Will my 64bit activation key work for 32bit Vista?
ayush
I bought a HP Pavilion Laptop which came with Vista Home Premium 64bit installed on it. There are however a number of 16-bit DOS applications that I need to run for college work.
I tried using DOSBox but it seems that the HP Pavilion laptop keypad isn't compatible. I can't even get my C drive to mount because there's no key that prints the ':' character.
So I guess the only option is to install 32 bit vista. A friend of mine has a 32 bit vista installation. If I install a copy using his activation key and then later (after installation)change it to my 64bit key, will it work?
Thanks in advance
Hello Ayush, and welcome to Vista Forums.
As long as you are installing your same Vista Home Premium edition, you can use your 64-bit product key number during the installation of the 32-bit Vista instead. 32-bit and 64-bit Vista key numbers are the same. You just have to use the same key number with the same original edition (ex: Ultimate, Home Premium) of Vista instead.
Thanks Shawn.
On the back of my laptop, it says :
<B>Windows Vista Home Premium OEMAct</B> and then the activation key is printed.
What does 'OEMAct' mean?
Sorry Ayush,
Since you have a OEM (Original Equipment Manufacturer) copy, you must contact HP to get a 32-bit OEM Vista replacement instead for your computer model. :(
Thanks in advance
Why doesn't Dosbox work on 64-bit? It works fine on my laptop. What is wrong with the keypad?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Vista is nasty as far as backwards compatibility my advice is to check into Virtual operating systems the best free software I have found is from Sun Microsystems however I know Microsoft makes a free one but I dont have the experience with that software to vouch for it. To use these you must have copy's of the OS's I also recommend getting Power ISO.
Virtual Box
Download VirtualBox | Register for VirtualBox resources | Free VirtualBox & Open Source VirtualBox
Power ISO
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
Microsoft VM (I haven't tryed it)
Windows Virtual PC: Home Page
