Help - icon problems
epicownage95
i need help on my icon problems....... my folder icon is destroyed and turned into a generic one, when ever i make a new folder its still shows the generic icon.....all my other icons of other programs have been replaced to generic ones... plsss help...T.T
    Gateway FX series 7809U
    Intel Core 2 Duo P8700 Fsb 1066
    4gb ddr3 Fsb 1066
    NVIDIA 9800GTX 1024 mb ddr 3 256 bit
    Conexant Hermosa HD Audio
    Laptop Lcd panel
    1440x900 17" laptop panel
    1x SSD Kingsone hyperX 120 GB
    9 Cell battery with 7800 MAH
    100 mbit/sec (megabit)
This may or may not be Virus related. In your post to don't say what led up to this. The easy solution would be to make sure your files are backed up then re-install Windows. How ever this will not be of any help if you have an infection. Here is a link where you can go for help to determine if it is Virus related Here.
Regards,
Gil777t
    Hp c3307c slimline
