help me with 2 problems about setting
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
how to do. Color scheme of internet, FF,... is changed.
i adjusted color schemes but it was not changed. how to do. thanks!!!!~________~
    Vaio VNG-CS325
    320G
I managed to see the pictures this time! If you have any modifications to your desktop (to make it look like a mac etc.) then disable them now.
  • Right click on your desktop and click Personalise.
  • Click Display Settings.
  • Drag the resolution slider as far right as it will go.
  • Make sure the colours is at "Highest (32 bit)", though I don't think this is a problem.
  • "OK" out of this box.
  • Click Theme under Personalise.
  • Drop down and click "Windows Vista".
  • "OK" out of this box and close Personalise.
Has this helped at all?
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
my desktop is normal now. But line around IE, FF, softwares... I can't fix. Look it the same win 97, 98. It's so bad. I only want it backs original configuration:confused:
    Vaio VNG-CS325
    320G
Just to confirm, you changed the Theme, and it still has not helped?
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
i tried to change but problem at line around IE, FF, Softwares... It's not from win vista. I see that they 're the same win 97,98. u can see pic. But line around Recycle, My Computer is normal
    Vaio VNG-CS325
    320G
Reinstall Firefox and see if that does the trick.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
not only FF has this problem but also IE, softwares. Can you help me install advanced appearance?
    Vaio VNG-CS325
    320G
Re: help me
So you have missing buttons from IE, classic buttons in Firefox and everything else is normal?
Have you tried removing / disabling the theme from firefox?
Are you using a skin in IE?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
