HELP! low disc space on Recovery D
elliejess
Getting the error message above: I have not altered anything on pc since I purchased it, as I don't have enough knowledge to do so. I know this is an old problem for most Vista users but can anyone help me to solve it? The constant pop ups are very annoying and worrying.
The recovery D indicator shows red. I have have plenty of space on C: if I can find out how to save backups to it. I save data files to external drive so no problem with that.
I need very simple instructions to sort this out please.
Dell desktop pc. WIndow Vista 32 bit Premium Home edition.
Try using WinDirStat to see where your space is going.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
If D: is the factory installed recovery partition, then, presumably, you aren't using it and will only need it if you need to reinstall your software and/or system.
The simplest way is to remove the drive letter from Vista; see Shawn's tutorial http://www.vistax64.com/tutorials/114767-drive-letter-add-change-remove.html.
If you later need to reinstall, just add the drive letter back using the same process. Don't use the drive letter for anything else in the meantime.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
