Will system restore external hard drive
patch41
Vista Pro
hi folks,if i leave the external hardrive plugged in and i do a system restore, would it also restore the external hardrive to a previous date , i did a clone image with acronis true image and i'm sorry i did, thanks for any help you can give...patch41
Re: Will system restore external hardrive
when you made your restore point if you included your external drive you can. If you didn't include the external drive when you set the restore point then the external drive will be visible but no restore point will be available for it.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
thanks ilikefree, then its a good idea once in a while to plug the external hardrive in and do a system restore,it might help the situation like mine where the external hardrive was wiped clean patch41
It is a good idea to include your external hard drives in your all of your back-ups. For that reason, I've given all of my external drives, individual drive identification letters [F:, G:, K:, M:, etc.] which helps for instant recognition.
I also suggest that you also include them in any Anti-virus, Malware and Spyware scans from time to time - that way it helps to keep everything clean. I 'hit' mine with checks by Malwarebytes' Anti-Malware, Spybot S&D, and SUPERAntiSpyware Free Edition, from time to time.
Another recommendation is to also include the external hard drives in your defragmenting admin. I use AusLogics [free] - again, every now and then. I've found AusLogics to be extremely reliable and far quicker than the installed Vista system defrag.
A word about Acronis - I too had it, but found it to be rather cumbersome, unreliable, slow and just downright frustrating. I've since tossed it out and use instead Macrium Reflect [free] from Paramount Software UK. It is a very simple bit of software to use, and easy to navigate around. Very reliable as well.....for example just yesterday, I did 185Gb total of back-ups of 4 system partitions, and 2 external hard drives, to another external hard drive; time taken = 1 hour 20 minutes.
All free software listed above, have links available from Brink's excellent guide; Free Software List for Vista - Vista Forums, here;
http://www.vistax64.com/software/115872-free-software-list-vista.html
Hope all this helps.
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
System Restore only backs up system files...it could care less what's on the external.
Time to start thinking of a regular backup strategy...
I use and recommend Acronis True Image...although it's not Free.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Posted at the same time you were typing sassofalco.....:D
    Intel Q6600
    ASUS P5K MBoard.
    OCZ Elite 800W PSU
Heh!Heh!Heh!....finally I beat someone else to the guns ;)!
....and I'll stick to 'em where Acronis is concerned. I feel that a Degree in Computer Science would help with that software, whereas with Macrium Reflect, I just need my Laptop, an External hard drive, and two large, strong, black coffees.
thanks sassofalco, acronis true image is what got me into trouble, and being a newbie doesent help,but you came up with good suuggestions, which i will try thanks again (and i tipped the scales). patch41
Plus 1 for Macurim and as a note Vista will not defrag files over 64Mb by default you will have to defrag with CMD.Prompt ran as administrator Defrag.exe C: -W note spaces after exe. and C:
    LENOVO 64734VM
    15 inch
Interestingly enough my recommendation for Free image apps is Macrium...
But i still run Acronis.
    Intel Q6600
    ASUS P5K MBoard.
    OCZ Elite 800W PSU
Hmmmmmm. - Mr. Geek patio. B.I.T.(Comp.Sc)....looks OK.
For my idea, cloning the whole hard disk to another hard disk is more efficient than backup and restore processes. Please do system restore under Pre-OS circumstance.
I felt sorry, why acronis true image could do this work. Based on experience, true image is an stable one with comprehensive features.
OK, in case true image cannot satisfy your requirement, try todo backup. This is a pretty good alternative of true image, features and stability and many many things. What's more, it is cheaper than true image...
