So I have a very annoying problem. Whenever i try to do ANY EXE file i get the "Please select a program to use with the EXE file." That whole thing. Problem is i end up doing this EVERY SINGLE TIME I have to use an EXE file! any ideas to fix this annoying problem?
- Custom Built
- AMD Athlon 64 2X Duel Core 5200+
- Biostar TA770 A2+ SE
- 4GB DDR2
- GeForce 9400GT
- Stock High Def. Audio controller
- Acer HDMI 27' Computer monitor
- 1280X1024
- 160 GB IDE HDD 320 GB SATA HDD 500 GB SATA HDD
- PSU
- LOGISYS Computer PS550ABK 550Watts ATX12V Power Supply
- Case
- Antec 300 Illusion Black Steel tower
- Cooling
- 140mm fan,2 x 120mm front fans, 1 x 120mm rear fan
- Standard PS2 Mouse
- Standard PS2 Keyboard
- 54MBPS
- Other Info
- DVDRW
