Overclocking my graphics card :)
jonny321321
Banned
Hi all
I have a Asus engtx 275 and was overclocking it my final clocks are
723/1404/1257
All the
[FONT=verdana,geneva]As far as the GeForce GTX 275 goes .. it's a pretty darn nice overclocker. We bumped the core [FONT=verdana,geneva]to 743MHz vs. 632MHz standard, the shader clock is now 1605MHz vs. 1404MHz standard and the memory is running at 1282MHz (2564 effective) vs. 1134MHz standard.[/FONT][/FONT]
The above is from GeForce GTX 275 Overclock guide
Yet the whole system locks out if i have the shader clock even at 1450? any reason why? i should be able to get 1605 according to this?
    Intel Pentium Dual Core E5200 Overclocked @ 2.90
    ASUStek
    OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
    ASUStek ENGTX275 PCI-E x 1
    19inch benq
    1400x900
    400 gb
    700 Watt artic power
    Artic cooler
    4.70 mb/s download, 0.37 mb/s upload
I upped the memory and ran furmark got 6077 score and 1 fps improved in max fps equalling 134!
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
first off they (guru3d) will get a 275 directly from NVidia , an NVidia chip on an NVidia built and designed board (called a referance board) , these are no ordinary 275's and they dont reach the open market dont try and match any oc from a referance board ,
the shader clock is the most difficult to oc and will cause the most instability if clocked incorrectly , and if you clock your ram too high you can damage it same goes for the core , stick with a safe overclock , run 3d mark in a loop for a few hours and run ATI tool and use it to scan for artifacts , if it finds any its back to the drawing board ;)
up your card by 5mhz at a time (yes you heard me right) when it starts to artifact back it off by 10mhz and your good to go :)
Or alternatively you could stop fecking around with it and enjoy it ingame ;) ;)
and stop using a synthetic benchmark as a guide to how good your overclock is , benchmarking programs are for bragging rights only ;) , do you have call of duty waw? come join us online for a few games we'll show exactly what that bloody 275 is for ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Lol :) Yeah calm down archie xD
Ok Ok I have cod4 pc :) Cod1 pc :) You have any of them! Ill play ya :)
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
PS Cheers for the help :D
But the shader clock how can they say they got it to 1605 or something and i cant get it past 1450 ???
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
Ahhhahaha NEVER! :D
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
the referance board will have most likely had a voltage tweak in the card bios , like i say its no ordinary 275 , NVidia release the best of the best tweaked cards for testing , as you probably know the only part of NVidia on your gpu is the core , the rest is designed and built by Asus , NV design and build and tweak their refernce cards themselves , best quality ram best quality capacitors and give the voltage a tweak for higher clocks..............and before you ask yes you can tweak the voltage on your card by flashing the cards bios but id leave that bit of overclocking alone for now ;)
I have all the cod series cod 1 is the best online multiplayer game in the history of the world :) but i only have WAW installed at the momment
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Archie theres no bios for my card anyway :(
I cant find any for
Asus engtx275 894mb
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
