My Fax Status Monitor used to work.
A so-called tech rep destroyed many of my programs, one of which was the fax program.
I removed and then added Windows Fax and Scan. Although I am able to send faxes, the Fax Status Monitor doesn;t work.
When I try and view the Fax Status Monitor under "tools", nothing happens.
How can I get the Fax Status Monitor to work again?
