USB Flash Drive (2GB) Boot Problems!!!
AlOnan
Hi!! I have created several Linux Live USBs and Linux Distros bigger than 200MB do not boot from my USB Flash Drive. I think that my USB Flash Drive might have bad
sectors. What would you suggest to me?
    Acer Aspire M1641
    Intel Dual Core E2220 2.4GHZ
    2GB DDR2
    ATI Sapphire Radeon HD 3450 256MB PCI-E 2.0
    Philips 192E WideScreen LCD Monitor 18.5`
    Seagate ST3250318AS, Western Digital WD3200AAJS-22L7A0
    2048kbps downloading, 512kbps downloading
    Planning to Upgrade my PC...
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Thanks but I`ve used it and it says *No Problems Found*
    Acer Aspire M1641
    2GB DDR2
You have to choose to boot from usb devices from advanced boot options. Your acer bios is: AMI PnP BIOS compatible with SMBIOS 2.4
You might have to go into the BIOS setup and set the boot order.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
