Vista will not start after System Restore
IMElizabeth
Last night, I accidentally deleted a few things off of my desktop HP so, I used System Restore to fix the problem.
Afterwards the computer started up fine and everything seemed okay until after a couple moments the entire computer froze. It stayed like this for a few minutes, and I, thinking nothing of it turned off the power button and prepared to restart the computer. However when I turned it back on it stayed on the little green moving bar for almost thirty minutes and still will not load. I have tried everything.
Using the F8 button I attempted to try every single option on the list but to no avail. I am desperate for my computer to work again and I am at my wits end. Please, help me!
(Also, I have none of my original startup disks or restore disks seeing as I lost them when I moved.)
-Ivy
-Ivy
Have a look at this tutorial:
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html?ltr=C
EEEK you interrupted your system restore :confused: that freeze point was the system restoring its self
As stated by theog, you will need a recovery disc to repair windows or if this fails you will have to make a fresh install
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
