Does anyone know of a program that controls fan speeds? i want to turn up my fans higher but i dont know where to find a program that works well can some people give me links please?
Fan speed control program - Club MyCE
look at AZImmortal's post; u can't use software; the only software that is related is ones that monitor fan speeds. u can always buy a cheap hardware controller that yyou can change the speeds with from dials.
depending on your BIOS settings the fans attached to motherboard headers will run 100% by default, the only one you can throttle through windows is the CPU HSF fan (providing its ''PWM'' enabled), via ''speedfan''
''speedfan'' will only alter fans that are ''PWM'' ready, these fans have a ''4pin'' connection to the board.
so...... what fans are you talking about & how are they connected to your system.
IDT High Definition Audio/SRS Premium Sound/Altec Lansing
17" Laptop Screen
1440 x 900 laptop, external 17 in LCD 1024 x 768
WD Scorpio Blue 320 GB SATA 5400 RPM
Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
8 Cell Lithium Ion Battery
Laptop with "light up" HP Logo on outside
Insane air coming out of Targus dual fan cooler
Microsoft Wireless Mobile Mouse 3000 / Touchpad
Full Keyboard with numpad
Comcast Cable 20 MBps
Used Primarily for CAD design using SolidWorks 2010.
Also I love to watch HD movies using the HDMI output(Netflix).
Linked to my Xbox 360 for Windows Media Center
3 USB ports + USB/eSata
HP Remote for Windows Media Center and Quickplay
Internal Dual Layer DVD+/-RW
External HP Lightscribe Dual Layer DVD+/-RW
HP Webcam and Microphone
x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
Logitech LX310 2.4Ghz Wireless Laser Mouse
Logitech LX310 2.4 Ghz Wireless Keyboard
32mb Download, 12mb Upload from Comcast
300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
