Akward problem and in need of immediate assistance please.
betalicious
I restarted my computer last night and when it was done booting my desktop and icons showed up except after waiting my yahoo IM, windows live, AVG anti-virus, xfire and several other programs hadnt started up....well i thought it was just blocked so decided to go on th einternet but when i tried to get on IE or chrome OR ANY OTHER ANYTHING ELSE i get the "Open with" dialoge box showing up or in some cases appliations not being found...also idk how but i managed to get IE running so that is how i am posting btw and I did some reasearch...maybe my registry is messed up because i cant acess it (i am a admin user for my comp btw) and i tired making a recovery disc (i have the recdisc.exe) but it has the "Open with" window show up everytime i try to do it....I really dont want to do a full restore but I wanna hear you guys takes on this I will answer any questions that will aid in my endevour to get my computer back to normal T~T
Welcome, I do not think that a recovery disc is needed. Try a simple system restore. It sounds like your problem will be corrected with that simple remedy.
Whenever there is an unexpected changed to your OS do a thorough A/V scan and download and use malwarebyes.
....i alrdy have malwarebytes...the restore wont make me lose my files would it caus ei have some rare videos and games and i dnt thnk i have enough additional storage space on external drives if everything gets wiped
I cannot tell you what will happen, I can tell you what should happen. System Restore is only suppose to make changes to the OS; documents, photos etc should not be touched. I have used SR about 3 times and never had a problem. The final decision would have to be up to you.
I tried system restore but....I wont work It just opens the Open with window when i try to do it.
If after following the tutorial in the above post, SR still does not work, try this.
http://www.vistax64.com/tutorials/69758-default-programs.html
the SR didnt work however....the default lead to finding the fix apparently the regestry lost association with all my .exe files after downloading a zip and extractingthe needed reg file the regestry is able to associate again and everything seems fine now...if i find another problem ill post again for help, ty rich you were a ton of help.:D
on a personal note im not using avg again because it was kinda responsible for this mess >~<
