Want to change advanced power options with a few keyboard presses?
I like changing advanced power options all the time, mostly CPU throttle and brightness (the two most important factors in battery life). I used to have a separate power plan just for different CPU throttles, but that seemed a little inefficient (as did opening advanced power options under several layers of GUI). So I just finished writing up some batch scripts to change advanced power settings.
All you need to do is copy the attached files into the System32 folder (C:\Windows\System32\), for which you'll need to provide administrator privileges. Then, just press Win+R and type the name of the setting followed by the value. For example:
"bri 30" will change the screen brightness to 30%.
"maxp 50" will change the maximum CPU throttle to 50%.
"sleep 5" will change the time until sleep to 5 minutes.
Like so:
By the way, you can change the command just by changing the name of the file. Renaming "disp.bat" to "Display Brightness.bat" will let you type "Display Brightness 4" instead of "disp 4".
Let me know what you think. I can make one for each and every advanced power setting, all you gotta do is ask. Enjoy! (Don't mind giving me rep if you use this, I spent quite some time on this
View attachment System32.zip
Like so:
)View attachment System32.zip
- HP dv5-1120ej Notebook PC
- Intel Dual 2.16GHz
- 4GB
- NVidia GeForce 9200M GS, 256MB
- 320GB internal, 320GB external, 1TB external to come (big download library XD)
- Fast enough
- Other Info
- Firefox, Foobar, and AutoHotkey! Go open source!
