Vistagnubee
Hi all:
I apologize if this is not the right area for this question but it didn't seem to fit anywhere else.
I am having a problem understanding system environment variables and hope someone can educate me a little.
Specifically, I am trying to set up Virtual box on a Vista Ultimate host so that limited users accounts can access the virtual machines.
I found the following information out on the web while trying to research the issue:
" By default all VM machine and disk data is stored in the .VirtualBox directory located in your home directory, C:\Users\<username>\ ".
This,I believe, limits the use of the VM to the user who creates it. If this is true, then I think the following sys environment variable would allow all users access the the vm's:
HOME = C:\Users\Public\<folder for organization purposes>\
I did a test run of setting up a VM and followed the creation process until it got to the point where it had finished configuring with the following location given for creating the file:
C:\Users\my_name\.Virtualbox\HardDisks\test.vdi
I found a similiar post on a Virtual Box forum but the response given was that the sys environment variable should be:
" HOME = C:\HOME"
I think that is wrong since there isn't a "HOME" directory in Vista.
Can anyone tell me if my thinking is correct, or, if not, where I am wrong?
thanx in advance...
" HOME = C:\HOME"
thanx in advance...
- home built
- i7 920 OC'd to 3.6Ghz
- Gigabyte GA-EX58-UD3R
- 8G OCZ Platinum 1600 DDR3 (4X 2Gb)
- MSI N260GTX OCv4
- on board - Realtek I think
- Hannspree
- 1920 x 1280
- 600 Gb Western Digital Black Caviar
- PSU
- Corsair 750W
- Case
- Antec 1200
- Cooling
- Xigmatek Dark Knight
