Upgrade from 32bit Home Premium OEM to 64 bit?
laval0rd
Is it possible to obtain a 64 bit installation disk for my OEM version of Vista Home Premium that came with my PC? The microsoft page doesn't make it very clear, has anyone done this before? Or is the only way to do this is to buy a full version of Ultimate?
Hello,
Call Microsoft and they should send you the installation DVD for the cost of the shipping.
~Jonathan
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
If you are turned down by MS, you may want to call the computer Manufacturer. Maybe they can help.
MS will not send replacements for OEM versions.
You can borrow one and copy it - or download one - as long as you use your own key.
Make sure you get the bit version you want 32 or 64 - the key will work with either.
Any MS dvd will do - they all contain all Editions.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
