DreamScene problem - explorer has stopped working
TopGunGeo
Hi, new to vistax64!
I have vista x86 sp2. :D
I get 'explorer has stopped working' error when trying to set dreamscene as background.
after that error comes, explorer restarts and my background is still old(without dreamscene).
Please help me, I want dreamscene!
(sorry for my english)
Hi TGG,
Are your video card drivers are up to date?
Aero enabled?
What are your specs? ie CPU and video card
Unfortunately dream scene was a great idea, but is buggy as hell.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Hi Smarteyeball,
Yes, my video card drivers are up to date.
Aero is enabled.
CPU - pentium dual core 3ghz
GPU - ati x1600pro.
thank you for reply, and please if you know something about it, tell me, I would be very thankful.
What version of explorer do you have? I installed 8 and had nothing but trouble with it. I removed it went back to 7 and have had no issues since.
    Dell XPS 720
    Itel Core (TM)2 Extreme CPU Q6800 @ 2.93GHz
    2 TB
    NVIDIA GeForce 9900 GTX
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    3 x 1 TB DEL Hard drives.
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
I believe he is referring to Windows Explorer.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Dell XPS 720
    2 TB
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
Oops :o
lol, no worries mate - easy to confuse :)
Yes, I mean Windows Explorer.
So what to do....
You can probably start by answering the questions I asked earlier ;)
Some of the default themes are 'less taxing' than others. It depends on your PC. Lower end PC's can really struggle with some 'dreams'.
You can also check out stardock's deskcapes.
Stardock.com - Your Edge In Software
It's the same deal as dreamscene, although it's no longer free like it used to be.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Thanks for the specs TGG.
If that is a Pentium D 3.0ghz, then some dreams - especially those with long loops and HD quality (720p,1080p etc), can utilise anywhere between 5% to 80% of your CPU usage just to run a dream.
Regardless of whether that is causing the explorer issue or not, it will definitely slow your whole system down.
As for the explorer crash, I'd temporarily try disabling AERO to see if it has an impact. From memory - The WDDM (Windows Display Desktop Manger) has problems pausing/restarting dreams when applications etc are minimized/maximized.
In conjunction with the 'explorer has stopped working' , have you had any other messages that mention the "display driver atikmdag.sys has stopped working and recovered" ?
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
No I don't get any other error messages.
But if I disable AERO I couldn't use Dreamscene......
Whoops, you're right. I haven't touched DS for well over a year and I got the Aero issue confused with something else. My apologies:o
You could always check the Event Viewer logs to see if it points a patricular file that is causing DS to stop working.
(Start> type "Event" and in the Event Viewer, Custom Views>Administrative Events
Look for the explorer application crash and see if it shows a "Faulting Module Path" usually a .dll or .exe file
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Oh, THANK YOU VERY MUCH!!!!:)
I looked in Event Viewer and there was said about ffdshow, I uninstalled it and NOW I CAN USE DREAMSCENE.:party:
T H A N K Y O U ! ! ! :);)
Awesome :) I'm sorry I didn't think of it straight away :rolleyes:
I would never have made the connection between codecs and dreamscene....
Enjoy :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
