info CSI 00000046 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:45, Info CSI 00000047 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:49, Info CSI 00000049 [SR] Verify complete
2010-05-27 16:43:50, Info CSI 0000004a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:50, Info CSI 0000004b [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:52, Info CSI 0000004d [SR] Verify complete
2010-05-27 16:43:52, Info CSI 0000004e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:52, Info CSI 0000004f [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:56, Info CSI 00000051 [SR] Verify complete
2010-05-27 16:43:56, Info CSI 00000052 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:56, Info CSI 00000053 [SR] Beginning Verify and Repair transaction
2010-05-27 16:43:59, Info CSI 00000055 [SR] Verify complete
2010-05-27 16:43:59, Info CSI 00000056 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:43:59, Info CSI 00000057 [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:01, Info CSI 00000059 [SR] Verify complete
2010-05-27 16:44:01, Info CSI 0000005a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:01, Info CSI 0000005b [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:05, Info CSI 0000005d [SR] Verify complete
2010-05-27 16:44:05, Info CSI 0000005e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:05, Info CSI 0000005f [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:07, Info CSI 00000061 [SR] Verify complete
2010-05-27 16:44:08, Info CSI 00000062 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:08, Info CSI 00000063 [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:10, Info CSI 00000065 [SR] Verify complete
2010-05-27 16:44:10, Info CSI 00000066 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:10, Info CSI 00000067 [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:13, Info CSI 00000069 [SR] Verify complete
2010-05-27 16:44:13, Info CSI 0000006a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:13, Info CSI 0000006b [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:20, Info CSI 0000006d [SR] Verify complete
2010-05-27 16:44:21, Info CSI 0000006e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:21, Info CSI 0000006f [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:26, Info CSI 00000072 [SR] Verify complete
2010-05-27 16:44:27, Info CSI 00000073 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:27, Info CSI 00000074 [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:35, Info CSI 00000078 [SR] Verify complete
2010-05-27 16:44:35, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:35, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:42, Info CSI 0000007e [SR] Verify complete
2010-05-27 16:44:42, Info CSI 0000007f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:42, Info CSI 00000080 [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:47, Info CSI 00000082 [SR] Verify complete
2010-05-27 16:44:48, Info CSI 00000083 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:48, Info CSI 00000084 [SR] Beginning Verify and Repair transaction
2010-05-27 16:44:56, Info CSI 00000092 [SR] Verify complete
2010-05-27 16:44:56, Info CSI 00000093 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:44:56, Info CSI 00000094 [SR] Beginning Verify and Repair transaction
2010-05-27 16:45:06, Info CSI 000000ad [SR] Verify complete
2010-05-27 16:45:07, Info CSI 000000ae [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:45:07, Info CSI 000000af [SR] Beginning Verify and Repair transaction
2010-05-27 16:45:15, Info CSI 000000b1 [SR] Verify complete
2010-05-27 16:45:15, Info CSI 000000b2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:45:15, Info CSI 000000b3 [SR] Beginning Verify and Repair transaction
2010-05-27 16:45:21, Info CSI 000000b5 [SR] Verify complete
2010-05-27 16:45:21, Info CSI 000000b6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:45:21, Info CSI 000000b7 [SR] Beginning Verify and Repair transaction
2010-05-27 16:45:30, Info CSI 000000b9 [SR] Verify complete
2010-05-27 16:45:30, Info CSI 000000ba [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:45:30, Info CSI 000000bb [SR] Beginning Verify and Repair transaction
2010-05-27 16:45:40, Info CSI 000000bd [SR] Verify complete
2010-05-27 16:45:40, Info CSI 000000be [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:45:40, Info CSI 000000bf [SR] Beginning Verify and Repair transaction
2010-05-27 16:45:53, Info CSI 000000d7 [SR] Verify complete
2010-05-27 16:45:53, Info CSI 000000d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:45:53, Info CSI 000000d9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:09, Info CSI 000000db [SR] Verify complete
2010-05-27 16:46:09, Info CSI 000000dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:09, Info CSI 000000dd [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:27, Info CSI 000000df [SR] Verify complete
2010-05-27 16:46:27, Info CSI 000000e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:27, Info CSI 000000e1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:33, Info CSI 000000e3 [SR] Verify complete
2010-05-27 16:46:33, Info CSI 000000e4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:33, Info CSI 000000e5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:36, Info CSI 000000e7 [SR] Verify complete
2010-05-27 16:46:36, Info CSI 000000e8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:36, Info CSI 000000e9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:40, Info CSI 000000eb [SR] Verify complete
2010-05-27 16:46:40, Info CSI 000000ec [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:40, Info CSI 000000ed [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:52, Info CSI 00000100 [SR] Verify complete
2010-05-27 16:46:52, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:52, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:53, Info CSI 00000104 [SR] Verify complete
2010-05-27 16:46:54, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:54, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2010-05-27 16:46:57, Info CSI 00000108 [SR] Verify complete
2010-05-27 16:46:58, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:46:58, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:02, Info CSI 0000010c [SR] Verify complete
2010-05-27 16:47:03, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:03, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:12, Info CSI 00000110 [SR] Verify complete
2010-05-27 16:47:12, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:12, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:19, Info CSI 00000114 [SR] Verify complete
2010-05-27 16:47:19, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:19, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:23, Info CSI 00000118 [SR] Verify complete
2010-05-27 16:47:23, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:23, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:33, Info CSI 0000011c [SR] Verify complete
2010-05-27 16:47:33, Info CSI 0000011d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:33, Info CSI 0000011e [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:38, Info CSI 00000120 [SR] Verify complete
2010-05-27 16:47:39, Info CSI 00000121 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:39, Info CSI 00000122 [SR] Beginning Verify and Repair transaction
2010-05-27 16:47:50, Info CSI 00000135 [SR] Verify complete
2010-05-27 16:47:51, Info CSI 00000136 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:47:51, Info CSI 00000137 [SR] Beginning Verify and Repair transaction
2010-05-27 16:48:02, Info CSI 0000013e [SR] Verify complete
2010-05-27 16:48:03, Info CSI 0000013f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:48:03, Info CSI 00000140 [SR] Beginning Verify and Repair transaction
2010-05-27 16:48:27, Info CSI 00000142 [SR] Verify complete
2010-05-27 16:48:27, Info CSI 00000143 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:48:27, Info CSI 00000144 [SR] Beginning Verify and Repair transaction
2010-05-27 16:48:49, Info CSI 00000146 [SR] Verify complete
2010-05-27 16:48:49, Info CSI 00000147 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:48:49, Info CSI 00000148 [SR] Beginning Verify and Repair transaction
2010-05-27 16:49:04, Info CSI 0000014a [SR] Verify complete
2010-05-27 16:49:05, Info CSI 0000014b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:49:05, Info CSI 0000014c [SR] Beginning Verify and Repair transaction
2010-05-27 16:49:17, Info CSI 0000014e [SR] Verify complete
2010-05-27 16:49:17, Info CSI 0000014f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:49:17, Info CSI 00000150 [SR] Beginning Verify and Repair transaction
2010-05-27 16:49:26, Info CSI 00000152 [SR] Verify complete
2010-05-27 16:49:26, Info CSI 00000153 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:49:26, Info CSI 00000154 [SR] Beginning Verify and Repair transaction
2010-05-27 16:49:34, Info CSI 00000158 [SR] Verify complete
2010-05-27 16:49:34, Info CSI 00000159 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:49:34, Info CSI 0000015a [SR] Beginning Verify and Repair transaction
2010-05-27 16:49:44, Info CSI 0000015c [SR] Verify complete
2010-05-27 16:49:45, Info CSI 0000015d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:49:45, Info CSI 0000015e [SR] Beginning Verify and Repair transaction
2010-05-27 16:49:56, Info CSI 00000160 [SR] Verify complete
2010-05-27 16:49:56, Info CSI 00000161 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:49:56, Info CSI 00000162 [SR] Beginning Verify and Repair transaction
2010-05-27 16:50:04, Info CSI 00000164 [SR] Verify complete
2010-05-27 16:50:04, Info CSI 00000165 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:50:04, Info CSI 00000166 [SR] Beginning Verify and Repair transaction
2010-05-27 16:50:13, Info CSI 00000168 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:50:15, Info CSI 0000016a [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:50:15, Info CSI 0000016b [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:50:16, Info CSI 0000016d [SR] Verify complete
2010-05-27 16:50:17, Info CSI 0000016e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:50:17, Info CSI 0000016f [SR] Beginning Verify and Repair transaction
2010-05-27 16:50:26, Info CSI 00000171 [SR] Verify complete
2010-05-27 16:50:26, Info CSI 00000172 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:50:26, Info CSI 00000173 [SR] Beginning Verify and Repair transaction
2010-05-27 16:50:35, Info CSI 00000175 [SR] Verify complete
2010-05-27 16:50:36, Info CSI 00000176 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:50:36, Info CSI 00000177 [SR] Beginning Verify and Repair transaction
2010-05-27 16:50:47, Info CSI 0000017a [SR] Verify complete
2010-05-27 16:50:48, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:50:48, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:02, Info CSI 0000017e [SR] Verify complete
2010-05-27 16:51:03, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:03, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:11, Info CSI 00000183 [SR] Verify complete
2010-05-27 16:51:11, Info CSI 00000184 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:11, Info CSI 00000185 [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:20, Info CSI 00000189 [SR] Verify complete
2010-05-27 16:51:21, Info CSI 0000018a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:21, Info CSI 0000018b [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:29, Info CSI 0000018f [SR] Verify complete
2010-05-27 16:51:29, Info CSI 00000190 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:29, Info CSI 00000191 [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:42, Info CSI 00000193 [SR] Verify complete
2010-05-27 16:51:42, Info CSI 00000194 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:42, Info CSI 00000195 [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:55, Info CSI 00000197 [SR] Verify complete
2010-05-27 16:51:55, Info CSI 00000198 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:55, Info CSI 00000199 [SR] Beginning Verify and Repair transaction
2010-05-27 16:51:59, Info CSI 0000019b [SR] Verify complete
2010-05-27 16:51:59, Info CSI 0000019c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:51:59, Info CSI 0000019d [SR] Beginning Verify and Repair transaction
2010-05-27 16:52:07, Info CSI 0000019f [SR] Verify complete
2010-05-27 16:52:07, Info CSI 000001a0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:52:07, Info CSI 000001a1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:52:17, Info CSI 000001a3 [SR] Verify complete
2010-05-27 16:52:17, Info CSI 000001a4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:52:17, Info CSI 000001a5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:52:26, Info CSI 000001a7 [SR] Verify complete
2010-05-27 16:52:27, Info CSI 000001a8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:52:27, Info CSI 000001a9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:52:39, Info CSI 000001ab [SR] Verify complete
2010-05-27 16:52:39, Info CSI 000001ac [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:52:39, Info CSI 000001ad [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:00, Info CSI 000001af [SR] Verify complete
2010-05-27 16:53:00, Info CSI 000001b0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:00, Info CSI 000001b1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:08, Info CSI 000001b3 [SR] Verify complete
2010-05-27 16:53:08, Info CSI 000001b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:08, Info CSI 000001b5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:19, Info CSI 000001c0 [SR] Verify complete
2010-05-27 16:53:20, Info CSI 000001c1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:20, Info CSI 000001c2 [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:27, Info CSI 000001c4 [SR] Verify complete
2010-05-27 16:53:28, Info CSI 000001c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:28, Info CSI 000001c6 [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:35, Info CSI 000001c8 [SR] Verify complete
2010-05-27 16:53:36, Info CSI 000001c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:36, Info CSI 000001ca [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:43, Info CSI 000001cc [SR] Verify complete
2010-05-27 16:53:43, Info CSI 000001cd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:43, Info CSI 000001ce [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:54, Info CSI 000001d0 [SR] Verify complete
2010-05-27 16:53:54, Info CSI 000001d1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:54, Info CSI 000001d2 [SR] Beginning Verify and Repair transaction
2010-05-27 16:53:57, Info CSI 000001d4 [SR] Verify complete
2010-05-27 16:53:58, Info CSI 000001d5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:53:58, Info CSI 000001d6 [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:01, Info CSI 000001d9 [SR] Verify complete
2010-05-27 16:54:01, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:01, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:12, Info CSI 000001e1 [SR] Verify complete
2010-05-27 16:54:12, Info CSI 000001e2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:12, Info CSI 000001e3 [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:15, Info CSI 000001e5 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:54:23, Info CSI 000001e9 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:54:23, Info CSI 000001ea [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:54:26, Info CSI 000001f0 [SR] Verify complete
2010-05-27 16:54:26, Info CSI 000001f1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:26, Info CSI 000001f2 [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:36, Info CSI 000001fe [SR] Verify complete
2010-05-27 16:54:36, Info CSI 000001ff [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:36, Info CSI 00000200 [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:41, Info CSI 00000202 [SR] Verify complete
2010-05-27 16:54:42, Info CSI 00000203 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:42, Info CSI 00000204 [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:47, Info CSI 00000206 [SR] Verify complete
2010-05-27 16:54:47, Info CSI 00000207 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:47, Info CSI 00000208 [SR] Beginning Verify and Repair transaction
2010-05-27 16:54:53, Info CSI 0000020d [SR] Verify complete
2010-05-27 16:54:53, Info CSI 0000020e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:54:53, Info CSI 0000020f [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:00, Info CSI 00000225 [SR] Verify complete
2010-05-27 16:55:01, Info CSI 00000226 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:01, Info CSI 00000227 [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:07, Info CSI 00000238 [SR] Verify complete
2010-05-27 16:55:07, Info CSI 00000239 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:07, Info CSI 0000023a [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:13, Info CSI 0000023c [SR] Verify complete
2010-05-27 16:55:13, Info CSI 0000023d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:13, Info CSI 0000023e [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:18, Info CSI 00000240 [SR] Verify complete
2010-05-27 16:55:18, Info CSI 00000241 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:18, Info CSI 00000242 [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:25, Info CSI 00000253 [SR] Verify complete
2010-05-27 16:55:26, Info CSI 00000254 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:26, Info CSI 00000255 [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:37, Info CSI 00000257 [SR] Verify complete
2010-05-27 16:55:38, Info CSI 00000258 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:38, Info CSI 00000259 [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:46, Info CSI 00000267 [SR] Verify complete
2010-05-27 16:55:46, Info CSI 00000268 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:46, Info CSI 00000269 [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:48, Info CSI 0000026b [SR] Verify complete
2010-05-27 16:55:48, Info CSI 0000026c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:48, Info CSI 0000026d [SR] Beginning Verify and Repair transaction
2010-05-27 16:55:57, Info CSI 00000270 [SR] Verify complete
2010-05-27 16:55:57, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:55:57, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:03, Info CSI 00000274 [SR] Verify complete
2010-05-27 16:56:03, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:03, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:11, Info CSI 00000278 [SR] Verify complete
2010-05-27 16:56:11, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:11, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:16, Info CSI 0000027c [SR] Verify complete
2010-05-27 16:56:16, Info CSI 0000027d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:16, Info CSI 0000027e [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:24, Info CSI 00000282 [SR] Verify complete
2010-05-27 16:56:24, Info CSI 00000283 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:24, Info CSI 00000284 [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:32, Info CSI 0000029e [SR] Verify complete
2010-05-27 16:56:33, Info CSI 0000029f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:33, Info CSI 000002a0 [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:53, Info CSI 000002a2 [SR] Verify complete
2010-05-27 16:56:53, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:53, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
2010-05-27 16:56:58, Info CSI 000002a6 [SR] Verify complete
2010-05-27 16:56:59, Info CSI 000002a7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:56:59, Info CSI 000002a8 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:05, Info CSI 000002aa [SR] Verify complete
2010-05-27 16:57:05, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:05, Info CSI 000002ac [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:10, Info CSI 000002ae [SR] Verify complete
2010-05-27 16:57:10, Info CSI 000002af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:10, Info CSI 000002b0 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:18, Info CSI 000002b3 [SR] Verify complete
2010-05-27 16:57:18, Info CSI 000002b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:18, Info CSI 000002b5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:24, Info CSI 000002b7 [SR] Verify complete
2010-05-27 16:57:25, Info CSI 000002b8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:25, Info CSI 000002b9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:30, Info CSI 000002bb [SR] Verify complete
2010-05-27 16:57:30, Info CSI 000002bc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:30, Info CSI 000002bd [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:34, Info CSI 000002bf [SR] Verify complete
2010-05-27 16:57:35, Info CSI 000002c0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:35, Info CSI 000002c1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:40, Info CSI 000002c4 [SR] Verify complete
2010-05-27 16:57:40, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:40, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:46, Info CSI 000002c8 [SR] Verify complete
2010-05-27 16:57:46, Info CSI 000002c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:46, Info CSI 000002ca [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:51, Info CSI 000002ce [SR] Verify complete
2010-05-27 16:57:52, Info CSI 000002cf [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:52, Info CSI 000002d0 [SR] Beginning Verify and Repair transaction
2010-05-27 16:57:58, Info CSI 000002d2 [SR] Verify complete
2010-05-27 16:57:58, Info CSI 000002d3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:57:58, Info CSI 000002d4 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:04, Info CSI 000002d7 [SR] Verify complete
2010-05-27 16:58:04, Info CSI 000002d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:04, Info CSI 000002d9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:10, Info CSI 000002db [SR] Verify complete
2010-05-27 16:58:10, Info CSI 000002dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:10, Info CSI 000002dd [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:16, Info CSI 000002df [SR] Verify complete
2010-05-27 16:58:16, Info CSI 000002e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:16, Info CSI 000002e1 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:23, Info CSI 000002e3 [SR] Verify complete
2010-05-27 16:58:23, Info CSI 000002e4 [SR] Verifying 25 (0x0000000000000019) components
2010-05-27 16:58:23, Info CSI 000002e5 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:24, Info CSI 000002e7 [SR] Verify complete
2010-05-27 16:58:24, Info CSI 000002e8 [SR] Repairing 2 components
2010-05-27 16:58:24, Info CSI 000002e9 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:24, Info CSI 000002eb [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:58:24, Info CSI 000002ed [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:58:24, Info CSI 000002ef [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:58:24, Info CSI 000002f0 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:58:24, Info CSI 000002f2 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 16:58:24, Info CSI 000002f3 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 16:58:24, Info CSI 000002f5 [SR] Repair complete
2010-05-27 16:58:24, Info CSI 000002f6 [SR] Committing transaction
2010-05-27 16:58:25, Info CSI 000002fa [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2010-05-27 16:58:29, Info CSI 000002fb [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:29, Info CSI 000002fc [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:30, Info CSI 000002fe [SR] Verify complete
2010-05-27 16:58:30, Info CSI 000002ff [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:30, Info CSI 00000300 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:32, Info CSI 00000302 [SR] Verify complete
2010-05-27 16:58:32, Info CSI 00000303 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:32, Info CSI 00000304 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:34, Info CSI 00000306 [SR] Verify complete
2010-05-27 16:58:34, Info CSI 00000307 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:34, Info CSI 00000308 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:36, Info CSI 0000030a [SR] Verify complete
2010-05-27 16:58:36, Info CSI 0000030b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:36, Info CSI 0000030c [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:38, Info CSI 0000030e [SR] Verify complete
2010-05-27 16:58:38, Info CSI 0000030f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:38, Info CSI 00000310 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:40, Info CSI 00000312 [SR] Verify complete
2010-05-27 16:58:40, Info CSI 00000313 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:40, Info CSI 00000314 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:42, Info CSI 00000316 [SR] Verify complete
2010-05-27 16:58:42, Info CSI 00000317 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:42, Info CSI 00000318 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:43, Info CSI 0000031a [SR] Verify complete
2010-05-27 16:58:44, Info CSI 0000031b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:44, Info CSI 0000031c [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:45, Info CSI 0000031e [SR] Verify complete
2010-05-27 16:58:46, Info CSI 0000031f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:46, Info CSI 00000320 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:47, Info CSI 00000322 [SR] Verify complete
2010-05-27 16:58:47, Info CSI 00000323 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:47, Info CSI 00000324 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:49, Info CSI 00000326 [SR] Verify complete
2010-05-27 16:58:49, Info CSI 00000327 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:49, Info CSI 00000328 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:50, Info CSI 0000032a [SR] Verify complete
2010-05-27 16:58:51, Info CSI 0000032b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:51, Info CSI 0000032c [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:52, Info CSI 0000032e [SR] Verify complete
2010-05-27 16:58:52, Info CSI 0000032f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:52, Info CSI 00000330 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:54, Info CSI 00000332 [SR] Verify complete
2010-05-27 16:58:55, Info CSI 00000333 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:55, Info CSI 00000334 [SR] Beginning Verify and Repair transaction
2010-05-27 16:58:57, Info CSI 00000336 [SR] Verify complete
2010-05-27 16:58:58, Info CSI 00000337 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:58:58, Info CSI 00000338 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:00, Info CSI 0000033a [SR] Verify complete
2010-05-27 16:59:00, Info CSI 0000033b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:00, Info CSI 0000033c [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:05, Info CSI 0000033e [SR] Verify complete
2010-05-27 16:59:05, Info CSI 0000033f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:05, Info CSI 00000340 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:07, Info CSI 00000342 [SR] Verify complete
2010-05-27 16:59:07, Info CSI 00000343 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:07, Info CSI 00000344 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:09, Info CSI 00000346 [SR] Verify complete
2010-05-27 16:59:09, Info CSI 00000347 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:09, Info CSI 00000348 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:11, Info CSI 0000034a [SR] Verify complete
2010-05-27 16:59:12, Info CSI 0000034b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:12, Info CSI 0000034c [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:13, Info CSI 0000034e [SR] Verify complete
2010-05-27 16:59:13, Info CSI 0000034f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:13, Info CSI 00000350 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:16, Info CSI 00000352 [SR] Verify complete
2010-05-27 16:59:16, Info CSI 00000353 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:16, Info CSI 00000354 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:18, Info CSI 00000356 [SR] Verify complete
2010-05-27 16:59:18, Info CSI 00000357 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:18, Info CSI 00000358 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:20, Info CSI 0000035a [SR] Verify complete
2010-05-27 16:59:20, Info CSI 0000035b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:20, Info CSI 0000035c [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:22, Info CSI 0000035e [SR] Verify complete
2010-05-27 16:59:22, Info CSI 0000035f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:22, Info CSI 00000360 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:28, Info CSI 00000362 [SR] Verify complete
2010-05-27 16:59:29, Info CSI 00000363 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:29, Info CSI 00000364 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:33, Info CSI 00000367 [SR] Verify complete
2010-05-27 16:59:33, Info CSI 00000368 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:33, Info CSI 00000369 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:39, Info CSI 0000036d [SR] Verify complete
2010-05-27 16:59:39, Info CSI 0000036e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:39, Info CSI 0000036f [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:44, Info CSI 00000373 [SR] Verify complete
2010-05-27 16:59:44, Info CSI 00000374 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:44, Info CSI 00000375 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:48, Info CSI 00000377 [SR] Verify complete
2010-05-27 16:59:48, Info CSI 00000378 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:48, Info CSI 00000379 [SR] Beginning Verify and Repair transaction
2010-05-27 16:59:55, Info CSI 00000387 [SR] Verify complete
2010-05-27 16:59:55, Info CSI 00000388 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 16:59:55, Info CSI 00000389 [SR] Beginning Verify and Repair transaction
2010-05-27 17:00:04, Info CSI 000003a2 [SR] Verify complete
2010-05-27 17:00:04, Info CSI 000003a3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:00:04, Info CSI 000003a4 [SR] Beginning Verify and Repair transaction
2010-05-27 17:00:11, Info CSI 000003a6 [SR] Verify complete
2010-05-27 17:00:11, Info CSI 000003a7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:00:11, Info CSI 000003a8 [SR] Beginning Verify and Repair transaction
2010-05-27 17:00:18, Info CSI 000003aa [SR] Verify complete
2010-05-27 17:00:19, Info CSI 000003ab [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:00:19, Info CSI 000003ac [SR] Beginning Verify and Repair transaction
2010-05-27 17:00:31, Info CSI 000003ae [SR] Verify complete
2010-05-27 17:00:31, Info CSI 000003af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:00:31, Info CSI 000003b0 [SR] Beginning Verify and Repair transaction
2010-05-27 17:00:40, Info CSI 000003b2 [SR] Verify complete
2010-05-27 17:00:40, Info CSI 000003b3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:00:40, Info CSI 000003b4 [SR] Beginning Verify and Repair transaction
2010-05-27 17:00:51, Info CSI 000003cc [SR] Verify complete
2010-05-27 17:00:51, Info CSI 000003cd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:00:51, Info CSI 000003ce [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:07, Info CSI 000003d0 [SR] Verify complete
2010-05-27 17:01:08, Info CSI 000003d1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:08, Info CSI 000003d2 [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:21, Info CSI 000003d4 [SR] Verify complete
2010-05-27 17:01:21, Info CSI 000003d5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:21, Info CSI 000003d6 [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:25, Info CSI 000003d8 [SR] Verify complete
2010-05-27 17:01:25, Info CSI 000003d9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:25, Info CSI 000003da [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:28, Info CSI 000003dc [SR] Verify complete
2010-05-27 17:01:28, Info CSI 000003dd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:28, Info CSI 000003de [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:31, Info CSI 000003e0 [SR] Verify complete
2010-05-27 17:01:31, Info CSI 000003e1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:31, Info CSI 000003e2 [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:43, Info CSI 000003f5 [SR] Verify complete
2010-05-27 17:01:43, Info CSI 000003f6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:43, Info CSI 000003f7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:44, Info CSI 000003f9 [SR] Verify complete
2010-05-27 17:01:44, Info CSI 000003fa [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:44, Info CSI 000003fb [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:47, Info CSI 000003fd [SR] Verify complete
2010-05-27 17:01:47, Info CSI 000003fe [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:47, Info CSI 000003ff [SR] Beginning Verify and Repair transaction
2010-05-27 17:01:52, Info CSI 00000401 [SR] Verify complete
2010-05-27 17:01:52, Info CSI 00000402 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:01:52, Info CSI 00000403 [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:00, Info CSI 00000405 [SR] Verify complete
2010-05-27 17:02:01, Info CSI 00000406 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:01, Info CSI 00000407 [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:06, Info CSI 00000409 [SR] Verify complete
2010-05-27 17:02:06, Info CSI 0000040a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:06, Info CSI 0000040b [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:09, Info CSI 0000040d [SR] Verify complete
2010-05-27 17:02:09, Info CSI 0000040e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:09, Info CSI 0000040f [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:17, Info CSI 00000411 [SR] Verify complete
2010-05-27 17:02:17, Info CSI 00000412 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:17, Info CSI 00000413 [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:21, Info CSI 00000415 [SR] Verify complete
2010-05-27 17:02:22, Info CSI 00000416 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:22, Info CSI 00000417 [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:32, Info CSI 0000042a [SR] Verify complete
2010-05-27 17:02:32, Info CSI 0000042b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:32, Info CSI 0000042c [SR] Beginning Verify and Repair transaction
2010-05-27 17:02:42, Info CSI 00000433 [SR] Verify complete
2010-05-27 17:02:42, Info CSI 00000434 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:02:42, Info CSI 00000435 [SR] Beginning Verify and Repair transaction
2010-05-27 17:03:05, Info CSI 00000437 [SR] Verify complete
2010-05-27 17:03:05, Info CSI 00000438 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:03:05, Info CSI 00000439 [SR] Beginning Verify and Repair transaction
2010-05-27 17:03:19, Info CSI 0000043b [SR] Verify complete
2010-05-27 17:03:19, Info CSI 0000043c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:03:19, Info CSI 0000043d [SR] Beginning Verify and Repair transaction
2010-05-27 17:03:30, Info CSI 0000043f [SR] Verify complete
2010-05-27 17:03:30, Info CSI 00000440 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:03:30, Info CSI 00000441 [SR] Beginning Verify and Repair transaction
2010-05-27 17:03:40, Info CSI 00000443 [SR] Verify complete
2010-05-27 17:03:41, Info CSI 00000444 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:03:41, Info CSI 00000445 [SR] Beginning Verify and Repair transaction
2010-05-27 17:03:48, Info CSI 00000447 [SR] Verify complete
2010-05-27 17:03:48, Info CSI 00000448 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:03:48, Info CSI 00000449 [SR] Beginning Verify and Repair transaction
2010-05-27 17:03:55, Info CSI 0000044d [SR] Verify complete
2010-05-27 17:03:56, Info CSI 0000044e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:03:56, Info CSI 0000044f [SR] Beginning Verify and Repair transaction
2010-05-27 17:04:08, Info CSI 00000451 [SR] Verify complete
2010-05-27 17:04:08, Info CSI 00000452 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:04:08, Info CSI 00000453 [SR] Beginning Verify and Repair transaction
2010-05-27 17:04:18, Info CSI 00000455 [SR] Verify complete
2010-05-27 17:04:18, Info CSI 00000456 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:04:18, Info CSI 00000457 [SR] Beginning Verify and Repair transaction
2010-05-27 17:04:25, Info CSI 00000459 [SR] Verify complete
2010-05-27 17:04:25, Info CSI 0000045a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:04:25, Info CSI 0000045b [SR] Beginning Verify and Repair transaction
2010-05-27 17:04:35, Info CSI 0000045d [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:04:37, Info CSI 0000045f [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:04:37, Info CSI 00000460 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:04:38, Info CSI 00000462 [SR] Verify complete
2010-05-27 17:04:38, Info CSI 00000463 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:04:38, Info CSI 00000464 [SR] Beginning Verify and Repair transaction
2010-05-27 17:04:47, Info CSI 00000466 [SR] Verify complete
2010-05-27 17:04:47, Info CSI 00000467 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:04:47, Info CSI 00000468 [SR] Beginning Verify and Repair transaction
2010-05-27 17:04:57, Info CSI 0000046a [SR] Verify complete
2010-05-27 17:04:57, Info CSI 0000046b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:04:57, Info CSI 0000046c [SR] Beginning Verify and Repair transaction
2010-05-27 17:05:09, Info CSI 0000046f [SR] Verify complete
2010-05-27 17:05:09, Info CSI 00000470 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:05:09, Info CSI 00000471 [SR] Beginning Verify and Repair transaction
2010-05-27 17:05:19, Info CSI 00000473 [SR] Verify complete
2010-05-27 17:05:19, Info CSI 00000474 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:05:19, Info CSI 00000475 [SR] Beginning Verify and Repair transaction
2010-05-27 17:05:25, Info CSI 00000478 [SR] Verify complete
2010-05-27 17:05:26, Info CSI 00000479 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:05:26, Info CSI 0000047a [SR] Beginning Verify and Repair transaction
2010-05-27 17:05:34, Info CSI 0000047e [SR] Verify complete
2010-05-27 17:05:34, Info CSI 0000047f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:05:34, Info CSI 00000480 [SR] Beginning Verify and Repair transaction
2010-05-27 17:05:42, Info CSI 00000484 [SR] Verify complete
2010-05-27 17:05:42, Info CSI 00000485 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:05:42, Info CSI 00000486 [SR] Beginning Verify and Repair transaction
2010-05-27 17:05:54, Info CSI 00000488 [SR] Verify complete
2010-05-27 17:05:54, Info CSI 00000489 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:05:54, Info CSI 0000048a [SR] Beginning Verify and Repair transaction
2010-05-27 17:06:07, Info CSI 0000048c [SR] Verify complete
2010-05-27 17:06:08, Info CSI 0000048d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:06:08, Info CSI 0000048e [SR] Beginning Verify and Repair transaction
2010-05-27 17:06:11, Info CSI 00000490 [SR] Verify complete
2010-05-27 17:06:11, Info CSI 00000491 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:06:11, Info CSI 00000492 [SR] Beginning Verify and Repair transaction
2010-05-27 17:06:19, Info CSI 00000494 [SR] Verify complete
2010-05-27 17:06:19, Info CSI 00000495 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:06:19, Info CSI 00000496 [SR] Beginning Verify and Repair transaction
2010-05-27 17:06:27, Info CSI 00000498 [SR] Verify complete
2010-05-27 17:06:28, Info CSI 00000499 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:06:28, Info CSI 0000049a [SR] Beginning Verify and Repair transaction
2010-05-27 17:06:36, Info CSI 0000049c [SR] Verify complete
2010-05-27 17:06:37, Info CSI 0000049d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:06:37, Info CSI 0000049e [SR] Beginning Verify and Repair transaction
2010-05-27 17:06:46, Info CSI 000004a0 [SR] Verify complete
2010-05-27 17:06:47, Info CSI 000004a1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:06:47, Info CSI 000004a2 [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:05, Info CSI 000004a4 [SR] Verify complete
2010-05-27 17:07:06, Info CSI 000004a5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:06, Info CSI 000004a6 [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:13, Info CSI 000004a8 [SR] Verify complete
2010-05-27 17:07:13, Info CSI 000004a9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:13, Info CSI 000004aa [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:24, Info CSI 000004b5 [SR] Verify complete
2010-05-27 17:07:24, Info CSI 000004b6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:24, Info CSI 000004b7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:31, Info CSI 000004b9 [SR] Verify complete
2010-05-27 17:07:31, Info CSI 000004ba [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:31, Info CSI 000004bb [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:38, Info CSI 000004bd [SR] Verify complete
2010-05-27 17:07:38, Info CSI 000004be [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:38, Info CSI 000004bf [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:46, Info CSI 000004c1 [SR] Verify complete
2010-05-27 17:07:46, Info CSI 000004c2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:46, Info CSI 000004c3 [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:56, Info CSI 000004c5 [SR] Verify complete
2010-05-27 17:07:56, Info CSI 000004c6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:07:56, Info CSI 000004c7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:07:59, Info CSI 000004c9 [SR] Verify complete
2010-05-27 17:08:00, Info CSI 000004ca [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:00, Info CSI 000004cb [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:03, Info CSI 000004ce [SR] Verify complete
2010-05-27 17:08:04, Info CSI 000004cf [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:04, Info CSI 000004d0 [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:15, Info CSI 000004d6 [SR] Verify complete
2010-05-27 17:08:15, Info CSI 000004d7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:15, Info CSI 000004d8 [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:18, Info CSI 000004da [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:08:26, Info CSI 000004de [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:08:26, Info CSI 000004df [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:08:29, Info CSI 000004e5 [SR] Verify complete
2010-05-27 17:08:30, Info CSI 000004e6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:30, Info CSI 000004e7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:39, Info CSI 000004f3 [SR] Verify complete
2010-05-27 17:08:40, Info CSI 000004f4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:40, Info CSI 000004f5 [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:44, Info CSI 000004f7 [SR] Verify complete
2010-05-27 17:08:44, Info CSI 000004f8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:44, Info CSI 000004f9 [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:50, Info CSI 000004fb [SR] Verify complete
2010-05-27 17:08:50, Info CSI 000004fc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:50, Info CSI 000004fd [SR] Beginning Verify and Repair transaction
2010-05-27 17:08:55, Info CSI 00000502 [SR] Verify complete
2010-05-27 17:08:56, Info CSI 00000503 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:08:56, Info CSI 00000504 [SR] Beginning Verify and Repair transaction
2010-05-27 17:09:10, Info CSI 0000051a [SR] Verify complete
2010-05-27 17:09:11, Info CSI 0000051b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:09:11, Info CSI 0000051c [SR] Beginning Verify and Repair transaction
2010-05-27 17:09:22, Info CSI 0000052d [SR] Verify complete
2010-05-27 17:09:23, Info CSI 0000052e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:09:23, Info CSI 0000052f [SR] Beginning Verify and Repair transaction
2010-05-27 17:09:33, Info CSI 00000531 [SR] Verify complete
2010-05-27 17:09:34, Info CSI 00000532 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:09:34, Info CSI 00000533 [SR] Beginning Verify and Repair transaction
2010-05-27 17:09:44, Info CSI 00000535 [SR] Verify complete
2010-05-27 17:09:44, Info CSI 00000536 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:09:44, Info CSI 00000537 [SR] Beginning Verify and Repair transaction
2010-05-27 17:09:57, Info CSI 00000548 [SR] Verify complete
2010-05-27 17:09:58, Info CSI 00000549 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:09:58, Info CSI 0000054a [SR] Beginning Verify and Repair transaction
2010-05-27 17:10:22, Info CSI 0000054c [SR] Verify complete
2010-05-27 17:10:23, Info CSI 0000054d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:10:23, Info CSI 0000054e [SR] Beginning Verify and Repair transaction
2010-05-27 17:10:40, Info CSI 0000055c [SR] Verify complete
2010-05-27 17:10:40, Info CSI 0000055d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:10:40, Info CSI 0000055e [SR] Beginning Verify and Repair transaction
2010-05-27 17:10:46, Info CSI 00000560 [SR] Verify complete
2010-05-27 17:10:46, Info CSI 00000561 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:10:46, Info CSI 00000562 [SR] Beginning Verify and Repair transaction
2010-05-27 17:11:07, Info CSI 00000565 [SR] Verify complete
2010-05-27 17:11:08, Info CSI 00000566 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:11:08, Info CSI 00000567 [SR] Beginning Verify and Repair transaction
2010-05-27 17:11:17, Info CSI 00000569 [SR] Verify complete
2010-05-27 17:11:17, Info CSI 0000056a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:11:17, Info CSI 0000056b [SR] Beginning Verify and Repair transaction
2010-05-27 17:11:31, Info CSI 0000056d [SR] Verify complete
2010-05-27 17:11:32, Info CSI 0000056e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:11:32, Info CSI 0000056f [SR] Beginning Verify and Repair transaction
2010-05-27 17:11:43, Info CSI 00000571 [SR] Verify complete
2010-05-27 17:11:43, Info CSI 00000572 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:11:43, Info CSI 00000573 [SR] Beginning Verify and Repair transaction
2010-05-27 17:12:03, Info CSI 00000577 [SR] Verify complete
2010-05-27 17:12:03, Info CSI 00000578 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:12:03, Info CSI 00000579 [SR] Beginning Verify and Repair transaction
2010-05-27 17:12:25, Info CSI 00000593 [SR] Verify complete
2010-05-27 17:12:26, Info CSI 00000594 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:12:26, Info CSI 00000595 [SR] Beginning Verify and Repair transaction
2010-05-27 17:13:55, Info CSI 00000597 [SR] Verify complete
2010-05-27 17:13:55, Info CSI 00000598 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:13:55, Info CSI 00000599 [SR] Beginning Verify and Repair transaction
2010-05-27 17:14:14, Info CSI 0000059b [SR] Verify complete
2010-05-27 17:14:15, Info CSI 0000059c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:14:15, Info CSI 0000059d [SR] Beginning Verify and Repair transaction
2010-05-27 17:14:37, Info CSI 0000059f [SR] Verify complete
2010-05-27 17:14:38, Info CSI 000005a0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:14:38, Info CSI 000005a1 [SR] Beginning Verify and Repair transaction
2010-05-27 17:14:56, Info CSI 000005a3 [SR] Verify complete
2010-05-27 17:14:57, Info CSI 000005a4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:14:57, Info CSI 000005a5 [SR] Beginning Verify and Repair transaction
2010-05-27 17:15:48, Info CSI 000005a8 [SR] Verify complete
2010-05-27 17:15:49, Info CSI 000005a9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:15:49, Info CSI 000005aa [SR] Beginning Verify and Repair transaction
2010-05-27 17:16:17, Info CSI 000005ac [SR] Verify complete
2010-05-27 17:16:17, Info CSI 000005ad [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:16:17, Info CSI 000005ae [SR] Beginning Verify and Repair transaction
2010-05-27 17:16:36, Info CSI 000005b0 [SR] Verify complete
2010-05-27 17:16:37, Info CSI 000005b1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:16:37, Info CSI 000005b2 [SR] Beginning Verify and Repair transaction
2010-05-27 17:16:53, Info CSI 000005b4 [SR] Verify complete
2010-05-27 17:16:53, Info CSI 000005b5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:16:53, Info CSI 000005b6 [SR] Beginning Verify and Repair transaction
2010-05-27 17:17:25, Info CSI 000005b9 [SR] Verify complete
2010-05-27 17:17:26, Info CSI 000005ba [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:17:26, Info CSI 000005bb [SR] Beginning Verify and Repair transaction
2010-05-27 17:17:45, Info CSI 000005bd [SR] Verify complete
2010-05-27 17:17:45, Info CSI 000005be [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:17:45, Info CSI 000005bf [SR] Beginning Verify and Repair transaction
2010-05-27 17:18:07, Info CSI 000005c3 [SR] Verify complete
2010-05-27 17:18:07, Info CSI 000005c4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:18:07, Info CSI 000005c5 [SR] Beginning Verify and Repair transaction
2010-05-27 17:18:26, Info CSI 000005c7 [SR] Verify complete
2010-05-27 17:18:27, Info CSI 000005c8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:18:27, Info CSI 000005c9 [SR] Beginning Verify and Repair transaction
2010-05-27 17:18:41, Info CSI 000005cc [SR] Verify complete
2010-05-27 17:18:41, Info CSI 000005cd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:18:41, Info CSI 000005ce [SR] Beginning Verify and Repair transaction
2010-05-27 17:18:54, Info CSI 000005d0 [SR] Verify complete
2010-05-27 17:18:55, Info CSI 000005d1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:18:55, Info CSI 000005d2 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:08, Info CSI 000005d4 [SR] Verify complete
2010-05-27 17:19:08, Info CSI 000005d5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:08, Info CSI 000005d6 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:25, Info CSI 000005d8 [SR] Verify complete
2010-05-27 17:19:25, Info CSI 000005d9 [SR] Verifying 25 (0x0000000000000019) components
2010-05-27 17:19:25, Info CSI 000005da [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:27, Info CSI 000005dc [SR] Verify complete
2010-05-27 17:19:27, Info CSI 000005dd [SR] Repairing 2 components
2010-05-27 17:19:27, Info CSI 000005de [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:27, Info CSI 000005e0 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:19:28, Info CSI 000005e2 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:19:28, Info CSI 000005e4 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:19:28, Info CSI 000005e5 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:19:28, Info CSI 000005e7 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:19:28, Info CSI 000005e8 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:19:28, Info CSI 000005ea [SR] Repair complete
2010-05-27 17:19:28, Info CSI 000005eb [SR] Committing transaction
2010-05-27 17:19:28, Info CSI 000005ef [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2010-05-27 17:19:33, Info CSI 000005f0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:33, Info CSI 000005f1 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:37, Info CSI 000005f3 [SR] Verify complete
2010-05-27 17:19:37, Info CSI 000005f4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:37, Info CSI 000005f5 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:42, Info CSI 000005f7 [SR] Verify complete
2010-05-27 17:19:42, Info CSI 000005f8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:42, Info CSI 000005f9 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:45, Info CSI 000005fb [SR] Verify complete
2010-05-27 17:19:45, Info CSI 000005fc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:45, Info CSI 000005fd [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:49, Info CSI 000005ff [SR] Verify complete
2010-05-27 17:19:50, Info CSI 00000600 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:50, Info CSI 00000601 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:53, Info CSI 00000603 [SR] Verify complete
2010-05-27 17:19:53, Info CSI 00000604 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:53, Info CSI 00000605 [SR] Beginning Verify and Repair transaction
2010-05-27 17:19:56, Info CSI 00000607 [SR] Verify complete
2010-05-27 17:19:57, Info CSI 00000608 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:19:57, Info CSI 00000609 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:00, Info CSI 0000060b [SR] Verify complete
2010-05-27 17:20:00, Info CSI 0000060c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:00, Info CSI 0000060d [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:03, Info CSI 0000060f [SR] Verify complete
2010-05-27 17:20:04, Info CSI 00000610 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:04, Info CSI 00000611 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:07, Info CSI 00000613 [SR] Verify complete
2010-05-27 17:20:07, Info CSI 00000614 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:07, Info CSI 00000615 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:11, Info CSI 00000617 [SR] Verify complete
2010-05-27 17:20:11, Info CSI 00000618 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:11, Info CSI 00000619 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:14, Info CSI 0000061b [SR] Verify complete
2010-05-27 17:20:14, Info CSI 0000061c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:14, Info CSI 0000061d [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:18, Info CSI 0000061f [SR] Verify complete
2010-05-27 17:20:18, Info CSI 00000620 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:18, Info CSI 00000621 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:21, Info CSI 00000623 [SR] Verify complete
2010-05-27 17:20:21, Info CSI 00000624 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:21, Info CSI 00000625 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:25, Info CSI 00000627 [SR] Verify complete
2010-05-27 17:20:25, Info CSI 00000628 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:25, Info CSI 00000629 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:28, Info CSI 0000062b [SR] Verify complete
2010-05-27 17:20:29, Info CSI 0000062c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:29, Info CSI 0000062d [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:33, Info CSI 0000062f [SR] Verify complete
2010-05-27 17:20:34, Info CSI 00000630 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:34, Info CSI 00000631 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:39, Info CSI 00000633 [SR] Verify complete
2010-05-27 17:20:40, Info CSI 00000634 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:40, Info CSI 00000635 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:43, Info CSI 00000637 [SR] Verify complete
2010-05-27 17:20:44, Info CSI 00000638 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:44, Info CSI 00000639 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:48, Info CSI 0000063b [SR] Verify complete
2010-05-27 17:20:48, Info CSI 0000063c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:48, Info CSI 0000063d [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:52, Info CSI 0000063f [SR] Verify complete
2010-05-27 17:20:53, Info CSI 00000640 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:53, Info CSI 00000641 [SR] Beginning Verify and Repair transaction
2010-05-27 17:20:55, Info CSI 00000643 [SR] Verify complete
2010-05-27 17:20:56, Info CSI 00000644 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:20:56, Info CSI 00000645 [SR] Beginning Verify and Repair transaction
2010-05-27 17:21:03, Info CSI 00000647 [SR] Verify complete
2010-05-27 17:21:03, Info CSI 00000648 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:21:03, Info CSI 00000649 [SR] Beginning Verify and Repair transaction
2010-05-27 17:21:07, Info CSI 0000064b [SR] Verify complete
2010-05-27 17:21:07, Info CSI 0000064c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:21:07, Info CSI 0000064d [SR] Beginning Verify and Repair transaction
2010-05-27 17:21:11, Info CSI 0000064f [SR] Verify complete
2010-05-27 17:21:11, Info CSI 00000650 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:21:11, Info CSI 00000651 [SR] Beginning Verify and Repair transaction
2010-05-27 17:21:17, Info CSI 00000653 [SR] Verify complete
2010-05-27 17:21:18, Info CSI 00000654 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:21:18, Info CSI 00000655 [SR] Beginning Verify and Repair transaction
2010-05-27 17:21:34, Info CSI 00000657 [SR] Verify complete
2010-05-27 17:21:35, Info CSI 00000658 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:21:35, Info CSI 00000659 [SR] Beginning Verify and Repair transaction
2010-05-27 17:21:45, Info CSI 0000065c [SR] Verify complete
2010-05-27 17:21:46, Info CSI 0000065d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:21:46, Info CSI 0000065e [SR] Beginning Verify and Repair transaction
2010-05-27 17:22:03, Info CSI 00000662 [SR] Verify complete
2010-05-27 17:22:04, Info CSI 00000663 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:22:04, Info CSI 00000664 [SR] Beginning Verify and Repair transaction
2010-05-27 17:22:18, Info CSI 00000668 [SR] Verify complete
2010-05-27 17:22:19, Info CSI 00000669 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:22:19, Info CSI 0000066a [SR] Beginning Verify and Repair transaction
2010-05-27 17:22:27, Info CSI 0000066c [SR] Verify complete
2010-05-27 17:22:28, Info CSI 0000066d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:22:28, Info CSI 0000066e [SR] Beginning Verify and Repair transaction
2010-05-27 17:22:42, Info CSI 0000067c [SR] Verify complete
2010-05-27 17:22:43, Info CSI 0000067d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:22:43, Info CSI 0000067e [SR] Beginning Verify and Repair transaction
2010-05-27 17:23:00, Info CSI 00000697 [SR] Verify complete
2010-05-27 17:23:01, Info CSI 00000698 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:23:01, Info CSI 00000699 [SR] Beginning Verify and Repair transaction
2010-05-27 17:23:20, Info CSI 0000069b [SR] Verify complete
2010-05-27 17:23:21, Info CSI 0000069c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:23:21, Info CSI 0000069d [SR] Beginning Verify and Repair transaction
2010-05-27 17:23:33, Info CSI 0000069f [SR] Verify complete
2010-05-27 17:23:35, Info CSI 000006a0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:23:35, Info CSI 000006a1 [SR] Beginning Verify and Repair transaction
2010-05-27 17:23:49, Info CSI 000006a3 [SR] Verify complete
2010-05-27 17:23:50, Info CSI 000006a4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:23:50, Info CSI 000006a5 [SR] Beginning Verify and Repair transaction
2010-05-27 17:24:09, Info CSI 000006a7 [SR] Verify complete
2010-05-27 17:24:10, Info CSI 000006a8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:24:10, Info CSI 000006a9 [SR] Beginning Verify and Repair transaction
2010-05-27 17:24:39, Info CSI 000006c1 [SR] Verify complete
2010-05-27 17:24:39, Info CSI 000006c2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:24:39, Info CSI 000006c3 [SR] Beginning Verify and Repair transaction
2010-05-27 17:25:23, Info CSI 000006c5 [SR] Verify complete
2010-05-27 17:25:23, Info CSI 000006c6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:25:23, Info CSI 000006c7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:26:00, Info CSI 000006c9 [SR] Verify complete
2010-05-27 17:26:01, Info CSI 000006ca [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:26:01, Info CSI 000006cb [SR] Beginning Verify and Repair transaction
2010-05-27 17:26:09, Info CSI 000006cd [SR] Verify complete
2010-05-27 17:26:09, Info CSI 000006ce [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:26:09, Info CSI 000006cf [SR] Beginning Verify and Repair transaction
2010-05-27 17:26:15, Info CSI 000006d1 [SR] Verify complete
2010-05-27 17:26:16, Info CSI 000006d2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:26:16, Info CSI 000006d3 [SR] Beginning Verify and Repair transaction
2010-05-27 17:26:23, Info CSI 000006d5 [SR] Verify complete
2010-05-27 17:26:24, Info CSI 000006d6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:26:24, Info CSI 000006d7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:26:49, Info CSI 000006ea [SR] Verify complete
2010-05-27 17:26:50, Info CSI 000006eb [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:26:50, Info CSI 000006ec [SR] Beginning Verify and Repair transaction
2010-05-27 17:26:53, Info CSI 000006ee [SR] Verify complete
2010-05-27 17:26:53, Info CSI 000006ef [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:26:53, Info CSI 000006f0 [SR] Beginning Verify and Repair transaction
2010-05-27 17:27:01, Info CSI 000006f2 [SR] Verify complete
2010-05-27 17:27:01, Info CSI 000006f3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:27:01, Info CSI 000006f4 [SR] Beginning Verify and Repair transaction
2010-05-27 17:27:12, Info CSI 000006f6 [SR] Verify complete
2010-05-27 17:27:13, Info CSI 000006f7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:27:13, Info CSI 000006f8 [SR] Beginning Verify and Repair transaction
2010-05-27 17:27:31, Info CSI 000006fa [SR] Verify complete
2010-05-27 17:27:32, Info CSI 000006fb [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:27:32, Info CSI 000006fc [SR] Beginning Verify and Repair transaction
2010-05-27 17:27:46, Info CSI 000006fe [SR] Verify complete
2010-05-27 17:27:47, Info CSI 000006ff [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:27:47, Info CSI 00000700 [SR] Beginning Verify and Repair transaction
2010-05-27 17:27:55, Info CSI 00000702 [SR] Verify complete
2010-05-27 17:27:56, Info CSI 00000703 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:27:56, Info CSI 00000704 [SR] Beginning Verify and Repair transaction
2010-05-27 17:28:18, Info CSI 00000706 [SR] Verify complete
2010-05-27 17:28:19, Info CSI 00000707 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:28:19, Info CSI 00000708 [SR] Beginning Verify and Repair transaction
2010-05-27 17:28:29, Info CSI 0000070a [SR] Verify complete
2010-05-27 17:28:30, Info CSI 0000070b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:28:30, Info CSI 0000070c [SR] Beginning Verify and Repair transaction
2010-05-27 17:28:53, Info CSI 0000071f [SR] Verify complete
2010-05-27 17:28:54, Info CSI 00000720 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:28:54, Info CSI 00000721 [SR] Beginning Verify and Repair transaction
2010-05-27 17:29:20, Info CSI 00000728 [SR] Verify complete
2010-05-27 17:29:21, Info CSI 00000729 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:29:21, Info CSI 0000072a [SR] Beginning Verify and Repair transaction
2010-05-27 17:29:56, Info CSI 0000072c [SR] Verify complete
2010-05-27 17:29:58, Info CSI 0000072d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:29:58, Info CSI 0000072e [SR] Beginning Verify and Repair transaction
2010-05-27 17:30:35, Info CSI 00000730 [SR] Verify complete
2010-05-27 17:30:35, Info CSI 00000731 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:30:35, Info CSI 00000732 [SR] Beginning Verify and Repair transaction
2010-05-27 17:30:51, Info CSI 00000734 [SR] Verify complete
2010-05-27 17:30:51, Info CSI 00000735 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:30:51, Info CSI 00000736 [SR] Beginning Verify and Repair transaction
2010-05-27 17:31:07, Info CSI 00000738 [SR] Verify complete
2010-05-27 17:31:08, Info CSI 00000739 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:31:08, Info CSI 0000073a [SR] Beginning Verify and Repair transaction
2010-05-27 17:31:26, Info CSI 0000073c [SR] Verify complete
2010-05-27 17:31:27, Info CSI 0000073d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:31:27, Info CSI 0000073e [SR] Beginning Verify and Repair transaction
2010-05-27 17:31:41, Info CSI 00000742 [SR] Verify complete
2010-05-27 17:31:42, Info CSI 00000743 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:31:42, Info CSI 00000744 [SR] Beginning Verify and Repair transaction
2010-05-27 17:32:06, Info CSI 00000746 [SR] Verify complete
2010-05-27 17:32:07, Info CSI 00000747 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:32:07, Info CSI 00000748 [SR] Beginning Verify and Repair transaction
2010-05-27 17:32:40, Info CSI 0000074a [SR] Verify complete
2010-05-27 17:32:42, Info CSI 0000074b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:32:42, Info CSI 0000074c [SR] Beginning Verify and Repair transaction
2010-05-27 17:32:53, Info CSI 0000074e [SR] Verify complete
2010-05-27 17:32:54, Info CSI 0000074f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:32:54, Info CSI 00000750 [SR] Beginning Verify and Repair transaction
2010-05-27 17:33:16, Info CSI 00000752 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:33:18, Info CSI 00000754 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:33:18, Info CSI 00000755 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:33:20, Info CSI 00000757 [SR] Verify complete
2010-05-27 17:33:20, Info CSI 00000758 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:33:20, Info CSI 00000759 [SR] Beginning Verify and Repair transaction
2010-05-27 17:33:37, Info CSI 0000075b [SR] Verify complete
2010-05-27 17:33:38, Info CSI 0000075c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:33:38, Info CSI 0000075d [SR] Beginning Verify and Repair transaction
2010-05-27 17:33:58, Info CSI 0000075f [SR] Verify complete
2010-05-27 17:33:58, Info CSI 00000760 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:33:58, Info CSI 00000761 [SR] Beginning Verify and Repair transaction
2010-05-27 17:34:16, Info CSI 00000764 [SR] Verify complete
2010-05-27 17:34:17, Info CSI 00000765 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:34:17, Info CSI 00000766 [SR] Beginning Verify and Repair transaction
2010-05-27 17:34:31, Info CSI 00000768 [SR] Verify complete
2010-05-27 17:34:32, Info CSI 00000769 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:34:32, Info CSI 0000076a [SR] Beginning Verify and Repair transaction
2010-05-27 17:34:43, Info CSI 0000076d [SR] Verify complete
2010-05-27 17:34:44, Info CSI 0000076e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:34:44, Info CSI 0000076f [SR] Beginning Verify and Repair transaction
2010-05-27 17:34:58, Info CSI 00000773 [SR] Verify complete
2010-05-27 17:34:59, Info CSI 00000774 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:34:59, Info CSI 00000775 [SR] Beginning Verify and Repair transaction
2010-05-27 17:35:14, Info CSI 00000779 [SR] Verify complete
2010-05-27 17:35:14, Info CSI 0000077a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:35:14, Info CSI 0000077b [SR] Beginning Verify and Repair transaction
2010-05-27 17:35:36, Info CSI 0000077d [SR] Verify complete
2010-05-27 17:35:37, Info CSI 0000077e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:35:37, Info CSI 0000077f [SR] Beginning Verify and Repair transaction
2010-05-27 17:36:00, Info CSI 00000781 [SR] Verify complete
2010-05-27 17:36:00, Info CSI 00000782 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:36:00, Info CSI 00000783 [SR] Beginning Verify and Repair transaction
2010-05-27 17:36:08, Info CSI 00000785 [SR] Verify complete
2010-05-27 17:36:09, Info CSI 00000786 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:36:09, Info CSI 00000787 [SR] Beginning Verify and Repair transaction
2010-05-27 17:36:20, Info CSI 00000789 [SR] Verify complete
2010-05-27 17:36:20, Info CSI 0000078a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:36:20, Info CSI 0000078b [SR] Beginning Verify and Repair transaction
2010-05-27 17:36:35, Info CSI 0000078d [SR] Verify complete
2010-05-27 17:36:35, Info CSI 0000078e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:36:35, Info CSI 0000078f [SR] Beginning Verify and Repair transaction
2010-05-27 17:36:52, Info CSI 00000791 [SR] Verify complete
2010-05-27 17:36:52, Info CSI 00000792 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:36:52, Info CSI 00000793 [SR] Beginning Verify and Repair transaction
2010-05-27 17:37:16, Info CSI 00000795 [SR] Verify complete
2010-05-27 17:37:17, Info CSI 00000796 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:37:17, Info CSI 00000797 [SR] Beginning Verify and Repair transaction
2010-05-27 17:37:55, Info CSI 00000799 [SR] Verify complete
2010-05-27 17:37:55, Info CSI 0000079a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:37:55, Info CSI 0000079b [SR] Beginning Verify and Repair transaction
2010-05-27 17:38:09, Info CSI 0000079d [SR] Verify complete
2010-05-27 17:38:09, Info CSI 0000079e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:38:09, Info CSI 0000079f [SR] Beginning Verify and Repair transaction
2010-05-27 17:38:27, Info CSI 000007aa [SR] Verify complete
2010-05-27 17:38:28, Info CSI 000007ab [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:38:28, Info CSI 000007ac [SR] Beginning Verify and Repair transaction
2010-05-27 17:38:45, Info CSI 000007ae [SR] Verify complete
2010-05-27 17:38:45, Info CSI 000007af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:38:45, Info CSI 000007b0 [SR] Beginning Verify and Repair transaction
2010-05-27 17:38:59, Info CSI 000007b2 [SR] Verify complete
2010-05-27 17:38:59, Info CSI 000007b3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:38:59, Info CSI 000007b4 [SR] Beginning Verify and Repair transaction
2010-05-27 17:39:11, Info CSI 000007b6 [SR] Verify complete
2010-05-27 17:39:11, Info CSI 000007b7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:39:11, Info CSI 000007b8 [SR] Beginning Verify and Repair transaction
2010-05-27 17:39:23, Info CSI 000007ba [SR] Verify complete
2010-05-27 17:39:24, Info CSI 000007bb [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:39:24, Info CSI 000007bc [SR] Beginning Verify and Repair transaction
2010-05-27 17:39:26, Info CSI 000007be [SR] Verify complete
2010-05-27 17:39:26, Info CSI 000007bf [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:39:26, Info CSI 000007c0 [SR] Beginning Verify and Repair transaction
2010-05-27 17:39:31, Info CSI 000007c3 [SR] Verify complete
2010-05-27 17:39:31, Info CSI 000007c4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:39:31, Info CSI 000007c5 [SR] Beginning Verify and Repair transaction
2010-05-27 17:39:47, Info CSI 000007cb [SR] Verify complete
2010-05-27 17:39:47, Info CSI 000007cc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:39:47, Info CSI 000007cd [SR] Beginning Verify and Repair transaction
2010-05-27 17:39:57, Info CSI 000007cf [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:40:26, Info CSI 000007d3 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:40:26, Info CSI 000007d4 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:40:30, Info CSI 000007da [SR] Verify complete
2010-05-27 17:40:30, Info CSI 000007db [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:40:30, Info CSI 000007dc [SR] Beginning Verify and Repair transaction
2010-05-27 17:40:48, Info CSI 000007e8 [SR] Verify complete
2010-05-27 17:40:48, Info CSI 000007e9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:40:48, Info CSI 000007ea [SR] Beginning Verify and Repair transaction
2010-05-27 17:40:57, Info CSI 000007ec [SR] Verify complete
2010-05-27 17:40:58, Info CSI 000007ed [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:40:58, Info CSI 000007ee [SR] Beginning Verify and Repair transaction
2010-05-27 17:41:09, Info CSI 000007f0 [SR] Verify complete
2010-05-27 17:41:09, Info CSI 000007f1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:41:09, Info CSI 000007f2 [SR] Beginning Verify and Repair transaction
2010-05-27 17:41:21, Info CSI 000007f7 [SR] Verify complete
2010-05-27 17:41:21, Info CSI 000007f8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:41:21, Info CSI 000007f9 [SR] Beginning Verify and Repair transaction
2010-05-27 17:41:33, Info CSI 0000080f [SR] Verify complete
2010-05-27 17:41:33, Info CSI 00000810 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:41:33, Info CSI 00000811 [SR] Beginning Verify and Repair transaction
2010-05-27 17:41:45, Info CSI 00000822 [SR] Verify complete
2010-05-27 17:41:45, Info CSI 00000823 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:41:45, Info CSI 00000824 [SR] Beginning Verify and Repair transaction
2010-05-27 17:41:53, Info CSI 00000826 [SR] Verify complete
2010-05-27 17:41:54, Info CSI 00000827 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:41:54, Info CSI 00000828 [SR] Beginning Verify and Repair transaction
2010-05-27 17:42:04, Info CSI 0000082a [SR] Verify complete
2010-05-27 17:42:05, Info CSI 0000082b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:42:05, Info CSI 0000082c [SR] Beginning Verify and Repair transaction
2010-05-27 17:42:18, Info CSI 0000083d [SR] Verify complete
2010-05-27 17:42:19, Info CSI 0000083e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:42:19, Info CSI 0000083f [SR] Beginning Verify and Repair transaction
2010-05-27 17:42:43, Info CSI 00000841 [SR] Verify complete
2010-05-27 17:42:43, Info CSI 00000842 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:42:43, Info CSI 00000843 [SR] Beginning Verify and Repair transaction
2010-05-27 17:43:02, Info CSI 00000851 [SR] Verify complete
2010-05-27 17:43:02, Info CSI 00000852 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:43:02, Info CSI 00000853 [SR] Beginning Verify and Repair transaction
2010-05-27 17:43:11, Info CSI 00000855 [SR] Verify complete
2010-05-27 17:43:11, Info CSI 00000856 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:43:11, Info CSI 00000857 [SR] Beginning Verify and Repair transaction
2010-05-27 17:43:29, Info CSI 0000085a [SR] Verify complete
2010-05-27 17:43:29, Info CSI 0000085b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:43:29, Info CSI 0000085c [SR] Beginning Verify and Repair transaction
2010-05-27 17:43:41, Info CSI 0000085e [SR] Verify complete
2010-05-27 17:43:41, Info CSI 0000085f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:43:41, Info CSI 00000860 [SR] Beginning Verify and Repair transaction
2010-05-27 17:43:59, Info CSI 00000862 [SR] Verify complete
2010-05-27 17:44:00, Info CSI 00000863 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:44:00, Info CSI 00000864 [SR] Beginning Verify and Repair transaction
2010-05-27 17:44:09, Info CSI 00000866 [SR] Verify complete
2010-05-27 17:44:10, Info CSI 00000867 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:44:10, Info CSI 00000868 [SR] Beginning Verify and Repair transaction
2010-05-27 17:44:23, Info CSI 0000086c [SR] Verify complete
2010-05-27 17:44:23, Info CSI 0000086d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:44:23, Info CSI 0000086e [SR] Beginning Verify and Repair transaction
2010-05-27 17:44:40, Info CSI 00000888 [SR] Verify complete
2010-05-27 17:44:41, Info CSI 00000889 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:44:41, Info CSI 0000088a [SR] Beginning Verify and Repair transaction
2010-05-27 17:45:22, Info CSI 0000088c [SR] Verify complete
2010-05-27 17:45:22, Info CSI 0000088d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:45:22, Info CSI 0000088e [SR] Beginning Verify and Repair transaction
2010-05-27 17:45:30, Info CSI 00000890 [SR] Verify complete
2010-05-27 17:45:30, Info CSI 00000891 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:45:30, Info CSI 00000892 [SR] Beginning Verify and Repair transaction
2010-05-27 17:45:42, Info CSI 00000894 [SR] Verify complete
2010-05-27 17:45:42, Info CSI 00000895 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:45:42, Info CSI 00000896 [SR] Beginning Verify and Repair transaction
2010-05-27 17:45:56, Info CSI 00000898 [SR] Verify complete
2010-05-27 17:45:56, Info CSI 00000899 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:45:56, Info CSI 0000089a [SR] Beginning Verify and Repair transaction
2010-05-27 17:46:28, Info CSI 0000089d [SR] Verify complete
2010-05-27 17:46:28, Info CSI 0000089e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:46:28, Info CSI 0000089f [SR] Beginning Verify and Repair transaction
2010-05-27 17:46:49, Info CSI 000008a1 [SR] Verify complete
2010-05-27 17:46:50, Info CSI 000008a2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:46:50, Info CSI 000008a3 [SR] Beginning Verify and Repair transaction
2010-05-27 17:47:06, Info CSI 000008a5 [SR] Verify complete
2010-05-27 17:47:06, Info CSI 000008a6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:47:06, Info CSI 000008a7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:47:18, Info CSI 000008a9 [SR] Verify complete
2010-05-27 17:47:18, Info CSI 000008aa [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:47:18, Info CSI 000008ab [SR] Beginning Verify and Repair transaction
2010-05-27 17:47:33, Info CSI 000008ae [SR] Verify complete
2010-05-27 17:47:33, Info CSI 000008af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:47:33, Info CSI 000008b0 [SR] Beginning Verify and Repair transaction
2010-05-27 17:47:45, Info CSI 000008b2 [SR] Verify complete
2010-05-27 17:47:45, Info CSI 000008b3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:47:45, Info CSI 000008b4 [SR] Beginning Verify and Repair transaction
2010-05-27 17:48:00, Info CSI 000008b8 [SR] Verify complete
2010-05-27 17:48:00, Info CSI 000008b9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:48:00, Info CSI 000008ba [SR] Beginning Verify and Repair transaction
2010-05-27 17:48:13, Info CSI 000008bc [SR] Verify complete
2010-05-27 17:48:14, Info CSI 000008bd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:48:14, Info CSI 000008be [SR] Beginning Verify and Repair transaction
2010-05-27 17:48:23, Info CSI 000008c1 [SR] Verify complete
2010-05-27 17:48:23, Info CSI 000008c2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:48:23, Info CSI 000008c3 [SR] Beginning Verify and Repair transaction
2010-05-27 17:48:35, Info CSI 000008c5 [SR] Verify complete
2010-05-27 17:48:36, Info CSI 000008c6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:48:36, Info CSI 000008c7 [SR] Beginning Verify and Repair transaction
2010-05-27 17:48:48, Info CSI 000008c9 [SR] Verify complete
2010-05-27 17:48:49, Info CSI 000008ca [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 17:48:49, Info CSI 000008cb [SR] Beginning Verify and Repair transaction
2010-05-27 17:49:04, Info CSI 000008cd [SR] Verify complete
2010-05-27 17:49:04, Info CSI 000008ce [SR] Verifying 25 (0x0000000000000019) components
2010-05-27 17:49:04, Info CSI 000008cf [SR] Beginning Verify and Repair transaction
2010-05-27 17:49:06, Info CSI 000008d1 [SR] Verify complete
2010-05-27 17:49:06, Info CSI 000008d2 [SR] Repairing 2 components
2010-05-27 17:49:06, Info CSI 000008d3 [SR] Beginning Verify and Repair transaction
2010-05-27 17:49:07, Info CSI 000008d5 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:49:07, Info CSI 000008d7 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:49:07, Info CSI 000008d9 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:49:07, Info CSI 000008da [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:49:07, Info CSI 000008dc [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 17:49:07, Info CSI 000008dd [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 17:49:07, Info CSI 000008df [SR] Repair complete
2010-05-27 17:49:07, Info CSI 000008e0 [SR] Committing transaction
2010-05-27 17:49:07, Info CSI 000008e4 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2010-05-27 19:46:06, Info CSI 00000006 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:06, Info CSI 00000007 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:08, Info CSI 00000009 [SR] Verify complete
2010-05-27 19:46:08, Info CSI 0000000a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:08, Info CSI 0000000b [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:10, Info CSI 0000000d [SR] Verify complete
2010-05-27 19:46:10, Info CSI 0000000e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:10, Info CSI 0000000f [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:11, Info CSI 00000011 [SR] Verify complete
2010-05-27 19:46:11, Info CSI 00000012 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:11, Info CSI 00000013 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:13, Info CSI 00000015 [SR] Verify complete
2010-05-27 19:46:13, Info CSI 00000016 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:13, Info CSI 00000017 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:15, Info CSI 00000019 [SR] Verify complete
2010-05-27 19:46:15, Info CSI 0000001a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:15, Info CSI 0000001b [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:17, Info CSI 0000001d [SR] Verify complete
2010-05-27 19:46:17, Info CSI 0000001e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:17, Info CSI 0000001f [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:18, Info CSI 00000021 [SR] Verify complete
2010-05-27 19:46:19, Info CSI 00000022 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:19, Info CSI 00000023 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:20, Info CSI 00000025 [SR] Verify complete
2010-05-27 19:46:20, Info CSI 00000026 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:20, Info CSI 00000027 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:22, Info CSI 00000029 [SR] Verify complete
2010-05-27 19:46:22, Info CSI 0000002a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:22, Info CSI 0000002b [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:24, Info CSI 0000002d [SR] Verify complete
2010-05-27 19:46:24, Info CSI 0000002e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:24, Info CSI 0000002f [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:25, Info CSI 00000031 [SR] Verify complete
2010-05-27 19:46:26, Info CSI 00000032 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:26, Info CSI 00000033 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:27, Info CSI 00000035 [SR] Verify complete
2010-05-27 19:46:27, Info CSI 00000036 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:27, Info CSI 00000037 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:29, Info CSI 00000039 [SR] Verify complete
2010-05-27 19:46:29, Info CSI 0000003a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:29, Info CSI 0000003b [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:30, Info CSI 0000003d [SR] Verify complete
2010-05-27 19:46:31, Info CSI 0000003e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:31, Info CSI 0000003f [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:32, Info CSI 00000041 [SR] Verify complete
2010-05-27 19:46:32, Info CSI 00000042 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:32, Info CSI 00000043 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:35, Info CSI 00000045 [SR] Verify complete
2010-05-27 19:46:35, Info CSI 00000046 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:35, Info CSI 00000047 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:38, Info CSI 00000049 [SR] Verify complete
2010-05-27 19:46:39, Info CSI 0000004a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:39, Info CSI 0000004b [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:40, Info CSI 0000004d [SR] Verify complete
2010-05-27 19:46:41, Info CSI 0000004e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:41, Info CSI 0000004f [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:43, Info CSI 00000051 [SR] Verify complete
2010-05-27 19:46:44, Info CSI 00000052 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:44, Info CSI 00000053 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:46, Info CSI 00000055 [SR] Verify complete
2010-05-27 19:46:46, Info CSI 00000056 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:46, Info CSI 00000057 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:48, Info CSI 00000059 [SR] Verify complete
2010-05-27 19:46:48, Info CSI 0000005a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:48, Info CSI 0000005b [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:51, Info CSI 0000005d [SR] Verify complete
2010-05-27 19:46:51, Info CSI 0000005e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:51, Info CSI 0000005f [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:53, Info CSI 00000061 [SR] Verify complete
2010-05-27 19:46:53, Info CSI 00000062 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:53, Info CSI 00000063 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:55, Info CSI 00000065 [SR] Verify complete
2010-05-27 19:46:55, Info CSI 00000066 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:55, Info CSI 00000067 [SR] Beginning Verify and Repair transaction
2010-05-27 19:46:58, Info CSI 00000069 [SR] Verify complete
2010-05-27 19:46:58, Info CSI 0000006a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:46:58, Info CSI 0000006b [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:05, Info CSI 0000006d [SR] Verify complete
2010-05-27 19:47:05, Info CSI 0000006e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:05, Info CSI 0000006f [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:09, Info CSI 00000072 [SR] Verify complete
2010-05-27 19:47:09, Info CSI 00000073 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:09, Info CSI 00000074 [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:17, Info CSI 00000078 [SR] Verify complete
2010-05-27 19:47:17, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:17, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:24, Info CSI 0000007e [SR] Verify complete
2010-05-27 19:47:24, Info CSI 0000007f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:24, Info CSI 00000080 [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:29, Info CSI 00000082 [SR] Verify complete
2010-05-27 19:47:29, Info CSI 00000083 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:29, Info CSI 00000084 [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:37, Info CSI 00000092 [SR] Verify complete
2010-05-27 19:47:37, Info CSI 00000093 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:37, Info CSI 00000094 [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:45, Info CSI 000000ad [SR] Verify complete
2010-05-27 19:47:45, Info CSI 000000ae [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:45, Info CSI 000000af [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:52, Info CSI 000000b1 [SR] Verify complete
2010-05-27 19:47:52, Info CSI 000000b2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:52, Info CSI 000000b3 [SR] Beginning Verify and Repair transaction
2010-05-27 19:47:57, Info CSI 000000b5 [SR] Verify complete
2010-05-27 19:47:57, Info CSI 000000b6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:47:57, Info CSI 000000b7 [SR] Beginning Verify and Repair transaction
2010-05-27 19:48:07, Info CSI 000000b9 [SR] Verify complete
2010-05-27 19:48:07, Info CSI 000000ba [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:48:07, Info CSI 000000bb [SR] Beginning Verify and Repair transaction
2010-05-27 19:48:16, Info CSI 000000bd [SR] Verify complete
2010-05-27 19:48:16, Info CSI 000000be [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:48:16, Info CSI 000000bf [SR] Beginning Verify and Repair transaction
2010-05-27 19:48:29, Info CSI 000000d7 [SR] Verify complete
2010-05-27 19:48:29, Info CSI 000000d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:48:29, Info CSI 000000d9 [SR] Beginning Verify and Repair transaction
2010-05-27 19:48:47, Info CSI 000000db [SR] Verify complete
2010-05-27 19:48:47, Info CSI 000000dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:48:47, Info CSI 000000dd [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:03, Info CSI 000000df [SR] Verify complete
2010-05-27 19:49:03, Info CSI 000000e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:03, Info CSI 000000e1 [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:08, Info CSI 000000e3 [SR] Verify complete
2010-05-27 19:49:09, Info CSI 000000e4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:09, Info CSI 000000e5 [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:12, Info CSI 000000e7 [SR] Verify complete
2010-05-27 19:49:13, Info CSI 000000e8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:13, Info CSI 000000e9 [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:17, Info CSI 000000eb [SR] Verify complete
2010-05-27 19:49:17, Info CSI 000000ec [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:17, Info CSI 000000ed [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:31, Info CSI 00000100 [SR] Verify complete
2010-05-27 19:49:31, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:31, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:32, Info CSI 00000104 [SR] Verify complete
2010-05-27 19:49:33, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:33, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:39, Info CSI 00000108 [SR] Verify complete
2010-05-27 19:49:40, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:40, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:46, Info CSI 0000010c [SR] Verify complete
2010-05-27 19:49:46, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:46, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2010-05-27 19:49:58, Info CSI 00000110 [SR] Verify complete
2010-05-27 19:49:58, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:49:58, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2010-05-27 19:50:07, Info CSI 00000114 [SR] Verify complete
2010-05-27 19:50:07, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:50:07, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2010-05-27 19:50:12, Info CSI 00000118 [SR] Verify complete
2010-05-27 19:50:12, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:50:12, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2010-05-27 19:50:24, Info CSI 0000011c [SR] Verify complete
2010-05-27 19:50:24, Info CSI 0000011d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:50:24, Info CSI 0000011e [SR] Beginning Verify and Repair transaction
2010-05-27 19:50:32, Info CSI 00000120 [SR] Verify complete
2010-05-27 19:50:32, Info CSI 00000121 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:50:32, Info CSI 00000122 [SR] Beginning Verify and Repair transaction
2010-05-27 19:50:46, Info CSI 00000135 [SR] Verify complete
2010-05-27 19:50:46, Info CSI 00000136 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:50:46, Info CSI 00000137 [SR] Beginning Verify and Repair transaction
2010-05-27 19:50:59, Info CSI 0000013e [SR] Verify complete
2010-05-27 19:50:59, Info CSI 0000013f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:50:59, Info CSI 00000140 [SR] Beginning Verify and Repair transaction
2010-05-27 19:51:24, Info CSI 00000142 [SR] Verify complete
2010-05-27 19:51:25, Info CSI 00000143 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:51:25, Info CSI 00000144 [SR] Beginning Verify and Repair transaction
2010-05-27 19:51:40, Info CSI 00000146 [SR] Verify complete
2010-05-27 19:51:40, Info CSI 00000147 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:51:40, Info CSI 00000148 [SR] Beginning Verify and Repair transaction
2010-05-27 19:51:52, Info CSI 0000014a [SR] Verify complete
2010-05-27 19:51:52, Info CSI 0000014b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:51:52, Info CSI 0000014c [SR] Beginning Verify and Repair transaction
2010-05-27 19:52:03, Info CSI 0000014e [SR] Verify complete
2010-05-27 19:52:03, Info CSI 0000014f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:52:03, Info CSI 00000150 [SR] Beginning Verify and Repair transaction
2010-05-27 19:52:11, Info CSI 00000152 [SR] Verify complete
2010-05-27 19:52:12, Info CSI 00000153 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:52:12, Info CSI 00000154 [SR] Beginning Verify and Repair transaction
2010-05-27 19:52:20, Info CSI 00000158 [SR] Verify complete
2010-05-27 19:52:20, Info CSI 00000159 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:52:20, Info CSI 0000015a [SR] Beginning Verify and Repair transaction
2010-05-27 19:52:31, Info CSI 0000015c [SR] Verify complete
2010-05-27 19:52:31, Info CSI 0000015d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:52:31, Info CSI 0000015e [SR] Beginning Verify and Repair transaction
2010-05-27 19:52:42, Info CSI 00000160 [SR] Verify complete
2010-05-27 19:52:42, Info CSI 00000161 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:52:42, Info CSI 00000162 [SR] Beginning Verify and Repair transaction
2010-05-27 19:52:50, Info CSI 00000164 [SR] Verify complete
2010-05-27 19:52:50, Info CSI 00000165 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:52:50, Info CSI 00000166 [SR] Beginning Verify and Repair transaction
2010-05-27 19:53:01, Info CSI 00000168 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 19:53:03, Info CSI 0000016a [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 19:53:03, Info CSI 0000016b [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 19:53:04, Info CSI 0000016d [SR] Verify complete
2010-05-27 19:53:04, Info CSI 0000016e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:53:04, Info CSI 0000016f [SR] Beginning Verify and Repair transaction
2010-05-27 19:53:13, Info CSI 00000171 [SR] Verify complete
2010-05-27 19:53:13, Info CSI 00000172 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:53:13, Info CSI 00000173 [SR] Beginning Verify and Repair transaction
2010-05-27 19:53:25, Info CSI 00000175 [SR] Verify complete
2010-05-27 19:53:26, Info CSI 00000176 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:53:26, Info CSI 00000177 [SR] Beginning Verify and Repair transaction
2010-05-27 19:53:39, Info CSI 0000017a [SR] Verify complete
2010-05-27 19:53:40, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:53:40, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2010-05-27 19:53:50, Info CSI 0000017e [SR] Verify complete
2010-05-27 19:53:50, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:53:50, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2010-05-27 19:53:56, Info CSI 00000183 [SR] Verify complete
2010-05-27 19:53:57, Info CSI 00000184 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:53:57, Info CSI 00000185 [SR] Beginning Verify and Repair transaction
2010-05-27 19:54:06, Info CSI 00000189 [SR] Verify complete
2010-05-27 19:54:07, Info CSI 0000018a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:54:07, Info CSI 0000018b [SR] Beginning Verify and Repair transaction
2010-05-27 19:54:15, Info CSI 0000018f [SR] Verify complete
2010-05-27 19:54:15, Info CSI 00000190 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:54:15, Info CSI 00000191 [SR] Beginning Verify and Repair transaction
2010-05-27 19:54:26, Info CSI 00000193 [SR] Verify complete
2010-05-27 19:54:26, Info CSI 00000194 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:54:26, Info CSI 00000195 [SR] Beginning Verify and Repair transaction
2010-05-27 19:54:40, Info CSI 00000197 [SR] Verify complete
2010-05-27 19:54:40, Info CSI 00000198 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:54:40, Info CSI 00000199 [SR] Beginning Verify and Repair transaction
2010-05-27 19:54:43, Info CSI 0000019b [SR] Verify complete
2010-05-27 19:54:44, Info CSI 0000019c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:54:44, Info CSI 0000019d [SR] Beginning Verify and Repair transaction
2010-05-27 19:54:52, Info CSI 0000019f [SR] Verify complete
2010-05-27 19:54:52, Info CSI 000001a0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:54:52, Info CSI 000001a1 [SR] Beginning Verify and Repair transaction
2010-05-27 19:55:02, Info CSI 000001a3 [SR] Verify complete
2010-05-27 19:55:02, Info CSI 000001a4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:55:02, Info CSI 000001a5 [SR] Beginning Verify and Repair transaction
2010-05-27 19:55:12, Info CSI 000001a7 [SR] Verify complete
2010-05-27 19:55:12, Info CSI 000001a8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:55:12, Info CSI 000001a9 [SR] Beginning Verify and Repair transaction
2010-05-27 19:55:24, Info CSI 000001ab [SR] Verify complete
2010-05-27 19:55:24, Info CSI 000001ac [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:55:24, Info CSI 000001ad [SR] Beginning Verify and Repair transaction
2010-05-27 19:55:46, Info CSI 000001af [SR] Verify complete
2010-05-27 19:55:46, Info CSI 000001b0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:55:46, Info CSI 000001b1 [SR] Beginning Verify and Repair transaction
2010-05-27 19:55:54, Info CSI 000001b3 [SR] Verify complete
2010-05-27 19:55:54, Info CSI 000001b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:55:54, Info CSI 000001b5 [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:06, Info CSI 000001c0 [SR] Verify complete
2010-05-27 19:56:07, Info CSI 000001c1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:07, Info CSI 000001c2 [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:14, Info CSI 000001c4 [SR] Verify complete
2010-05-27 19:56:14, Info CSI 000001c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:14, Info CSI 000001c6 [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:23, Info CSI 000001c8 [SR] Verify complete
2010-05-27 19:56:23, Info CSI 000001c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:23, Info CSI 000001ca [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:31, Info CSI 000001cc [SR] Verify complete
2010-05-27 19:56:32, Info CSI 000001cd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:32, Info CSI 000001ce [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:42, Info CSI 000001d0 [SR] Verify complete
2010-05-27 19:56:43, Info CSI 000001d1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:43, Info CSI 000001d2 [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:46, Info CSI 000001d4 [SR] Verify complete
2010-05-27 19:56:46, Info CSI 000001d5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:46, Info CSI 000001d6 [SR] Beginning Verify and Repair transaction
2010-05-27 19:56:50, Info CSI 000001d9 [SR] Verify complete
2010-05-27 19:56:50, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:56:50, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:01, Info CSI 000001e1 [SR] Verify complete
2010-05-27 19:57:02, Info CSI 000001e2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:02, Info CSI 000001e3 [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:06, Info CSI 000001e5 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 19:57:15, Info CSI 000001e9 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 19:57:15, Info CSI 000001ea [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 19:57:18, Info CSI 000001f0 [SR] Verify complete
2010-05-27 19:57:18, Info CSI 000001f1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:18, Info CSI 000001f2 [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:28, Info CSI 000001fe [SR] Verify complete
2010-05-27 19:57:28, Info CSI 000001ff [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:28, Info CSI 00000200 [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:33, Info CSI 00000202 [SR] Verify complete
2010-05-27 19:57:34, Info CSI 00000203 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:34, Info CSI 00000204 [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:40, Info CSI 00000206 [SR] Verify complete
2010-05-27 19:57:40, Info CSI 00000207 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:40, Info CSI 00000208 [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:46, Info CSI 0000020d [SR] Verify complete
2010-05-27 19:57:46, Info CSI 0000020e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:46, Info CSI 0000020f [SR] Beginning Verify and Repair transaction
2010-05-27 19:57:54, Info CSI 00000225 [SR] Verify complete
2010-05-27 19:57:54, Info CSI 00000226 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:57:54, Info CSI 00000227 [SR] Beginning Verify and Repair transaction
2010-05-27 19:58:01, Info CSI 00000238 [SR] Verify complete
2010-05-27 19:58:01, Info CSI 00000239 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:58:01, Info CSI 0000023a [SR] Beginning Verify and Repair transaction
2010-05-27 19:58:07, Info CSI 0000023c [SR] Verify complete
2010-05-27 19:58:07, Info CSI 0000023d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:58:07, Info CSI 0000023e [SR] Beginning Verify and Repair transaction
2010-05-27 19:58:16, Info CSI 00000240 [SR] Verify complete
2010-05-27 19:58:16, Info CSI 00000241 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:58:16, Info CSI 00000242 [SR] Beginning Verify and Repair transaction
2010-05-27 19:58:25, Info CSI 00000253 [SR] Verify complete
2010-05-27 19:58:26, Info CSI 00000254 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:58:26, Info CSI 00000255 [SR] Beginning Verify and Repair transaction
2010-05-27 19:58:47, Info CSI 00000257 [SR] Verify complete
2010-05-27 19:58:47, Info CSI 00000258 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:58:47, Info CSI 00000259 [SR] Beginning Verify and Repair transaction
2010-05-27 19:58:58, Info CSI 00000267 [SR] Verify complete
2010-05-27 19:58:59, Info CSI 00000268 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:58:59, Info CSI 00000269 [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:05, Info CSI 0000026b [SR] Verify complete
2010-05-27 19:59:05, Info CSI 0000026c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:05, Info CSI 0000026d [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:15, Info CSI 00000270 [SR] Verify complete
2010-05-27 19:59:15, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:15, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:21, Info CSI 00000274 [SR] Verify complete
2010-05-27 19:59:21, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:21, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:31, Info CSI 00000278 [SR] Verify complete
2010-05-27 19:59:31, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:31, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:38, Info CSI 0000027c [SR] Verify complete
2010-05-27 19:59:38, Info CSI 0000027d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:38, Info CSI 0000027e [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:48, Info CSI 00000282 [SR] Verify complete
2010-05-27 19:59:48, Info CSI 00000283 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:48, Info CSI 00000284 [SR] Beginning Verify and Repair transaction
2010-05-27 19:59:58, Info CSI 0000029e [SR] Verify complete
2010-05-27 19:59:58, Info CSI 0000029f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 19:59:58, Info CSI 000002a0 [SR] Beginning Verify and Repair transaction
2010-05-27 20:00:22, Info CSI 000002a2 [SR] Verify complete
2010-05-27 20:00:22, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:00:22, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
2010-05-27 20:00:30, Info CSI 000002a6 [SR] Verify complete
2010-05-27 20:00:30, Info CSI 000002a7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:00:30, Info CSI 000002a8 [SR] Beginning Verify and Repair transaction
2010-05-27 20:00:38, Info CSI 000002aa [SR] Verify complete
2010-05-27 20:00:38, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:00:38, Info CSI 000002ac [SR] Beginning Verify and Repair transaction
2010-05-27 20:00:45, Info CSI 000002ae [SR] Verify complete
2010-05-27 20:00:45, Info CSI 000002af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:00:45, Info CSI 000002b0 [SR] Beginning Verify and Repair transaction
2010-05-27 20:00:56, Info CSI 000002b3 [SR] Verify complete
2010-05-27 20:00:56, Info CSI 000002b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:00:56, Info CSI 000002b5 [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:05, Info CSI 000002b7 [SR] Verify complete
2010-05-27 20:01:05, Info CSI 000002b8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:05, Info CSI 000002b9 [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:12, Info CSI 000002bb [SR] Verify complete
2010-05-27 20:01:13, Info CSI 000002bc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:13, Info CSI 000002bd [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:18, Info CSI 000002bf [SR] Verify complete
2010-05-27 20:01:19, Info CSI 000002c0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:19, Info CSI 000002c1 [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:27, Info CSI 000002c4 [SR] Verify complete
2010-05-27 20:01:27, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:27, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:34, Info CSI 000002c8 [SR] Verify complete
2010-05-27 20:01:34, Info CSI 000002c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:34, Info CSI 000002ca [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:43, Info CSI 000002ce [SR] Verify complete
2010-05-27 20:01:44, Info CSI 000002cf [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:44, Info CSI 000002d0 [SR] Beginning Verify and Repair transaction
2010-05-27 20:01:53, Info CSI 000002d2 [SR] Verify complete
2010-05-27 20:01:53, Info CSI 000002d3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:01:53, Info CSI 000002d4 [SR] Beginning Verify and Repair transaction
2010-05-27 20:02:02, Info CSI 000002d7 [SR] Verify complete
2010-05-27 20:02:02, Info CSI 000002d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:02:02, Info CSI 000002d9 [SR] Beginning Verify and Repair transaction
2010-05-27 20:02:09, Info CSI 000002db [SR] Verify complete
2010-05-27 20:02:10, Info CSI 000002dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:02:10, Info CSI 000002dd [SR] Beginning Verify and Repair transaction
2010-05-27 20:02:18, Info CSI 000002df [SR] Verify complete
2010-05-27 20:02:18, Info CSI 000002e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 20:02:18, Info CSI 000002e1 [SR] Beginning Verify and Repair transaction
2010-05-27 20:02:27, Info CSI 000002e3 [SR] Verify complete
2010-05-27 20:02:27, Info CSI 000002e4 [SR] Verifying 25 (0x0000000000000019) components
2010-05-27 20:02:27, Info CSI 000002e5 [SR] Beginning Verify and Repair transaction
2010-05-27 20:02:28, Info CSI 000002e7 [SR] Verify complete
2010-05-27 20:02:28, Info CSI 000002e8 [SR] Repairing 2 components
2010-05-27 20:02:28, Info CSI 000002e9 [SR] Beginning Verify and Repair transaction
2010-05-27 20:02:28, Info CSI 000002eb [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 20:02:28, Info CSI 000002ed [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 20:02:28, Info CSI 000002ef [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 20:02:28, Info CSI 000002f0 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 20:02:29, Info CSI 000002f2 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 20:02:29, Info CSI 000002f3 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 20:02:29, Info CSI 000002f5 [SR] Repair complete
2010-05-27 20:02:29, Info CSI 000002f6 [SR] Committing transaction
2010-05-27 20:02:29, Info CSI 000002fa [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
2010-05-27 23:27:03, Info CSI 00000006 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:03, Info CSI 00000007 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:06, Info CSI 00000009 [SR] Verify complete
2010-05-27 23:27:06, Info CSI 0000000a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:06, Info CSI 0000000b [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:10, Info CSI 0000000d [SR] Verify complete
2010-05-27 23:27:10, Info CSI 0000000e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:10, Info CSI 0000000f [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:13, Info CSI 00000011 [SR] Verify complete
2010-05-27 23:27:13, Info CSI 00000012 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:13, Info CSI 00000013 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:17, Info CSI 00000015 [SR] Verify complete
2010-05-27 23:27:17, Info CSI 00000016 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:17, Info CSI 00000017 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:20, Info CSI 00000019 [SR] Verify complete
2010-05-27 23:27:20, Info CSI 0000001a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:20, Info CSI 0000001b [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:23, Info CSI 0000001d [SR] Verify complete
2010-05-27 23:27:24, Info CSI 0000001e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:24, Info CSI 0000001f [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:26, Info CSI 00000021 [SR] Verify complete
2010-05-27 23:27:27, Info CSI 00000022 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:27, Info CSI 00000023 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:29, Info CSI 00000025 [SR] Verify complete
2010-05-27 23:27:30, Info CSI 00000026 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:30, Info CSI 00000027 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:33, Info CSI 00000029 [SR] Verify complete
2010-05-27 23:27:33, Info CSI 0000002a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:33, Info CSI 0000002b [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:35, Info CSI 0000002d [SR] Verify complete
2010-05-27 23:27:36, Info CSI 0000002e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:36, Info CSI 0000002f [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:38, Info CSI 00000031 [SR] Verify complete
2010-05-27 23:27:38, Info CSI 00000032 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:38, Info CSI 00000033 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:41, Info CSI 00000035 [SR] Verify complete
2010-05-27 23:27:41, Info CSI 00000036 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:41, Info CSI 00000037 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:43, Info CSI 00000039 [SR] Verify complete
2010-05-27 23:27:44, Info CSI 0000003a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:44, Info CSI 0000003b [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:46, Info CSI 0000003d [SR] Verify complete
2010-05-27 23:27:47, Info CSI 0000003e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:47, Info CSI 0000003f [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:49, Info CSI 00000041 [SR] Verify complete
2010-05-27 23:27:49, Info CSI 00000042 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:49, Info CSI 00000043 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:52, Info CSI 00000045 [SR] Verify complete
2010-05-27 23:27:53, Info CSI 00000046 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:53, Info CSI 00000047 [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:56, Info CSI 00000049 [SR] Verify complete
2010-05-27 23:27:56, Info CSI 0000004a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:56, Info CSI 0000004b [SR] Beginning Verify and Repair transaction
2010-05-27 23:27:59, Info CSI 0000004d [SR] Verify complete
2010-05-27 23:27:59, Info CSI 0000004e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:27:59, Info CSI 0000004f [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:02, Info CSI 00000051 [SR] Verify complete
2010-05-27 23:28:02, Info CSI 00000052 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:02, Info CSI 00000053 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:05, Info CSI 00000055 [SR] Verify complete
2010-05-27 23:28:06, Info CSI 00000056 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:06, Info CSI 00000057 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:07, Info CSI 00000059 [SR] Verify complete
2010-05-27 23:28:08, Info CSI 0000005a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:08, Info CSI 0000005b [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:11, Info CSI 0000005d [SR] Verify complete
2010-05-27 23:28:11, Info CSI 0000005e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:11, Info CSI 0000005f [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:13, Info CSI 00000061 [SR] Verify complete
2010-05-27 23:28:14, Info CSI 00000062 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:14, Info CSI 00000063 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:16, Info CSI 00000065 [SR] Verify complete
2010-05-27 23:28:16, Info CSI 00000066 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:16, Info CSI 00000067 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:18, Info CSI 00000069 [SR] Verify complete
2010-05-27 23:28:18, Info CSI 0000006a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:18, Info CSI 0000006b [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:24, Info CSI 0000006d [SR] Verify complete
2010-05-27 23:28:25, Info CSI 0000006e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:25, Info CSI 0000006f [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:29, Info CSI 00000072 [SR] Verify complete
2010-05-27 23:28:29, Info CSI 00000073 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:29, Info CSI 00000074 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:36, Info CSI 00000078 [SR] Verify complete
2010-05-27 23:28:36, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:36, Info CSI 0000007a [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:42, Info CSI 0000007e [SR] Verify complete
2010-05-27 23:28:42, Info CSI 0000007f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:42, Info CSI 00000080 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:47, Info CSI 00000082 [SR] Verify complete
2010-05-27 23:28:47, Info CSI 00000083 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:47, Info CSI 00000084 [SR] Beginning Verify and Repair transaction
2010-05-27 23:28:54, Info CSI 00000092 [SR] Verify complete
2010-05-27 23:28:54, Info CSI 00000093 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:28:54, Info CSI 00000094 [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:03, Info CSI 000000ad [SR] Verify complete
2010-05-27 23:29:03, Info CSI 000000ae [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:03, Info CSI 000000af [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:09, Info CSI 000000b1 [SR] Verify complete
2010-05-27 23:29:10, Info CSI 000000b2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:10, Info CSI 000000b3 [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:15, Info CSI 000000b5 [SR] Verify complete
2010-05-27 23:29:15, Info CSI 000000b6 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:15, Info CSI 000000b7 [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:22, Info CSI 000000b9 [SR] Verify complete
2010-05-27 23:29:22, Info CSI 000000ba [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:22, Info CSI 000000bb [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:30, Info CSI 000000bd [SR] Verify complete
2010-05-27 23:29:31, Info CSI 000000be [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:31, Info CSI 000000bf [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:43, Info CSI 000000d7 [SR] Verify complete
2010-05-27 23:29:44, Info CSI 000000d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:44, Info CSI 000000d9 [SR] Beginning Verify and Repair transaction
2010-05-27 23:29:58, Info CSI 000000db [SR] Verify complete
2010-05-27 23:29:58, Info CSI 000000dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:29:58, Info CSI 000000dd [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:11, Info CSI 000000df [SR] Verify complete
2010-05-27 23:30:12, Info CSI 000000e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:12, Info CSI 000000e1 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:15, Info CSI 000000e3 [SR] Verify complete
2010-05-27 23:30:15, Info CSI 000000e4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:15, Info CSI 000000e5 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:17, Info CSI 000000e7 [SR] Verify complete
2010-05-27 23:30:17, Info CSI 000000e8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:17, Info CSI 000000e9 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:20, Info CSI 000000eb [SR] Verify complete
2010-05-27 23:30:20, Info CSI 000000ec [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:20, Info CSI 000000ed [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:31, Info CSI 00000100 [SR] Verify complete
2010-05-27 23:30:31, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:31, Info CSI 00000102 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:32, Info CSI 00000104 [SR] Verify complete
2010-05-27 23:30:32, Info CSI 00000105 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:32, Info CSI 00000106 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:35, Info CSI 00000108 [SR] Verify complete
2010-05-27 23:30:36, Info CSI 00000109 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:36, Info CSI 0000010a [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:39, Info CSI 0000010c [SR] Verify complete
2010-05-27 23:30:40, Info CSI 0000010d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:40, Info CSI 0000010e [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:50, Info CSI 00000110 [SR] Verify complete
2010-05-27 23:30:50, Info CSI 00000111 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:50, Info CSI 00000112 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:56, Info CSI 00000114 [SR] Verify complete
2010-05-27 23:30:56, Info CSI 00000115 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:56, Info CSI 00000116 [SR] Beginning Verify and Repair transaction
2010-05-27 23:30:59, Info CSI 00000118 [SR] Verify complete
2010-05-27 23:30:59, Info CSI 00000119 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:30:59, Info CSI 0000011a [SR] Beginning Verify and Repair transaction
2010-05-27 23:31:07, Info CSI 0000011c [SR] Verify complete
2010-05-27 23:31:07, Info CSI 0000011d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:31:07, Info CSI 0000011e [SR] Beginning Verify and Repair transaction
2010-05-27 23:31:12, Info CSI 00000120 [SR] Verify complete
2010-05-27 23:31:12, Info CSI 00000121 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:31:12, Info CSI 00000122 [SR] Beginning Verify and Repair transaction
2010-05-27 23:31:23, Info CSI 00000135 [SR] Verify complete
2010-05-27 23:31:23, Info CSI 00000136 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:31:23, Info CSI 00000137 [SR] Beginning Verify and Repair transaction
2010-05-27 23:31:34, Info CSI 0000013e [SR] Verify complete
2010-05-27 23:31:34, Info CSI 0000013f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:31:34, Info CSI 00000140 [SR] Beginning Verify and Repair transaction
2010-05-27 23:31:52, Info CSI 00000142 [SR] Verify complete
2010-05-27 23:31:53, Info CSI 00000143 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:31:53, Info CSI 00000144 [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:04, Info CSI 00000146 [SR] Verify complete
2010-05-27 23:32:04, Info CSI 00000147 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:04, Info CSI 00000148 [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:11, Info CSI 0000014a [SR] Verify complete
2010-05-27 23:32:11, Info CSI 0000014b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:11, Info CSI 0000014c [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:18, Info CSI 0000014e [SR] Verify complete
2010-05-27 23:32:18, Info CSI 0000014f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:18, Info CSI 00000150 [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:24, Info CSI 00000152 [SR] Verify complete
2010-05-27 23:32:24, Info CSI 00000153 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:24, Info CSI 00000154 [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:30, Info CSI 00000158 [SR] Verify complete
2010-05-27 23:32:30, Info CSI 00000159 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:30, Info CSI 0000015a [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:38, Info CSI 0000015c [SR] Verify complete
2010-05-27 23:32:38, Info CSI 0000015d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:38, Info CSI 0000015e [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:46, Info CSI 00000160 [SR] Verify complete
2010-05-27 23:32:46, Info CSI 00000161 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:46, Info CSI 00000162 [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:52, Info CSI 00000164 [SR] Verify complete
2010-05-27 23:32:52, Info CSI 00000165 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:32:52, Info CSI 00000166 [SR] Beginning Verify and Repair transaction
2010-05-27 23:32:59, Info CSI 00000168 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:33:00, Info CSI 0000016a [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:33:00, Info CSI 0000016b [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 23:33:01, Info CSI 0000016d [SR] Verify complete
2010-05-27 23:33:01, Info CSI 0000016e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:01, Info CSI 0000016f [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:09, Info CSI 00000171 [SR] Verify complete
2010-05-27 23:33:09, Info CSI 00000172 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:09, Info CSI 00000173 [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:16, Info CSI 00000175 [SR] Verify complete
2010-05-27 23:33:16, Info CSI 00000176 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:16, Info CSI 00000177 [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:24, Info CSI 0000017a [SR] Verify complete
2010-05-27 23:33:24, Info CSI 0000017b [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:24, Info CSI 0000017c [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:31, Info CSI 0000017e [SR] Verify complete
2010-05-27 23:33:31, Info CSI 0000017f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:31, Info CSI 00000180 [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:36, Info CSI 00000183 [SR] Verify complete
2010-05-27 23:33:36, Info CSI 00000184 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:36, Info CSI 00000185 [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:43, Info CSI 00000189 [SR] Verify complete
2010-05-27 23:33:43, Info CSI 0000018a [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:43, Info CSI 0000018b [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:49, Info CSI 0000018f [SR] Verify complete
2010-05-27 23:33:49, Info CSI 00000190 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:49, Info CSI 00000191 [SR] Beginning Verify and Repair transaction
2010-05-27 23:33:57, Info CSI 00000193 [SR] Verify complete
2010-05-27 23:33:58, Info CSI 00000194 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:33:58, Info CSI 00000195 [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:07, Info CSI 00000197 [SR] Verify complete
2010-05-27 23:34:07, Info CSI 00000198 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:07, Info CSI 00000199 [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:09, Info CSI 0000019b [SR] Verify complete
2010-05-27 23:34:09, Info CSI 0000019c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:09, Info CSI 0000019d [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:15, Info CSI 0000019f [SR] Verify complete
2010-05-27 23:34:15, Info CSI 000001a0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:15, Info CSI 000001a1 [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:24, Info CSI 000001a3 [SR] Verify complete
2010-05-27 23:34:24, Info CSI 000001a4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:24, Info CSI 000001a5 [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:34, Info CSI 000001a7 [SR] Verify complete
2010-05-27 23:34:34, Info CSI 000001a8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:34, Info CSI 000001a9 [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:40, Info CSI 000001ab [SR] Verify complete
2010-05-27 23:34:40, Info CSI 000001ac [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:40, Info CSI 000001ad [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:53, Info CSI 000001af [SR] Verify complete
2010-05-27 23:34:54, Info CSI 000001b0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:54, Info CSI 000001b1 [SR] Beginning Verify and Repair transaction
2010-05-27 23:34:58, Info CSI 000001b3 [SR] Verify complete
2010-05-27 23:34:59, Info CSI 000001b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:34:59, Info CSI 000001b5 [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:08, Info CSI 000001c0 [SR] Verify complete
2010-05-27 23:35:09, Info CSI 000001c1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:09, Info CSI 000001c2 [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:15, Info CSI 000001c4 [SR] Verify complete
2010-05-27 23:35:16, Info CSI 000001c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:16, Info CSI 000001c6 [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:23, Info CSI 000001c8 [SR] Verify complete
2010-05-27 23:35:23, Info CSI 000001c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:23, Info CSI 000001ca [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:31, Info CSI 000001cc [SR] Verify complete
2010-05-27 23:35:31, Info CSI 000001cd [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:31, Info CSI 000001ce [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:40, Info CSI 000001d0 [SR] Verify complete
2010-05-27 23:35:40, Info CSI 000001d1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:40, Info CSI 000001d2 [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:41, Info CSI 000001d4 [SR] Verify complete
2010-05-27 23:35:42, Info CSI 000001d5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:42, Info CSI 000001d6 [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:44, Info CSI 000001d9 [SR] Verify complete
2010-05-27 23:35:44, Info CSI 000001da [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:44, Info CSI 000001db [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:52, Info CSI 000001e1 [SR] Verify complete
2010-05-27 23:35:53, Info CSI 000001e2 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:35:53, Info CSI 000001e3 [SR] Beginning Verify and Repair transaction
2010-05-27 23:35:56, Info CSI 000001e5 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:36:03, Info CSI 000001e9 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:36:03, Info CSI 000001ea [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 23:36:06, Info CSI 000001f0 [SR] Verify complete
2010-05-27 23:36:06, Info CSI 000001f1 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:06, Info CSI 000001f2 [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:15, Info CSI 000001fe [SR] Verify complete
2010-05-27 23:36:15, Info CSI 000001ff [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:15, Info CSI 00000200 [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:19, Info CSI 00000202 [SR] Verify complete
2010-05-27 23:36:20, Info CSI 00000203 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:20, Info CSI 00000204 [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:24, Info CSI 00000206 [SR] Verify complete
2010-05-27 23:36:24, Info CSI 00000207 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:24, Info CSI 00000208 [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:29, Info CSI 0000020d [SR] Verify complete
2010-05-27 23:36:29, Info CSI 0000020e [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:29, Info CSI 0000020f [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:35, Info CSI 00000225 [SR] Verify complete
2010-05-27 23:36:35, Info CSI 00000226 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:35, Info CSI 00000227 [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:41, Info CSI 00000238 [SR] Verify complete
2010-05-27 23:36:41, Info CSI 00000239 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:41, Info CSI 0000023a [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:46, Info CSI 0000023c [SR] Verify complete
2010-05-27 23:36:46, Info CSI 0000023d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:46, Info CSI 0000023e [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:51, Info CSI 00000240 [SR] Verify complete
2010-05-27 23:36:51, Info CSI 00000241 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:51, Info CSI 00000242 [SR] Beginning Verify and Repair transaction
2010-05-27 23:36:56, Info CSI 00000253 [SR] Verify complete
2010-05-27 23:36:57, Info CSI 00000254 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:36:57, Info CSI 00000255 [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:07, Info CSI 00000257 [SR] Verify complete
2010-05-27 23:37:07, Info CSI 00000258 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:07, Info CSI 00000259 [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:15, Info CSI 00000267 [SR] Verify complete
2010-05-27 23:37:15, Info CSI 00000268 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:15, Info CSI 00000269 [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:17, Info CSI 0000026b [SR] Verify complete
2010-05-27 23:37:17, Info CSI 0000026c [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:17, Info CSI 0000026d [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:26, Info CSI 00000270 [SR] Verify complete
2010-05-27 23:37:27, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:27, Info CSI 00000272 [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:31, Info CSI 00000274 [SR] Verify complete
2010-05-27 23:37:31, Info CSI 00000275 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:31, Info CSI 00000276 [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:36, Info CSI 00000278 [SR] Verify complete
2010-05-27 23:37:37, Info CSI 00000279 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:37, Info CSI 0000027a [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:41, Info CSI 0000027c [SR] Verify complete
2010-05-27 23:37:41, Info CSI 0000027d [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:41, Info CSI 0000027e [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:48, Info CSI 00000282 [SR] Verify complete
2010-05-27 23:37:48, Info CSI 00000283 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:48, Info CSI 00000284 [SR] Beginning Verify and Repair transaction
2010-05-27 23:37:55, Info CSI 0000029e [SR] Verify complete
2010-05-27 23:37:55, Info CSI 0000029f [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:37:55, Info CSI 000002a0 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:14, Info CSI 000002a2 [SR] Verify complete
2010-05-27 23:38:14, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:14, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:19, Info CSI 000002a6 [SR] Verify complete
2010-05-27 23:38:20, Info CSI 000002a7 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:20, Info CSI 000002a8 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:25, Info CSI 000002aa [SR] Verify complete
2010-05-27 23:38:25, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:25, Info CSI 000002ac [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:30, Info CSI 000002ae [SR] Verify complete
2010-05-27 23:38:30, Info CSI 000002af [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:30, Info CSI 000002b0 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:36, Info CSI 000002b3 [SR] Verify complete
2010-05-27 23:38:36, Info CSI 000002b4 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:36, Info CSI 000002b5 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:42, Info CSI 000002b7 [SR] Verify complete
2010-05-27 23:38:43, Info CSI 000002b8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:43, Info CSI 000002b9 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:48, Info CSI 000002bb [SR] Verify complete
2010-05-27 23:38:48, Info CSI 000002bc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:48, Info CSI 000002bd [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:51, Info CSI 000002bf [SR] Verify complete
2010-05-27 23:38:52, Info CSI 000002c0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:52, Info CSI 000002c1 [SR] Beginning Verify and Repair transaction
2010-05-27 23:38:57, Info CSI 000002c4 [SR] Verify complete
2010-05-27 23:38:57, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:38:57, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:02, Info CSI 000002c8 [SR] Verify complete
2010-05-27 23:39:02, Info CSI 000002c9 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:39:02, Info CSI 000002ca [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:08, Info CSI 000002ce [SR] Verify complete
2010-05-27 23:39:08, Info CSI 000002cf [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:39:08, Info CSI 000002d0 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:14, Info CSI 000002d2 [SR] Verify complete
2010-05-27 23:39:14, Info CSI 000002d3 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:39:14, Info CSI 000002d4 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:20, Info CSI 000002d7 [SR] Verify complete
2010-05-27 23:39:20, Info CSI 000002d8 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:39:20, Info CSI 000002d9 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:27, Info CSI 000002db [SR] Verify complete
2010-05-27 23:39:27, Info CSI 000002dc [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:39:27, Info CSI 000002dd [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:34, Info CSI 000002df [SR] Verify complete
2010-05-27 23:39:35, Info CSI 000002e0 [SR] Verifying 100 (0x0000000000000064) components
2010-05-27 23:39:35, Info CSI 000002e1 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:42, Info CSI 000002e3 [SR] Verify complete
2010-05-27 23:39:42, Info CSI 000002e4 [SR] Verifying 25 (0x0000000000000019) components
2010-05-27 23:39:42, Info CSI 000002e5 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:44, Info CSI 000002e7 [SR] Verify complete
2010-05-27 23:39:44, Info CSI 000002e8 [SR] Repairing 2 components
2010-05-27 23:39:44, Info CSI 000002e9 [SR] Beginning Verify and Repair transaction
2010-05-27 23:39:44, Info CSI 000002eb [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:39:44, Info CSI 000002ed [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:39:44, Info CSI 000002ef [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:39:44, Info CSI 000002f0 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 23:39:44, Info CSI 000002f2 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-27 23:39:44, Info CSI 000002f3 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2010-05-27 23:39:44, Info CSI 000002f5 [SR] Repair complete
2010-05-27 23:39:44, Info CSI 000002f6 [SR] Committing transaction
2010-05-27 23:39:44, Info CSI 000002fa [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    NVIDIA GeForce 9600M GT
    16"
    1920x1080
    300 GB
Hello,
Thanks for that log. You did it perfectly. However, it is not showing up any corruptions, which means I will have to think of something else to get any sort of lead at all! Give me a few minutes.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello,
Can you please download and install Internet Explorer 8. Please do this even if you have already installed IE8, as this will reinstall all the components, and if you don't already have it installed, then it is definitely worth installing: Internet Explorer 8: Worldwide sites
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello Richard, I was thinking about installing IE7/8 first when I found the problem that the attachment button was not working in any of the web mail sites... However, later I found at the same time the File/Open and File/Save As buttons of some software were not working neither. Reading and searching around, I finally realized the issue is affecting all programs are running in 32 bits. Also, found that a possible cause could be a damaged comdlg32.dll.mui library being used for 32 bits programs in the SysWOW64 directory (64 bits programs uses library in the System32 directory) because IE7 64bits and Office 64 have no problem at all with the File/Open Save As windows.
This means the issue is not related with a specific program but something to do with a windows system file (a DLL or even the registry). I was thinking to replace the comdlg32.dll file in SysWOW64 in case it is corrupted or damaged somehow, but have not found a good copy yet...
Again, any program using 32 bits will no work but the ones are 64 bits based are OK and by clicking in the buttons will no do any action or gine no error message. The only error message I started to get at the same time is related to the "Save Destination As" when you right click in top of any attachment in those web mail sites, in that case, windows is given me the error "Internet Explorer can not download. Interface not compatible".
Thanks for any extra help...
Regards
Luis
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
In the same way, the attachment button does not work in Windows Live Mail...
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
Hello,
I see your point about comdlg32.dll, and I see that it is a global thing, but is not comdlg.dll only for Visual Basic applications, hardly a very serious language? I will upload a copy of comdlg32.dll and comdlg32.dll.mui in a few minutes off my machine, but I am not totally convinced it is the problem, however, we should rule it out.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello,
I have got those files for you. I have got the perfect match, Vista Home Premium x64 SP2 with all updates. I have uploaded the en-US MUI file, can you confirm this is correct?
C:\Windows\SysWOW64\comdlg32.dll
C:\Windows\SysWOW64\en-US\comdlg32.dll.mui
I have had to zip them up because this forum does not allow the upload of .dll and .mui.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello, thanks. Is there any specific procedure to replace these files in my pc or it is just a copy?
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
Also, I have got this pc in Spain so Vista is in Spanish language, is the .mui file you sent still ok to put in the es-ES directory instead the en-US directory?
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
Hello,
The .dll is language inspecific, however, the .mui is not. Therefore, you CANNOT copy the .mui into your en-ES directory, or that little bit of windows will be in English! What you should do is check the file size of the file to be replaced and that of my file. If they are exactly the same (Size, NOT Size on disk) then there is no need for a replace. If however, they vary, in particular if yours is much smaller, then just copy and replace it in. Make sure your keep a backup of the old file, and you may need to take ownership first. I will do this in more details later if necessary. Due to SFC not picking this up, and this being for Visual Basic applications, I do not believe this is the problem, though it will not hurt to check.
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello, I just copied only the .dll because the .mui even though is much smaller than the one you sent, it is equal to the en-US I have... I checked for sizes of the .mui in other lenguages and all of them are similar in size than the one in spanish, the one used in en-US is the only one with that big size.
After copying the .dll and boot, nothing has changed, open/save/save as menus are not working yet.
One interesting thing I noticed is that apparently the vista Style menus are the ones not working, however, the XP style menus are (the only open/save as menus are working are the ones used by IE7 64bits and Office 2003)...
I started to thing also about permissions, because when I hit the Open menu in some cases looks like the system is doing something (very quick) but the open dialog never opens... what do you think?
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
Sorry, I slightly misunderstand what you mean by the XP Style Menus. Do you mean the Windows Classic Look, or am I missing something basic here! Do you mean Windows Aero, the glass effect?
Thanks!
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Again, I cannot guarantee, but I have found a more likely culprit in terms of file corruption. Can you please press open the Command Prompt as I showed you earlier.
  • Type cd %userprofile%\Desktop and press enter.
  • Type dir \PresentationFramework.dll /a h /s > file.txt and press enter.
Let the scan run (about 15-30 minutes max) and paste inline (it should not be too long) the file.txt that has just been created on your Desktop. This will list every occurrence of this file on your hard disk and its exact file size.
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello,
Please see results of the listing below:
Code:
El volumen de la unidad C no tiene etiqueta.
El n£mero de serie del volumen es: 4206-BE2A
Directorio de C:\Program Files\Reference Assemblies\Microsoft\Framework\v3.0
19/02/2009 00:10 4.636.672 PresentationFramework.dll
1 archivos 4.636.672 bytes
Directorio de C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\v3.0
19/02/2009 00:09 5.283.840 PresentationFramework.dll
1 archivos 5.283.840 bytes
Directorio de C:\WINDOWS\assembly\GAC_MSIL\PresentationFramework\3.0.0.0__31bf3856ad364e35
Directorio de C:\WINDOWS\Microsoft.NET\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35
27/05/2010 14:59 6.346.600 PresentationFramework.dll
1 archivos 6.346.600 bytes
Directorio de C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\WPF
18/03/2010 13:16 6.346.600 PresentationFramework.dll
Directorio de C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319\WPF
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6000.16708_none_c8c6bd1a11260fcd
20/06/2008 06:41 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6000.16780_none_c8683b6a116e249d
25/11/2008 05:13 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6000.20864_none_c90b79352a77f1e1
20/06/2008 06:43 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6000.20964_none_c90b7b1b2a77ef08
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6001.18000_none_caa4f78a0e53d8df
21/01/2008 08:21 4.956.160 PresentationFramework.dll
1 archivos 4.956.160 bytes
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6001.18096_none_ca49a9fa0e976c62
20/06/2008 06:47 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6001.18173_none_ca5c4ada0e89e5a2
25/11/2008 05:14 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6001.22208_none_cb36988b276a4088
20/06/2008 06:45 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6001.22317_none_cb2aca3b27734049
25/11/2008 05:44 4.636.672 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\amd64_wpf-presentationframework_31bf3856ad364e35_6.0.6002.18005_none_cc9070960b75a42b
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6000.16708_none_74d95b94f6cef266
20/06/2008 06:48 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6000.16780_none_747ad9e4f7170736
25/11/2008 05:14 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6000.20864_none_751e17b01020d47a
20/06/2008 06:42 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6000.20964_none_751e19961020d1a1
25/11/2008 05:13 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6001.18000_none_76b79604f3fcbb78
21/01/2008 08:21 5.210.112 PresentationFramework.dll
1 archivos 5.210.112 bytes
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6001.18096_none_765c4874f4404efb
20/06/2008 06:44 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6001.18173_none_766ee954f432c83b
25/11/2008 05:04 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6001.22208_none_774937060d132321
20/06/2008 06:43 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6001.22317_none_773d68b60d1c22e2
25/11/2008 05:27 5.283.840 PresentationFramework.dll
Directorio de C:\WINDOWS\winsxs\msil_presentationframework_31bf3856ad364e35_6.0.6002.18005_none_78a30f10f11e86c4
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6000.16708_none_6ca8219658c89e97
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6000.16780_none_6c499fe65910b367
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6000.20864_none_6cecddb1721a80ab
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6000.20964_none_6cecdf97721a7dd2
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6001.18000_none_6e865c0655f667a9
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6001.18096_none_6e2b0e765639fb2c
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6001.18173_none_6e3daf56562c746c
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6001.22208_none_6f17fd076f0ccf52
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6001.22317_none_6f0c2eb76f15cf13
Directorio de C:\WINDOWS\winsxs\x86_wpf-presentationframework_31bf3856ad364e35_6.0.6002.18005_none_7071d512531832f5
    HP HDX16
    P8400 2.26GHz
    Intel Core 2 Duo
    16"
    1920x1080
    300 GB
Hello,
Can you please install .Net Framework 3.5 SP1. There is listing for 4.0, 3.0 and a few others, but not much for 3.5 SP1, an ommission that should be rectified. Even if you already have this, please install it again to reinstall the components. Just install it over the top, do not try and uninstall it first. If I have given you the wrong language, please just change it, I was doing my best to read the Microsoft website in Spanish! Detalles de la descarga: .NET Framework 3.5 Service Pack 1
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
