Jesse02
This is a tough one for me to explain but I will try very hard. I guess this started around late summer 09. I turned on my computer and it would run chkdsk over and over again. I let it go over night once and it was still scanning the hard drive over and over.
Around Christmas time I reinstalled vista and still it would run chkdsk on every boot. Only this time, it ran once and then vista loaded fine. It would stop responding often and run slow but it was better. I manually turned off chkdsk but it made the computer run worse over time. It would just not do anything so i would have to hold on the power button and turn it back on. The hard drive light will just stay on and the drive will sound a little different than usual. No clicking or metal on metal noise, just a different type of busy noise until you open something. Also you could use the disk clean up but not the defrag. It will say you should defrag volume so i would click defrag now. It would just show you the spinning blue circle and say analyzing but then say you should degrag volume again. So it won't defrag either. System restore also does not work.
So today after being sick of it, I checked into the chkdsk and found I could have it fix and try to restore sectors and stuff. So I ran chkdsk /f. It looked different and said it was fixing many things. I also ran chkdsk /r. They both seemed to be done quick but the computer's performance was improved a lot. It now shuts down instead of just saying it is.
I tried just a plain old chkdsk and it goes only so far and says it encountered an unknown error and done checking the disk. I still can't defrag also. All of the different things I have done today helped, but didn't solve the problem. I am going to keep a very close eye on things and post any error messages here. I know that is important clue when trying to fix issues. I would love to just find a way to fix this problem. I'd hate to have to buy a new hard drive or something.
I'm not new to computers but I'm not a computer genius either. I really don't know my level of computer knowledge.
- compaq presario pc
- intel pentium dual cpu e2160 @1.8ghz 1.80 ghz
- 1.00 gb
- intel graphics media accelerator 3100
- realtech high definition audio
- 32inch lcd tv
- 320 gb sata
