16 bit MS-DOS Subsystem problem
Stuart289
I downloaded the game Jazz Jack Rabbit. I have Vista Home Premium 32bit but it wont run the game saying,
This system does not support fullscreen mode. Chose 'close' to terminate the application.
What does this mean can anyone help me run the program?
Hello Stuart289,
Download this app and install, you can then run the game.
When you are on their site there is a comprehensive "How to" which will provide all the user instructions.
DOSBox, an x86 emulator with DOS
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
