Hi im kinda new so ill need all the help i can get. in march i think my friend gave me a laptop. Sony Vaio. 1gb Ram all that.... x64... recently it crashed and i ran the recovery partition... now for some reason my laptop has gone from x64 to 32bit. yes it is 64bit capable but i dont have any installation cds with x64 on them... i was wondering if there was a way to change without a fresh installation with cds or recovery partiton (now deleted)
simply
if there is a way to change my pc BACK to x64
HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
Realtek HD Audio
Dell E2311H DVI/VGA 5ms response, Full HD
1920x1080 @ 60Hz
320GB Seagate Barracuda 7200.02 SATA II
Cooler Master Extreme Power Plus 700w
Lian-Li PC-6010 With Side Window
Aywun A4 80mm fan
Logitech K120 Wired Mouse
Logitech K120 Wired Keyboard
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
Thomson A/B/G/N Router
LiteON CD/DVD Player
GAME PERFORMANCE:
Battlefield 3: 41 FPS High 1x AA @ 1280x720
Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
Counter Strike Source (and other Valve games):
300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
I would that the 64-bit Vista was not the original OS installed, and that the 32-bit Vista is what was included with the computer originally on the recovery partition.
Unfortunately, you can only do a clean install when going from the 32-bit to 64-bit Vista, or the other way around. Since you have deleted the CD and recovery partition, you will now have no way of reinstalling the 32-bit Vista via a factory restore from them. Unless you have another Vista installation disc with a valid product key number for it you are out of luck and will need to purchase a new copy. If it comes down to that, you might consider Windows 7 instead.
