HELP! Password Problem
CanSpec
I shutdown my comp for the first time in months and months(sleep mode before) and now Vista is asking for my password which I don't remember. I contacted HP and they say I have to do a system restore...which of course I cant...it also never came with start-up disks. HELP! please...:cry:
Here is a method to try to remove the password (you will need access to another PC or mac)
Go to: http://pogostick.net/~pnh/ntpasswd/ and click “Bootdisk” at the top. Scroll down to about half-way to the download page. Download the latest CD release and extract the zip file.
Install the HP tool included with this post, start it, and select a blank memory stick. Make sure ALL data is backed up, as the memory stick will be wiped. Select FAT and type a Voulume name if you wish. Check create a DOS start up disk, and select the downloaded CD image. If this does not work, after the format, just drag the contents of the CD archive onto your memory stick.
Once you have made your memory stick, boot into it (you may have to change your BIOS settings) and then follow the instructions in the walkthrough provided by the site. I have included a copy of this walkthrough as a Word document. I have also listed a summary of which buttons to press. Follow these instructions exactly. This will work from NT to Windows 7, and so many options do not apply to Vista, and you will do much damage in running them.
Here is the summary (and included at the bottom of the document) :
· Enter
· Select Windows partion using numbers then enter
· Enter
· 1 then enter
· 1 then enter again
· Enter account name then enter
· 1 then enter
· ! then enter
· q then enter
· y then enter
· n then enter
I would recommend following the walkthrough, and only using the summary to check you have not missed a step. I would recommend printing off the walkthrough, though you could have it on another computer screen.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
