Solved Shortcut icon problem for Connection with Vista X64
I have created a desktop shortcut for my ADSL connection. As can you seen in the first picture, my connection is ADSLInfostrada (Infostrada is my provider). Vista create a shortcut with a generic icon, instead of that with the 2 screens like in second picture.
Rarely the system put the second picture icon, but after a few of minutes, the icon come back to that ugly generic.
Why system change the icon without reasons? I have installed Vista only 2 days ago with all updates.
How can I do in mode that the system always use the second picture icon?
- E8600 @ 3,8 GHz
- DFI P35 DK T2RS
- 4 Gb DDR2 800 Corsair
- GTX 295
- Samsung SyncMaster T240HD
- 1920x1200
Hello Siegfried, and welcome to Vista Forums.
First test to see if
rebuilding the icon cache may allow it to display properly afterwards.
If not, then you might see if you may be able to manually
change the shortcut icon to the correct one a few times to see if it will display properly afterwards.
If still not, then check to make sure that you create the shortcut directly from the source EXE file and not from another shortcut that could have been moved or deleted.
- Operating System
- Windows 10 Pro 64-bit
- Custom
- Intel i7-8700K 5 GHz
- ASUS ROG Maximus XI Formula Z390
- 64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
- ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
- Integrated Digital Audio (S/PDIF)
- 2 x Samsung Odyssey G7 27"
- 2560x1440
- 1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
- PSU
- Seasonic Prime Titanium 850W
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Logitech MX Master 3
- Logitech wireless K800
- 1 Gb/s Download and 35 Mb/s Upload
- Other Info
- Logitech Z625 speaker system,
Galaxy S23 Plus phone
- Operating System
- Windows 10 Pro
- HP Envy Y0F94AV
- i7-7500U @ 2.70 GHz
- 16 GB DDR4-2133
- Conexant ISST Audio
- 17.3" UHD IPS touch
- 3480 x 2160
- 512 GB M.2 SSD
- E8600 @ 3,8 GHz
- DFI P35 DK T2RS
- GTX 295
- 1920x1200
That's great news Siegfried. I'm happy to hear that you got it sorted.
- Operating System
- Custom
- 2560x1440
- PSU
- Case
- Cooling
- Other Info
- Operating System
- Windows 10 Pro
- HP Envy Y0F94AV
- 16 GB DDR4-2133
- 3480 x 2160
- 512 GB M.2 SSD
