need help... 'No battery is detected'
Christena
Hi for all :),
i think i have a problem .. i can't solve..
i have just reinstalled a clean vista but vista saying... "No battery is detected "!!!:confused:
even it was detected before installing it!!!
Hope anyone can help me..
Thanks ...
Hello Chistena,
Is this for a laptop or a desktop with a backup UPS battery attached to it. If the later, do you have the software (32-bit Vista version) installed for it?
Hi Brink,
it's for laptop ... and i installed vista (32-bit ) ...
What make of Notebook?
This may help,
1) remove power cable & battery leave for 10 mins.
2) restart notebook with power cable (no battery)
3) restart notebook with battery (no power cable)
4) restart notebook with power cable & battery.
Your laptop should function as normal, both on power and on battery. However, Windows will only detect the battery if the necessary driver is installed. In order to locate this driver, we will need the make and model number of your laptop.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
