OK so i installed a new TB HD from WD yesterday and i have had a 64 bit OS ( i have 32 bit vista now ) cd laying around for awhile. I figured i would install it on the new HD so i could get the cheap upgrade to 7 next month. Well the HD install and format went well yesterday and i installed the OS this morning on the new HD. But now, like i figured, all the settings and drivers are on the other hard drive. So my dual monitors are not set up and i cant get on the internet. I cant even find the nvidia program to set up the dual monitors so i am assuming it is on the other HD somewhere. I copied and pasted the driver files from the old HD to the new one, but that didnt do anything. I even put the wireless network adapter cd and installed it. Still says i dont have a wireless network adapter installed ( i hope its 64 bit compatible, its a "wireless G network adapter model no. WMP54G ). I need some help please guys thanks.
