Need help with reset disk
saga3180
K i found a webiste with the reset disk and donwloaded and burned it into an iso and its bootable.So now my problem is how do i put it into factory settings since i dont have a backup?I really didnt need a backup
Hello Saga, and welcome to Vista Forums.
What brand is your computer? Most OEM (store bought) computers come with a factory recovery partition that you can do a factory restore from.
You probably don't want the junk from a factory install. Wipe everything and re-install. Or wait for 7.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Well i was able to burn a reset disk for 32 bit
and i found a button that said repiar your computer so i clikced it
And i got these options:
start up repair
system restore
windows complete pc restore
windows memory diagnostic tool
and lastly
command prompt
Sorry for double posts.
That would be a Vista Recovery Disk instead. It does not install Vista, but only does those repair options. Only a OEM Vista Factory Recovery Disc, or partition, can be used to reinstall Vista.
If you have a friend that has the exact same model and brand of computer as you, then you can use their OEM recovery disc to reinstall Vista with using your product key number on the bottom of the laptop instead.
Otherwise, you will need to buy a new copy. Since Windows 7 is coming out on the 22nd, you may wait and buy it if you have to buy a new OS.
Try the startup repair first.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
