System Restore disk problems
bp123
Hello,
First off, after restarting my computer one day, I found it to either not get past the loading screen or freeze 5 minutes after if i could log on. I tried a few things that did not work and went to do a system restore from the windows repair tools upon booting up.
When i tried to restore i get the message that a system restore cannot be done because the C drive had errors. It prompted me to do a disk consistency check upon restart which i did. After trying a few times i find that it always freezes at 7% through, and will not move.
Finally, i tried booting into safe mode, only to find that it too freezes when it is loading files, always at windows/system32/drivers/crcdisk.sys.
The computer is only 2 months old, bought brand new at best buy. A rocketfish 550watt power supply and Geforce 9800 video card were installed by the employees, but no other hardware was replaced or tampered with.
Any help is appreciated!
    Acer
    Dual core E5200 2.5Ghz
    3 GB
    Geforce 9800 GT
Your disk is dying, replace it at the store.
    Sony Vaio Z46GDU
    P9700@2.8GHz w/6MB L2 cache 1066MHz FSB
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Frost is most likely correct. You can also try download knoppix, a bootable CD to format the drive and try again.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Or sysrescuecd
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
As suggested, you can try to recover your files with: ( Computer First Aid Using Knoppix ) But if the HDD is dead, that may not work either. I hope you backed up your files.
I would go back to Best Buy and have them replace the disk. If you put your foot down (talk to the manager), they will do it. You have a 1 year warrenty. But usually you have to claim that at the manufacturer. After 1 month, Best Buy does not want to know you any more.
    Dell
    Q6600
    HP w2207h
