problems with ejecting drive
copodd
Hi All, i am new to this site, but i thought i would ask a question. my laptop is running vista home basic and when i try to eject my wd 1 tb external drive, i get a message saying that problem ejecting drive windows is running a program try again later. Has anyone else had or having this problem. Is there a solution. If there is a solution, please let me know. Thanks:sa:
Is it indexing the drive? if you need to remove it and it won't stop running try restarting your computer it will end all processes and you will be able to remove it then. I have had this problem a couple of times never found what was causing it but task manager should be able to tell you what it is.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Yeah probably windows is trying to index that drive. Unplug the external drive when your computer is turned off then since there is nothing running when your computer is turned off. <<-- simple as that.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
I have found a solution. simply open my computer, right click on item you want to eject, scroll down to safely remove, click it and there you go it will eject with no windows bull****.:)
