As some of you may know my system had a hiccup last night and I chose to perform a system recovery. Well, now since the restoration, windows explorer will take up to 200mb of ram just to open a folder. Everything lags... But when I open a program everything is normal, just seems that browsing thru my folders sucks away resources and lags everything down... I just checked event viewer, its clean, device manager is good. Msconfig only shows 2 items under start up that are checked. I do have a lot of services disabled and in 'manual' mode, does explorer rely on a certain service? Btw, superfetch and readyboost are disabled, as they were before the recovery, didn't have any effect then...
Idk what else to check, this is really random. It does it even when the folder I'm trying to view is set to 'List' so its not that. Even thumbnails are disabled...
Thanks in advanced for any suggestions.
- HP
- Intel Neo
- 2GB
- Intergrated Intel Graphics
- Integrated
- 1280 x 800
- 160GB
- PSU
- Power Adapter
- Case
- It's special, it flips open :)
- Touchpad
- Acer
- Down: 16mb/s Up: 1.6mb/s
- Other Info
- I killed my HP Laptop :'(
