Hello,
I would like your help on how to solve the issue with my Vista desktop. When online, it was freezing, and I then turned it off because it won't allow me to shut off using the Start button. I then turned it on, and the statement appeared on the black screen.
Setting has failed to POST.
System is using default settings for this POST attempt.
Press F1 to continue.
Press F2 to enter SETUP to adjust OC/OV settings.
I pressed F1 and it came on with no problem. But, it continues doing that kind of statement after turned it off for a day. It won't disappear because it looks like I need to press F2 to solve it. Please direct me to some sites or others for this kind of issue. If I need to press F2, what will happen and what do I do with it?
Thanks.
Thanks.
- Dell desktop-XPS
- Intel Core 2 Duo-3.00GHz
- 4.00 GB
- NVIDIA Geforce GTX 285
- 450 GB
- Microsoft
- Logitech
- High Speed Verizon
