Solved Help Needed with *Reliability Monitor*
LatinGod
Need help With Vista's Reliability Monitor. Here's the problem...
Past month having too many problems with Vista Extreme and dont know what is causing them. I went and opened the Reliability Monitor and as soon as it opens i also get a small window saying: Internet Explorer cannot download.The system cannot find the file specified. Also, on the big window where the Reliability Monitor opens,the bottom part of the window and right below the graph with all the red X's,it says:Navigation to the webpage was canceled.What you can try:Retype the address.
Does anyone have any idea why this is happening and/or how to fix this issue? Any and all help will be greatly appreciated. Thanks in advance.
    Dell Studio 1735 Laptop
    Dual core
    4Gb
    ATI Radeon HD 3650
    500Gb WD
Welcome, sounds like corruption.
Try this to fix. In search type cmd, do not hit enter>right click run as administrator.
In the cmd prompt type sfc /scannow. You will get a report of any problems, In addition, the scan will try to make corrections. If errors are found run 3 times. Only one file at a time is fixed.
Trying that right now.Thank you. Will post back in a few...
    Dual core
    4Gb
    ATI Radeon HD 3650
    500Gb WD
Im on the East Coast, getting late. I will see the post tomorrow, but do wish you luck.
East Coast here too. But thanks again and will post back n inform if resolved. Have a good night bro...
    Dual core
    4Gb
    ATI Radeon HD 3650
    500Gb WD
TY for your kind word and rep. You will always be welcome at the Forum. I hope that your next visit is to tell us that your problem has been resolved.
Hello Richard. Just wanted to say thanks again. My issue was resolved in another way. Kinda figured out that the problem was File Association. I forgot that htm and html is associated with IE by default. Im thinking that when i made FireFox my default browser it may have changed the file association.Anyways, for anyone that encounters the same problem i had... All i did was go to the Tutorial section of this site, Default File Type Associations - Restore. Downloaded the restore for HTM and HTML, ran them, and restarted Vista. After this, the Reliability Monitor was able to read the logs. But thanks Richard, because i followed your advice and was able to fix other problems. Hope this post is able to help someone in the future.
    Dual core
    4Gb
    ATI Radeon HD 3650
    500Gb WD
Mate, just for future, if the matter is 'solved' to your satisfaction, then go back to your last post, click on the
Solved icon.JPG top right of post, and just enter 'Solved' in the dialogue box that comes up.
By the way, thanks for getting back with the feedback - too often overlooked, as are expressions of thanks to those that may have helped.
Enjoy your stay with the Forums.....any problems, there's always someone around ready to help.
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Okey thanks. I was trying to figure where was the "solved" thing.
    Dual core
    4Gb
    ATI Radeon HD 3650
    500Gb WD
Sorry that I did not answer sooner, had no electric power since, Friday.
I know, we had some crazy weather too here in NYC. But again, Thanks Rich. Your sugestion helped me fix other things that I had no idea were wrong. Your help was, is, and will always be greatly appreciated.
    Dual core
    4Gb
    ATI Radeon HD 3650
    500Gb WD
Good to see you back on board Richard, and hoping that things are slowly becoming stabilised and returned to 'normal', whatever that may be.
Nature is the great leveller, and can reduce us all to a survivalist mode in a matter of hours, and then it is often surprising how resilient and innovative most become when faced with living with just the basic necessities. I sincerely hope that you and yours are managing through this weather event, and that any losses are minimal.
You gotta look on the bright side - stocks of firewood will be at an all-time high for next winter, and furniture craftsmen will be rubbing their hands with gleeful anticipation, at all that new resource material.
That is all so true Sassofalco
