Bsod problem,please help!i've found what caused it
2 of the file is causing them
NV4_disp.dll << this is nvidia right..i updated to lastest driver and still i get BSOD.
and ntoskrnl.exe << i've no idea what this is.
Here is my "whocrashed" reports
On Sun 2009/11/22 上午 02:47:01 your computer crashed
This was likely caused by the following module: nv4_disp.dll
Bugcheck code: 0x1000000A (0x4C004100, 0x1C, 0x0, 0x804EEACF)
Error: Unknown
Dump file: H:\WINDOWS\Minidump\Mini112209-01.dmp
file path: H:\WINDOWS\system32\nv4_disp.dll
product: NVIDIA Compatible Windows 2000 Display driver, Version 191.07
company: NVIDIA Corporation
description: NVIDIA Compatible Windows 2000 Display driver, Version 191.07
[FONT=Segoe UI, Arial]On Sat 2009/11/21 上午 10:56:59 your computer crashed
This was likely caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT]
Bugcheck code: 0x1000000A (0x912815FF, 0x2, 0x1, 0x80702A8E)
Error: [FONT=Segoe UI, Arial]Unknown[/FONT]
Dump file: H:\WINDOWS\Minidump\Mini112109-05.dmp
[/FONT][FONT=Segoe UI, Arial]file path: H:\WINDOWS\system32\ntoskrnl.exe
product: [FONT=Segoe UI, Arial]Microsoft(R) Windows(R) Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: NT Kernel & System
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit may be another driver on your system which cannot be identified at this time.
[/FONT]
[FONT=Segoe UI, Arial]This is only two of them,but mostly its those 2 which causing bsod.
[/FONT]
    Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    Lenovo 1440 X 900 60Hz
    1440 X 900
    1TB
